> I just killed my back, I can barely freak'n walk
VaccaRabite
post Dec 12 2007, 07:17 PM
En Garde!
I tweaked my back a little last night while welding my engine cart together (which turned out awesome, by the way).
It hurt today, but was feeling better tonight so I went back out to the garage to rebuild a 3 ton jack.
Well, suddenly I realized that my back really hurt.
And now I can only limp around like an old man. I had to have my wife take my boots off for me.
I am going to bed. This blows!
Zach
milnersXcoupe
post Dec 13 2007, 03:09 PM
MedlinePlus Drug Information: Ibuprofen
People who take nonsteroidal anti-inflammatory medications (NSAIDs) (other than aspirin) such as ibuprofen may have a higher risk of having a heart attack ...
My spine is wreckage - so btdt - .
The Flexi is fine - do NOT drink ANY Alcohol - you will Torch your Kidinies
and Liver. We recently buried a friend, Sherri Brechia - 40 - light weight meds with Wine.
Ibuprofen - skip it.
Anything that asks you if you've previous Liver / Kidney problems - is doing so because it severely 'taxes' them - ie - causes damage.
This is also used as the 'disclaimer' in court cases.
Kidney / Liver do not regenerate / repair - you just lose function and carry more toxicity in your blood stream.
Ask your MD for a script for:
LOVAZA > 1 x 4 daily.
It's pharmaceutical grade Omega 3 oils - which your system requires in huge amounts - and is not available thru 'normal diets'.
Your Heart requires this as not to 'tear' since aging 'drys out' the Heart Muscle - as does booze / meat diets / white sugar / coffee.
The Heart uptakes oils and nutrients via blood contact - as it doesn't have veins flowing thru it - so you need to carry the Omega 3 oils in your blood stream.
Stroke: Omega 3 oils again. The vascular system shrinks & hardens from
booze / coffee / meat diets / white sugars - then as pressure increases you pop a small vein & lose half your speech.
With the regular LOVAZA use you'll reduce your chance of stroke / heart attack by 95% - as stated in American Stroke Association lit.
LOVAZA, formerly OMACOR, is Rx grade & 3 times the strength of over the counter Omega 3:
EPA 465mg
DHA 375mg
use these figures as your baseline per gel cap dose.
Your spine stays in place vi muscles on either side being in 'balance' - you stretch one and the now stronger other yanks a disc, pinching a nerve - then the discs above it begin to rotate to take up some of the slack.
Get the crutches as I stated earlier - just do the basic alignments to let the musculature mend evenly.
That other device sounds good - try it later, for now just do the basic straight line stretch & keep your back straight while lifting.
Get yourself a $25.00 hand held electric massager at your local Pharmacy - lying down - slam it up into an armpit - leave the 'Heat' off.
This will keep your 'fluid cycle' running for faster repairs - and remove 'stress' - and enable 'motion' for musculature to 'move' discs around while the back is 'unloaded' of weight.
When you lie down to sleep - everything shuts down - which leaves 'bruised chemistry' in place as the 'fluid cycle' - active during activity - virtually shuts down. MD's always say - get active asap - ? this is why - so repair codes & fluids are delivered and cleared etc.
Using an electric massager 'tricks' the fluid cycle into staying on while 'at rest' - I sleep with my rig running all night - have for years -
just leave the 'Heat' thing OFF. Usually under an armpit does the trick - sometimes the side of the neck. I'm an instrumentalist so I do my Hand Joints regularly & use Glucosamine Chondroiten & Nutri Tech 'Phyto Green' mixed in Westsoy Plain Enriched Soymilk - 1 heaping coffee scooper to 1.5 glasses into blender for 20 sec. : www.all-one.com > 'phyto green' > get the 'going green' product disclosure & read it > free @ 1-800-235-5727.
Aging is about losing - loss of nutrients leads to loss of fuel for micro mechanisms that repair us.
Do the above as stated from here out > you'll be around for the Stem Cell Regenerative Medicine that is on the horizon..... but later for that.
Wilhelm
post Dec 14 2007, 04:34 PM
"The Heart uptakes oils and nutrients via blood contact - as it doesn't have veins flowing thru it - so you need to carry the Omega 3 oils in your blood stream."
