> What type of brake fluid should I use?, DOT 3, DOT 4, etc. ?
levonfarra
post Mar 17 2008, 09:20 PM
I use the car for street and canyon driving. My car has all stock brake system.
Thanks,
Levon
PeeGreen 914
post Mar 17 2008, 09:26 PM
Standard DOT 4 will be fine for you. We don't put DOT 3 in anything. I am sure it would be fine but there isn't any reason why not to use DOT 4. You don't need to use any Blue or other racing fluid as you are just using it for the street. I don't think you will ever get your brakes hot enough. Just be sure to bleed them every now and again.
SGB
post Mar 17 2008, 10:29 PM
just visiting
I dunno- "Canyon driving" is a potential load. I like to find DOT-4 brake fluid with a high "wet boiling point". My understanding is that the wet BP is based on fluid with some moisture content, as would be typical with a DD exposed to wet conditions. At m last flush, I put in Valvolene Synpower. It was at m FLAPS, cheap and had pretty good stats:table found by google
- Lo-Fi Version Time is now: 2nd April 2026 - 07:21 AM
