| stephenaki |
Feb 18 2008, 11:57 AM
Can I get this one dad?? ![]() ![]() ![]() Group: Members Posts: 1,191 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
OK, I went to Cologne this weekend and on the way up stopped by to see Ingo at Mittelmotor to see what the deal was...I was prepared for the worst based on his email.
Well, based on his email, and some information from this forum, it is not near as bad as I feared. Let me summarize this and get to the point and, I will need some input from the group on some issues. 1. Diesel problem, fixed. They changed out 3 of the plugs, one was stubborn so they decided better I break it than them, and fuel filter. Runs fine now. 2. Front axle not a problem, he thinks the shocks should be changed. Otherwise the tierods and A-arms were solid. 3. Brake lines. Fairly well worn and the lines from the metal tubing to the brakes definately need replacing. 4. Engine and Gear Box leak. Need to replace some seals, nothing that requires the engine to be dropped. 5. Lights and wipers. still inop and the lower right fog?driving light? is busted. 6. Engine mounts need replacing. All four are worn and the rubber cracked. 7. Rear axle (this had me worried). It IS attached to the car. What he was refering to was that the trailing arms had lateral play and he said that the pin that runs through it was bad and the entire trailing arm should be replaced on both sides. So, here are my questions, most serious concern first. 1. Trailing arm lateral play, whats tolerance? Can the pin be replaced or do I have to replace the entire trailing arm? (IMG:style_emoticons/default/confused24.gif) From what I can see, the whole unit must be replaced. This would be the most expensive problem. 2. Lights, what are common problems that people have experienced that would cause the headlights and driving lights to shut down? All the other lights and turn signals work. Bottom line, not that big a problem, the cost was going to be the labor, they charge A LOT!! Needless to say brakes are PITA and I didn't feel like messing with the seals so I had him fix those two problems. If I had my Mityvac I would have done the brakes but I don't and I hate bleeding brakes! I go back next Saturday to pick up the car, I will put her on a trailer and bring it back to Stuttgart then drop it off at the on-post auto craft shop and work on it there. Barring any significant issues with the trailing arms, need your input on this one, I should have it up and ready for inspection before the end of March. (IMG:style_emoticons/default/driving.gif) Of course this could all come to a screeching halt if they send me on another lovely trip somewhere else for a few weeks but I don't think that is in the cards right now. (IMG:style_emoticons/default/av-943.gif) |
| rhodyguy |
Feb 18 2008, 12:11 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
shot bushings/pin on the trailing arms? look at the elephant setup (eric shea offers them done) but he has done a nice write up on how-to yourself. an alignment will be required. chris foley offers a delrin(?) replacement set as well.
you can do the mounts yourself both outboard fronts and the rears. year specific. avail at pelican and other vendors. wipers? check the fuse. the lights don't raise or don't illuminate. don't raise? suspect the relays. check fuses then the headlights. sealed beam or halogen? the fog/driving lense is easily replaced if that's what's wrong. |
| stephenaki |
Feb 18 2008, 12:31 PM
shot bushings/pin on the trailing arms? look at the elephant setup (eric shea offers them done) but he has done a nice write up on how-to yourself. an alignment will be required. chris foley offers a delrin(?) replacement set as well. you can do the mounts yourself both outboard fronts and the rears. year specific. avail at pelican and other vendors. wipers? check the fuse. the lights don't raise or don't illuminate. don't raise? suspect the relays. check fuses then the headlights. sealed beam or halogen? the fog/driving lense is easily replaced if that's what's wrong. Lights raise, don't illuminate. Checked all the fuses, unless there are some hidden other than under the dash, they are all still good. Ugly, but good. |
| TeenerTim |
Feb 18 2008, 12:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 597 Joined: 22-October 07 From: Norfolk,VA Member No.: 8,253 Region Association: MidAtlantic Region |
Never overlook the obvious. The bulb may be burned out.
| stephenaki |
Feb 18 2008, 12:47 PM
stephenaki Mittelmotor 914 Update! Feb 18 2008, 11:57 AM
r_towle Lets see,
Oil leaks, motor mounts, bad plug...take... Feb 18 2008, 01:38 PM
Eric_Shea
Well... true, we rarely see "wear" as ... Feb 18 2008, 03:11 PM
Bleyseng :WTF: :agree:
When I visited in 2004 some of th... Feb 18 2008, 06:45 PM
rick 918-S I wouldn't put any stock in a visual inspectio... Feb 18 2008, 06:53 PM
stephenaki Thanks to all for the responses, I am thinking of ... Feb 19 2008, 12:58 AM
hcdmueller Check out Engmans website
http://engmanparts.com ... Feb 19 2008, 04:22 AM
stephenaki
http://engmanparts.com... Feb 19 2008, 04:49 AM
rick 918-S Someone should post a photo of a suspension consol... Feb 19 2008, 08:20 AM
Eric_Shea We don't know if that's the problem.
I s... Feb 19 2008, 11:45 AM
stephenaki
I ... Feb 19 2008, 01:33 PM
jd74914 If you are going to get a new fuse block get the n... Feb 19 2008, 06:46 PM
stephenaki Picked up a car and trailer today; will be off to ... Feb 22 2008, 01:27 PM
Jeffs9146 Ovaling before repair and after repair! Feb 22 2008, 05:41 PM
stephenaki
I r... Feb 23 2008, 01:34 PM
stephenaki Ya know, the Army has a saying, "no plan surv... Feb 23 2008, 02:02 PM
Eric_Shea :whistle:
Feb 23 2008, 02:34 PM
1970 Neun vierzehn Stephen,
I'm nominating you for the "200... Feb 23 2008, 02:48 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th April 2026 - 08:30 PM |
