SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,319 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
(IMG:style_emoticons/default/icon8.gif) got the new alternator and decided to cut back the plastic sheeting around the alternator wires to see how much damage then burned up diode had done.
i guess a lot of current while draining the battery can really produce some heat ... (IMG:style_emoticons/default/headbang.gif) so, now the $432 dollar question, is there a replacement harness for this or do i have to either get a complete new engine harness or try to replace each wire individually? they're pretty much burned all the way into the main harness. i cut out the worst, but the insulation where i cut them was still very hard and brittle, so i'm guessing the whole of the wires is toast ... this is on the 3.6L engine, btw. ... (IMG:style_emoticons/default/blink.gif) Andy ![]() ![]() ![]() |
JeffBowlsby |
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,052 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
Yipes Andy!
If the damage is not too bad, maybe a few wires/casing can be replaced easily enough. The Rich Johnson harness looks like a great deal if you are in a hurry. If you do replace it, would you donate it to me for 914 harness science? |
SirAndy |
If you do replace it, would you donate it to me for 914 harness science? sure thing ... (IMG:style_emoticons/default/beerchug.gif) a little bird just told me that the new harness from porsche is $775 ... (IMG:style_emoticons/default/huh.gif) Andy |
Lo-Fi Version | Time is now: 26th September 2025 - 06:34 AM |
