Real time djet help needed!, High idle |
championgt1 |
Jan 26 2008, 01:43 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Items noted 1:Using Dave Darling's diagram the line coming off the throttle body to the cap side port of the vacuum advance unit is plugged with a screw and not connected to the vacuum advance unit shown in top of picture. Does this line need to be connected to the cap side port of the vacuum advance unit? 2: The line from the back of the vacuum advance line is omited because the car is a 74 and does not have a port on the throttle body. |
rhodyguy |
Jan 30 2008, 08:25 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
first thing i would do is, take one of the headlight relays out, presuming your headlights worked properly. the relays are located in the front trunk under the black plastic covers next to the headlight motors. swap one out for item #12, fig 9.21 p.128 of your haynes. turn the key to the first position and see if the fuel pump runs briefly and shuts down.
k |
Lo-Fi Version | Time is now: 7th June 2024 - 06:21 AM |