Wrong! The heart has an extensive blood supply to absorb nutrients and oxygen and other than a few cell layers does not get nutrients via blood contact.
Vacca Rabite   I just killed my back   Dec 12 2007, 07:17 PM
Trevorg7   Man that sucks, hang in there. I have a chronic ba...   Dec 12 2007, 07:22 PM
Porcharu   Get yourself one of these. Back fixer Absolutel...   Dec 12 2007, 07:38 PM
TedK   That back fixer looks like a great idea, but what ...   Dec 12 2007, 07:56 PM
Dr. Roger   Dude, I've had a bad back since '92. Seen...   Dec 12 2007, 08:03 PM
drive-ability   Sounds like you have a trigger point in your back,...   Dec 12 2007, 08:47 PM
Dr Evil   That sucks man :( No bowling for you on Sun? Dont ...   Dec 12 2007, 08:54 PM
Vacca Rabite   That sucks man :( No bowling for you on Sun? Dont...   Dec 13 2007, 09:33 AM
ahdoman   If it's your lower back it might be a leg / bu...   Dec 12 2007, 10:26 PM
tmh75   goolge "egoscue" its an chiropractic exe...   Dec 12 2007, 10:32 PM
Mr.C   Great information! I had the crawling not abl...   Dec 12 2007, 10:49 PM
rick 918-S   I feel your pain dude. I have a curved spine and H...   Dec 12 2007, 10:49 PM
mikelsr   Go see a doctor. After four bad discs and one bac...   Dec 12 2007, 10:55 PM
milnersXcoupe   "Cheap & Easy" Get yourself a set ...   Dec 12 2007, 11:53 PM
Elliot Cannon   Hurt my back 35 years ago working in a warehouse. ...   Dec 13 2007, 12:58 AM
MrKona   Hopefully it's just muscular. Sounds like you...   Dec 13 2007, 01:41 AM
thesey914   I just had a Microdiscectomy 6 weeks ago after hav...   Dec 13 2007, 05:06 AM
effutuo101   I have had 2 back surgury. I have nerve damage (10...   Dec 13 2007, 09:12 AM
Vacca Rabite   Doc appointment at 11:15, and my darling wife stay...   Dec 13 2007, 09:36 AM
Zaney   :smash: Ouch! I hope it's just muscular. ...   Dec 13 2007, 09:57 AM
jd74914   Nate is right. My Dad had tons of back problems (f...   Dec 13 2007, 10:40 AM
racerx9146   same thing I had a year ago. If you are tall and n...   Dec 13 2007, 11:02 AM
Vacca Rabite   Back from the Doc. He thinks it is all just muscu...   Dec 13 2007, 01:13 PM
Dr Evil   Aw man, percocet is fun and has a good street valu...   Dec 13 2007, 01:40 PM
Todd Enlund   Doc appointment at 11:15, and my darling wife sta...   Dec 13 2007, 01:51 PM
sww914   All this stretching, exercising, yoga crap is a bu...   Dec 13 2007, 02:48 PM
milnersXcoupe   MedlinePlus Drug Information: Ibuprofen People who...   Dec 13 2007, 03:09 PM
Dr Evil   MedlinePlus Drug Information: Ibuprofen People wh...   Dec 13 2007, 04:05 PM
Wilhelm   "The Heart uptakes oils and nutrients via blo...   Dec 14 2007, 04:34 PM
milnersXcoupe   Aw man, percocet is fun and has a good street valu...   Dec 13 2007, 04:25 PM
Dr Evil   I am not here to argue with you. Are YOU the neuro...   Dec 13 2007, 04:49 PM
scotty b   Sorry Zach. I can definitely sympathize. I have an...   Dec 13 2007, 06:49 PM
angerosa   Yeah Sorry to hear that but rejoice in the fact th...   Dec 14 2007, 04:09 PM
jimkelly   my back has gone out 3 or 4 times over the past 4 ...   Dec 14 2007, 04:45 PM
- Lo-Fi Version Time is now: 6th July 2025 - 08:24 PM
