Now what? Fuse on relay board blowing., rear fuse that controls fuel pump blowing |
Phoenix914 |
Dec 30 2007, 05:42 PM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
Last night I tried to start my 914 to move it out of the garage...and it didn't start. When I turned the key, the auxiliary fan came on because the lever was pulled back. I turned off the fan, then proceeded to start the engine and it just cranked. I turned off the key, then turned it to the on position. This was when I noticed the fuel pump didn't come on. Why? During my check I discovered the rear fuse of the two on the relay board in the engine compartment was blown. A little research told me that this fuse is for the fuel pump and aux. fan.
So, I disconnected the fuel pump, put in a new fuse and it blew when I turned the key. Another new fuse, reconnected the fuel pump, disconnected the aux. fan, turned the key and the fuse blew again. It's not the fan. What is causing this? I drove the car in there less than two weeks ago!! It's strange that the aux. fan came on the first time I turned the key. Now it won't work with the fuse blown. Somebody please help me. I have to move everything out of this rented garage tomorrow. This includes my 914. I'd rather not have to tow it if that can be avoided. |
Dr Evil |
Jan 2 2008, 11:57 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Just to make sure, in what condition was the plug to the AAR? The most common problem I have found with those is not an internal short, but rather the plug being uninsulated allowing it to ground against the case, often intermittently. If the plug has bare metal showing try insulating that first.
Lo-Fi Version | Time is now: 10th June 2024 - 03:46 AM |
