> Tranny Gearing.
749142
post Feb 18 2008, 10:55 PM
Hey guys.
does anbydody know about regearing a 914 transmission with a steeper final drive ratio differential. do they make aftermarket differentials? if so any links?
thanks
steven
Bleyseng
post Feb 18 2008, 10:59 PM
Aircooled Baby!
The final drive/5th gear setup was setup to keep the fan moving at the right speed for cooling.
Changing that for a street car means looking at how you will cool the engine.
post Feb 18 2008, 11:18 PM
QUOTE(Bleyseng @ Feb 18 2008, 08:59 PM) *
my dad has done such extensive polishing to my heads and pistons that my engine runs about 65 degrees cooler than stock. so there for if i can gear it steeper i can get back some of that heat for efficiency and then have more topend if i have the power and have more efficiency becuase of lower rpms. i have video of my heads that are polished. they look like mirrors. you can see the reflection of my dad with the camera in the valves. it took him about 4 months to do the two. but it was well worth it. next best thing from ceramic coating.
steven
jd74914
post Feb 18 2008, 11:30 PM
Its alive
QUOTE(749142 @ Feb 19 2008, 12:18 AM) *
steven
How do you know it runs cooler than stock?
Polishing does not help you loose heat. If you polish the inside of your ports and combustion chambers you increase surface tension and hurt mixing, and if you polish the outside you loose surface area over the rough castings (heat exchange is dependent on surface area). (IMG:style_emoticons/default/wacko.gif)
- Lo-Fi Version Time is now: 13th July 2025 - 04:40 AM
