how large can you go on a 2.0 |
ne14914 |
Mar 17 2003, 11:43 PM
Me N My914 Group: Members Posts: 94 Joined: 4-March 03 From: Los Angeles, Cali (Inland Empire) Member No.: 388 |
How large can you build a 2.0 motor and still use it as a reliable daily driver?
Dave Cawdrey |
Mar 18 2003, 04:08 PM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
QUOTE(Mark Henry @ Mar 18 2003, 05:41 AM) 78mm X 96mm is the largest you can you build a 2.0 motor and still use it as a reliable daily driver. Dave if you are going with a 78mm crank get one with type 1 (beetle) rod journals. Not only are T4 rods heavy but they're very short (rod angle) as well. You can use modified T1 rods or any of the aftermarket T1 longer rods. This will give you greater flexablity on the design of your engine. You will also have to use a small (22mm) pin piston like the 96mm or some guys have used a 94mm T1 piston on a T4 jugg. Good luck, Mark I already got H-beams w/ chevy journals and bushed for 22 pins. My 94's are cut for longer (78) stroke. I was considering the T 1 stuff when this stuff (P's & rods) was brought to my attenion... Thanks for yer ideas, tho |
Lo-Fi Version | Time is now: 10th June 2024 - 10:31 AM |
