> WOT: need computer help...., need to assign an IP address to a particular computer....
scottb
post Dec 18 2007, 08:43 PM
who wants a PEZ?!
on my network.
i have a linksys BEFSR41 and have 2 IP addresses through comcast (at least that is what they tell me).
i need to do the following:
find out my IP addresses
assign one of these addresses to my wifes work computer, and let the rest of the house use the other.
i have messed around within the router but as i don't know my ip addresses. i do an ipconfig and only get one ip address.
so any suggestions oh wise ones? my wife an i both work for the same company and the security system is such that only one log in per ip address is allowed (hence the need for 2).
hope this is clear enough....
thanks,
scott
scottb
post Jan 28 2008, 06:00 PM
who wants a PEZ?!
ok, resurrecting this for some input. was not able to get things organized before and then work got busy among other excuses.but now i can work from home even more so i want this VPN issue resolved once and for all.
just got off the phone with comcast tech and the latest information i received is that in order to have IP addresses assigned, i will need a gateway modem. the IP addresses i have are not static so per the tech person, they cannot be assigned to a particular router port. i asked for a static IP address but they will not give them to residential accounts.
the reasoning for the gateway modem is that it will grab the first IP address for the first log on, then the second for the next. most of these that i have found on line look a lot like a router. i would set up a router and/or switch on a couple of the remaining ethernet connections so i can have use of more than one log in on one of the IP addresses.
ok, so there is the story and here are my questions:
1) does this reasoning sound plausible?
2) any suggestions for a gateway router?
as always, thanks in advance.
scott
scottb   WOT: need computer help....   Dec 18 2007, 08:43 PM
KaptKaos   www.ipchicken.com will show you the IP address you...   Dec 18 2007, 08:57 PM
effutuo101   You have two IP addresses and want one dedicated t...   Dec 18 2007, 10:06 PM
Dr. Roger   your wireless router has something called DHCP. Th...   Dec 19 2007, 01:19 AM
Sarastro   Anyone know of a different way besides two cable...   Dec 19 2007, 01:57 AM
scottb   roger, you are correct that we use rsa keys to log...   Dec 19 2007, 04:27 AM
Sarastro   Scott, Before you spend any money on additional e...   Dec 19 2007, 08:06 AM
Richard Casto   I am not as up on this as I used to be. I suspect...   Dec 19 2007, 11:25 AM
KaptKaos   I'll say this again. Confirm that your ISP is...   Dec 19 2007, 12:02 PM
scottb   you guys are making my brain hurt! :blink: i...   Dec 19 2007, 12:08 PM
Dr. Roger   before i do anything, try this.... cable comes ...   Dec 19 2007, 02:17 PM
Sarastro   Wow, I've set up and maintained quite a few ne...   Dec 19 2007, 03:33 PM
Richard Casto   Wow, I've set up and maintained quite a few n...   Dec 19 2007, 07:28 PM
scottb   I recommend you get back with the guys are work a...   Dec 19 2007, 04:38 PM
KaptKaos   The static IP issue is not a red herring. It requ...   Dec 19 2007, 07:47 PM
Richard Casto   The static IP issue is not a red herring. It req...   Dec 20 2007, 07:52 AM
KaptKaos   [quote name='KaptKaos' post='978516' date='Dec 19...   Dec 20 2007, 10:16 AM
Richard Casto   [quote name='KaptKaos' post='978516' date='Dec 1...   Dec 20 2007, 11:11 PM
Dr. Roger   cool then. so use both routers and you'll be ...   Dec 20 2007, 03:29 AM
scottb   ok, tried the following: modem to switch wife co...   Dec 20 2007, 04:24 AM
Richard Casto   A few things to check. When you had both PCs conn...   Dec 20 2007, 08:02 AM
dgw   Wife and I work for two different companies. both ...   Dec 20 2007, 08:18 PM
scottb   pulled out an old router and was not able to get a...   Dec 20 2007, 08:46 PM
Richard Casto   pulled out an old router and was not able to get ...   Dec 20 2007, 11:21 PM
Richard Casto   what difference should it make what ip address the...   Dec 20 2007, 11:25 PM
KaptKaos   2 PCs both going to the same VPN gateway. VPN ga...   Dec 20 2007, 11:24 PM
KaptKaos   Depends on the company and their security policies...   Dec 20 2007, 11:36 PM
Gint   Depends on the company and their security policie...   Dec 21 2007, 09:18 AM
Richard Casto   Example of what I am talking about... http://ask-...   Dec 20 2007, 11:44 PM
Dr. Roger   thats what I'm talking about   Dec 21 2007, 12:26 AM
scottb   thanks for all the help guys. i am going to take ...   Dec 21 2007, 06:23 AM
scottb   ok here is the latest as of today.... modem ----...   Dec 29 2007, 04:42 PM
Richard Casto   Scott, Sorry you are still having issues. If it ...   Dec 30 2007, 10:39 PM
KaptKaos   My head hurts from wrenching. I'll try and he...   Dec 30 2007, 10:58 PM
scottb   ok, resurrecting this for some input. was not abl...   Jan 28 2008, 06:00 PM
Richard Casto   Scott, (1) I have to say that I am a bit confused...   Jan 29 2008, 02:07 PM
- Lo-Fi Version Time is now: 4th July 2025 - 12:12 AM
