Intermittant complete loss of oil pressure, It goes away after a few minutes |
sww914 |
Jan 18 2008, 04:52 PM
Advanced Member Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None |
If it's warm at the track my car will occasionally loose all oil pressure, like 1-2 times a weekend at the worst, sometimes not at all. I shut it down and drift in if I'm close enough to the pits or I pull over and wait to get towed in.
After the engine has cooled a little bit, sometimes as little as 5 minutes, I can start the car again and all is well.I suspect that the oil pressure relief valve is sticking, what do you guys think? How could I fix this short of a dry sump system? I'm building a 2.7 to put in it right now so I can't spend a fortune on the 4. |
brant |
Jan 19 2008, 08:50 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Usually the seperate guage and seperate light are still powered by the same (dual) sender
replace the sender I'd definitely look at wiring first its the cheapest to repair |
Lo-Fi Version | Time is now: 7th June 2024 - 09:53 PM |
