Intermittant complete loss of oil pressure, It goes away after a few minutes |
sww914 |
Jan 18 2008, 04:52 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
If it's warm at the track my car will occasionally loose all oil pressure, like 1-2 times a weekend at the worst, sometimes not at all. I shut it down and drift in if I'm close enough to the pits or I pull over and wait to get towed in.
After the engine has cooled a little bit, sometimes as little as 5 minutes, I can start the car again and all is well.I suspect that the oil pressure relief valve is sticking, what do you guys think? How could I fix this short of a dry sump system? I'm building a 2.7 to put in it right now so I can't spend a fortune on the 4. |
gregrobbins |
Jan 18 2008, 05:33 PM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Had a similar problem with the my car and it turned out to be a bad electrical connection.
Lo-Fi Version | Time is now: 7th June 2024 - 03:29 PM |
