> I created an Oil Leak!, by replacing with viton seals? wtf?
purple
post Jan 9 2008, 10:05 AM
Pigeon feeders attract me
Greetings Yall!
I have just put the engine back in my teener and started it up (without the exhaust) to make sure I got everything right before I'd do more major re-assembly.
Well, it turns out I created an oil leak where there wasnt one before DOH!
I replaced the drivers side pushrod tube seals with the viton set from auto atlanta. I noticed at that time that I had only 5 'big' o-rings and 11 'small' o-rings. It was enough to do the drivers side tubes but i was hesitant to try the passenger side. Well..this weekend I put the passenger side ones on. I used the small o-rings on the big side of the pushrod tubes because that's all I had
DONT DO THIS
I knew there was going to be a problem when I saw the PO had used silicone sealant around the big o-rings...
It doesnt leak when the engine runs, it does it after the engine has cooled off and the oil still in the rocker box just kinda drips out. This really sucks bad and was wondering if I should get another viton set from AA or what? Should I use some gasket-maker to seal the o-rings? should i re-use the old ones? they werent leaking after all...
the moral of the story: 'while im in there' leads to big f-ups sometimes
Allan
post Jan 9 2008, 01:14 PM
Teenerless Weenie
First order I ever placed with AA was for Viton seals.
Got a bag of generic o-ring instead... (IMG:style_emoticons/default/blink.gif)
purple   I created an Oil Leak!   Jan 9 2008, 10:05 AM
type47   maybe stretching the O-ring caused it to be thinne...   Jan 9 2008, 11:10 AM
davep   Now you know why using the wrong part can cost muc...   Jan 9 2008, 12:57 PM
purple   I guess I have a beef with auto atlanta, I mean th...   Jan 9 2008, 12:59 PM
SLITS   And now you know why you should have ordered them ...   Jan 9 2008, 01:11 PM
KaptKaos   I got mine in a set from Pelican. There were actu...   Jan 9 2008, 01:13 PM
Headrage   First order I ever placed with AA was for Viton se...   Jan 9 2008, 01:14 PM
TeenerTim   the moral of the story: 'while im in there...   Jan 9 2008, 01:24 PM
slackin' at work   I just did this to my car as well. I bought my se...   Jan 9 2008, 01:51 PM
Jake Raby   I do NOT use the Viton seals! They are more di...   Jan 9 2008, 02:09 PM
2-OH!   Also, once you get the correct seals (Viton works ...   Jan 9 2008, 02:32 PM
Brando   Don't half-ass, and use the right parts :)   Jan 9 2008, 02:46 PM
Jake Raby   The loctite 565 trick works real well for me, espe...   Jan 9 2008, 02:52 PM
purple   Mr. Raby....I can quote you saying 'use viton ...   Jan 9 2008, 05:50 PM
Cap'n Krusty   Jake uses Loctite, I use motor oil. Both work. T...   Jan 9 2008, 06:52 PM
Jake Raby   And I'll still be doing it when he the Capn...   Jan 9 2008, 08:02 PM
purple   What's funny is this 'viton' stuff is ...   Jan 10 2008, 08:26 AM
Jake Raby   The material IS superior- no argument there.. But ...   Jan 10 2008, 10:35 AM
purple   last night I pulled the rockers, rods, and tubes.....   Jan 11 2008, 08:54 AM
Jake Raby   for small items we can do priority overnight for ...   Jan 11 2008, 10:39 AM
purple   for small items we can do priority overnight for...   Jan 11 2008, 11:08 AM
Jake Raby   COOL! We are realy getting the store efficient...   Jan 11 2008, 11:21 AM
- Lo-Fi Version Time is now: 13th July 2025 - 07:18 PM
