Rear axle removal |
Rear axle removal |
whitey |
Jan 29 2008, 10:00 PM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
What is the procedure for removing the rear axles. Are they actually driven out?
KaptKaos |
Jan 29 2008, 11:31 PM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
If your CV bolts are stock, you will need a triple-square socket to get the bolts off the flanges on the trans.
Outboard, you need a GINORMOUS socket to get the nut off of the axle at the hub. Anyone know the size off of the top of their head? Undo those and you can pull the axles out pretty easily. |
Dr. Roger |
Jan 30 2008, 01:54 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
If your CV bolts are stock, you will need a triple-square socket to get the bolts off the flanges on the trans. Outboard, you need a GINORMOUS socket to get the nut off of the axle at the hub. Anyone know the size off of the top of their head? Undo those and you can pull the axles out pretty easily. My "off the top of my head" guesstimation is that it was about a 1 1/4" or 1 3/16" socket. Metric to SAE conversion. =) |
Lo-Fi Version | Time is now: 9th June 2024 - 02:35 AM |
