914 Track Suspension, Torsion Bar & Springs |
trapper |
Sep 22 2007, 10:02 PM
Newbie Group: Members Posts: 37 Joined: 6-February 03 From: Brighton, MI Member No.: 258 |
I need some suspension advice! I bought a 914-6 track car last spring and it is very soft. I don't know what I have installed yet but I suspect I need an upgrade over the winter. The car is a 2.8 liter with full cage. Any recommendations as to torsion bar size and rear springs? The car has front and rear sway bars, Bilsteins and monoball
front mounts. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/smash.gif) |
bumble |
Jan 14 2008, 06:37 AM
Newbie Group: Members Posts: 7 Joined: 20-January 04 From: Sydney, Australia Member No.: 1,582 |
I found the following to be near perfect:
23mm torsion bars 22mm front sway bar 300lb rear springs no rear sway bar Poly Bronze bushes throughout monoball top mounts 3.2 Carrera struts with raised spindles Very stiff chassis - full roll cage tied into the rear shock turrets, chassis stiffeners etc. Koni sport shocks. 2.7L engine (~180 RWHP). Quaife Torsen diff. This setup is extremely sensitive to sway bar settings - 1/4 inch either way is quite noticeable. Konis are the weak link - soon to be replaced with custom built Proflex shocks. Cheers, Mark. |
PeeGreen 914 |
Jan 17 2008, 06:02 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I found the following to be near perfect: 23mm torsion bars 22mm front sway bar 300lb rear springs no rear sway bar Poly Bronze bushes throughout monoball top mounts 3.2 Carrera struts with raised spindles Very stiff chassis - full roll cage tied into the rear shock turrets, chassis stiffeners etc. Koni sport shocks. 2.7L engine (~180 RWHP). Quaife Torsen diff. This setup is extremely sensitive to sway bar settings - 1/4 inch either way is quite noticeable. Konis are the weak link - soon to be replaced with custom built Proflex shocks. Cheers, Mark. This is almost what I have, and I would venture to say that this would be perfect. |
Lo-Fi Version | Time is now: 29th May 2024 - 01:15 AM |
