VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,755 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
I tweaked my back a little last night while welding my engine cart together (which turned out awesome, by the way).
It hurt today, but was feeling better tonight so I went back out to the garage to rebuild a 3 ton jack. Well, suddenly I realized that my back really hurt. And now I can only limp around like an old man. I had to have my wife take my boots off for me. I am going to bed. This blows! Zach |
milnersXcoupe |
Newbie ![]() Group: Members Posts: 6 Joined: 11-December 07 From: New York Member No.: 8,452 ![]() |
MedlinePlus Drug Information: Ibuprofen
People who take nonsteroidal anti-inflammatory medications (NSAIDs) (other than aspirin) such as ibuprofen may have a higher risk of having a heart attack ... My spine is wreckage - so btdt - . The Flexi is fine - do NOT drink ANY Alcohol - you will Torch your Kidinies and Liver. We recently buried a friend, Sherri Brechia - 40 - light weight meds with Wine. Ibuprofen - skip it. Anything that asks you if you've previous Liver / Kidney problems - is doing so because it severely 'taxes' them - ie - causes damage. This is also used as the 'disclaimer' in court cases. Kidney / Liver do not regenerate / repair - you just lose function and carry more toxicity in your blood stream. Ask your MD for a script for: LOVAZA > 1 x 4 daily. It's pharmaceutical grade Omega 3 oils - which your system requires in huge amounts - and is not available thru 'normal diets'. Your Heart requires this as not to 'tear' since aging 'drys out' the Heart Muscle - as does booze / meat diets / white sugar / coffee. The Heart uptakes oils and nutrients via blood contact - as it doesn't have veins flowing thru it - so you need to carry the Omega 3 oils in your blood stream. Stroke: Omega 3 oils again. The vascular system shrinks & hardens from booze / coffee / meat diets / white sugars - then as pressure increases you pop a small vein & lose half your speech. With the regular LOVAZA use you'll reduce your chance of stroke / heart attack by 95% - as stated in American Stroke Association lit. LOVAZA, formerly OMACOR, is Rx grade & 3 times the strength of over the counter Omega 3: EPA 465mg DHA 375mg use these figures as your baseline per gel cap dose. Your spine stays in place vi muscles on either side being in 'balance' - you stretch one and the now stronger other yanks a disc, pinching a nerve - then the discs above it begin to rotate to take up some of the slack. Get the crutches as I stated earlier - just do the basic alignments to let the musculature mend evenly. That other device sounds good - try it later, for now just do the basic straight line stretch & keep your back straight while lifting. Get yourself a $25.00 hand held electric massager at your local Pharmacy - lying down - slam it up into an armpit - leave the 'Heat' off. This will keep your 'fluid cycle' running for faster repairs - and remove 'stress' - and enable 'motion' for musculature to 'move' discs around while the back is 'unloaded' of weight. When you lie down to sleep - everything shuts down - which leaves 'bruised chemistry' in place as the 'fluid cycle' - active during activity - virtually shuts down. MD's always say - get active asap - ? this is why - so repair codes & fluids are delivered and cleared etc. Using an electric massager 'tricks' the fluid cycle into staying on while 'at rest' - I sleep with my rig running all night - have for years - just leave the 'Heat' thing OFF. Usually under an armpit does the trick - sometimes the side of the neck. I'm an instrumentalist so I do my Hand Joints regularly & use Glucosamine Chondroiten & Nutri Tech 'Phyto Green' mixed in Westsoy Plain Enriched Soymilk - 1 heaping coffee scooper to 1.5 glasses into blender for 20 sec. : www.all-one.com > 'phyto green' > get the 'going green' product disclosure & read it > free @ 1-800-235-5727. Aging is about losing - loss of nutrients leads to loss of fuel for micro mechanisms that repair us. Do the above as stated from here out > you'll be around for the Stem Cell Regenerative Medicine that is on the horizon..... but later for that. |
Lo-Fi Version | Time is now: 6th July 2025 - 08:42 PM |
