| ThinAir |
Jan 29 2008, 09:52 AM
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,569 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region
My 1970 914-4 with factory
I'm pretty sure that this has to be a loose connection or a wire that has worn through the insulation and is grounding occasionally. In order to make it easier to find, the question I have is what component would cause such a behavior? Knowing that might make it easier to track down where the problem is coming from. Any ideas? I want to put this back on the road for the Rt66 Classic in March. |
| ejm |
Jan 29 2008, 12:20 PM
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,716 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
QUOTE a quick check is the head temp sensor failure. I would just change it. The problem is so sporadic the sensor will most likely test good. Also check carefully where the CHT wire goes into the harness, it may be broken inside the insulation there. |
ThinAir Sudden flooding while running Jan 29 2008, 09:52 AM
dr914@autoatlanta.com
My 1970 914-4 with factory LJet FI ran fine when ... Jan 29 2008, 09:56 AM
Dave_Darling CHT sensor wire going open-circuit momentarily. M... Jan 29 2008, 09:57 AM
SLITS Uhhhh .... they actually made a '70 1.7 with L... Jan 29 2008, 10:32 AM
ThinAir
Uhhhh .... they actually made a '70 1.7 with ... Jan 29 2008, 09:01 PM
Bleyseng
I would just change it. The problem is so spora... Jan 29 2008, 07:05 PM
Bleyseng :chair: Jan 29 2008, 09:06 PM
ThinAir
:chair:
Thanks, I needed that! Jan 29 2008, 09:19 PM
SLITS Mine died and went really rich at the RRC last yea... Jan 29 2008, 11:49 PM
ThinAir Your the best, Ron. I always seem to forget about... Jan 30 2008, 12:14 AM
SLITS
Your the best, Ron. I always seem to forget abou... Jan 30 2008, 07:46 AM
ThinAir
Your the best, Ron. I always seem to forget abo... Jan 30 2008, 08:56 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:14 PM |
