> Oil Temperature and Pressure Senders and Gauges, I need some..
Mockmaw
post Dec 15 2003, 07:19 PM
Hello all,
Now that the fury of school and work are beginning to subside for my annual multi-week-vacation, I'm gearing up to continue work on my car. As I reinstall the engine in the coming weeks, I want to take care of the lack of oil temperature/pressure measurement in my car (especially with the 'new' mildly beefed-up engine). My car (a '72) never had an oil temp guage (nor sender to the best of my understanding) but it does have the traditional oil pressure sender and idiot light dealie. I'd like to be able to monitor actual numbers (okay, well not numbers.. perhaps 'variability beyond an idiot light' is what I was gunning for) and I don't know the best way to do this. CB offers this; will this work:
http://www.cbperformance.com/catalog.asp?ProductID=837
If not, what's the best way of addressing the problem? I have a custom center console that I've constructed that can house the gauges (or I can construct a different place to put them.. such as where the old heater controls are, since I won't be using those anymore..) In any event, placement and size of gauges isn't as important as finding a reliable and efficient way of handling the problem.
Thoughts? Suggestions? I'm hoping to order them in the next 24 hours so they'll be there by the time I get home.
Thanks!
trojanhorsepower
post Dec 17 2003, 03:33 PM
Mockmaw,
I think that part of the problem is that no one makes a sender that has the same threads as the original sender (located on the top of the block near the oil cooler). So different vendors have come up with different solutions. One popular solution (VDO I know and maybe others) is a piece of hose with different fittings on each end. One that matches the original sender (male) and a female fitting that matches the modern sender. I think that Brad once suggested that the hose for a grease gun may have the correct fittings. These can be purchased at your local auto parts store. You may also be able to have a hose made at a parts place or hydraulics place. Just pick a sender and take it and your old sender to the shop and tell them what you want.
Hope that helps
-Pete
- Lo-Fi Version Time is now: 9th November 2026 - 09:54 AM
