> Car wont start after sitting a while...need ideas.
biosurfer1
post Dec 15 2007, 07:20 PM
Teener fo Life!
So after 8 months of sitting, moving to my new house next week got my a$$ in gear to get my 914 back on the road...and now it wont start.
Background Info: Back in April, the 914 went on jackstands to replace the brake calipers and convert the tranny to sideshift. Brakes are now done, and the tranny was rebuilt and installed. I didnt start it for so long because I couldnt get the shift linkage adjusted. I know, bad excuse but with a new job and whatnot, it just got put on the back burner.
Anyways, now I want to drive it to the new house so I started going through it and trying to solve the problems. I tried starting it the other night and all it would do is crank very slowly but wouldnt not turn over. After talking with a friend, I found that the tranny ground strap was not installed. I got a new one, cleaned all connections and hooked it up. Now the car will crank like normal, but it will still not start.
I went through everything I could think of but nothing helped, so now i'm looking for suggestions on where to go from here.
List of what has been checked:
accelerator and throttle linkage ok
all hoses replaced and connected correctly
battery fully charged
all grounds cleaned connected correctly
AAR recently cleaned out and works
plenty of gas in the tank
So where do I go from here??
BTW, its a 1971 1.7 with FI.
KaptKaos
post Dec 16 2007, 10:53 PM
Family
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
Nice.
biosurfer1   Car wont start after sitting a while...need ideas.   Dec 15 2007, 07:20 PM
KaptKaos   Air, fuel and spark. Check the air filter, make...   Dec 15 2007, 07:38 PM
The Kelzer   [quote name='KaptKaos' date='Dec 15 20...   Dec 15 2007, 08:37 PM
stateofidleness   check the connections on the starter and the ignit...   Dec 15 2007, 07:40 PM
biosurfer1   Thanks guys State: I checked all the connections ...   Dec 15 2007, 08:18 PM
jasons   Since its FI, do you hear the fuel pump run moment...   Dec 15 2007, 08:48 PM
Hammy   Since its FI, do you hear the fuel pump run momen...   Dec 15 2007, 09:18 PM
biosurfer1   i was trying to listen for the fuel pump but the f...   Dec 15 2007, 11:52 PM
roadster fan   Since it ran good when you parked it I would guess...   Dec 16 2007, 12:31 AM
swl   A year is a little short for varnish build up but ...   Dec 16 2007, 07:22 AM
biosurfer1   took out the heater fan relay and turned the ignit...   Dec 16 2007, 12:30 PM
swl   while you are waiting for reinforcements... Take ...   Dec 16 2007, 03:36 PM
biosurfer1   2 steps forward, one step back:( I found that the...   Dec 16 2007, 04:32 PM
KaptKaos   Take the carpet up in the middle of the car. Find...   Dec 16 2007, 04:40 PM
swl   quite a common oops is to get the throttle cable w...   Dec 16 2007, 04:50 PM
biosurfer1   Thanks everyone... I replaced the fuel lines that...   Dec 16 2007, 10:50 PM
KaptKaos   :trophy: :trophy: :trophy: :trophy: :trophy: ...   Dec 16 2007, 10:53 PM
biosurfer1   BTW...this car is a perfect example of "while...   Dec 16 2007, 11:03 PM
- Lo-Fi Version Time is now: 11th July 2025 - 12:44 PM
