purple |
Pigeon feeders attract me ![]() ![]() ![]() Group: Members Posts: 938 Joined: 24-July 07 From: Houston, TX Member No.: 7,942 Region Association: None ![]() |
Greetings Yall!
I have just put the engine back in my teener and started it up (without the exhaust) to make sure I got everything right before I'd do more major re-assembly. Well, it turns out I created an oil leak where there wasnt one before DOH! I replaced the drivers side pushrod tube seals with the viton set from auto atlanta. I noticed at that time that I had only 5 'big' o-rings and 11 'small' o-rings. It was enough to do the drivers side tubes but i was hesitant to try the passenger side. Well..this weekend I put the passenger side ones on. I used the small o-rings on the big side of the pushrod tubes because that's all I had DONT DO THIS I knew there was going to be a problem when I saw the PO had used silicone sealant around the big o-rings... It doesnt leak when the engine runs, it does it after the engine has cooled off and the oil still in the rocker box just kinda drips out. This really sucks bad and was wondering if I should get another viton set from AA or what? Should I use some gasket-maker to seal the o-rings? should i re-use the old ones? they werent leaking after all... the moral of the story: 'while im in there' leads to big f-ups sometimes |
2-OH! |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 ![]() |
Also, once you get the correct seals (Viton works good for me) put them on correctly, prelube them with a very, very small amount of 30wt....Slide in through the head and apply a little pressure and turn the entire tube about a quarter of a turn at the same time as you push into place...This will help prevent the "bunch" effect and keep the metal from nibbling away or pinching at the seal...
After it slips into place check for uniformity of the tiny bit left you can see (both ends)...If it ain't perfectly uniform around the end of the tube, it's gonna' leak...Also make certain it's all the way in and seated... OH, and be sure the bore in the head and in the case are clean, free of debris and that there is no residue from the last set...Any of those will guarentee a leak... Try Zims (800-356-2964) for seals... Have fun... 2-OH! |
Lo-Fi Version | Time is now: 13th July 2025 - 07:51 PM |
