> I want to delete the relay board, How do I do this?
URY914
post Dec 15 2003, 09:43 PM
I deleted my alternator (wire, tin, bolts, nuts, brackets, etc) and saved 18 pounds!!! (IMG:style_emoticons/default/smilie_pokal.gif)
Now I want to delete the relay board. But I need to know how to wire the starter in. I know I'll need some sort of voltage regulator or relay in the starter circuit.
What have the others of you done?
Thanks,
Paul
davep
post Dec 16 2003, 10:44 AM
914 Historian
You moght be best off removing the existing harness in as complete a condition as possible. Then create a new harness to do exactly what you require. I would use a starter switch to operate a relay to operate the solenoid. There has been a "hot-start" kit available for years. That reduces the current through the switch and wiring. Reduces the cost of the switch(s), but adds the cost of a relay. I see Bosch 30 amp relays around that would be ideal.
DaveP
- Lo-Fi Version Time is now: 12th July 2025 - 11:31 PM
