| Cap'n Krusty |
Apr 23 2008, 05:08 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
If you believe that crap works, I have a 12 lane bridge over some swamp land in Arizona you'd like to buy ........................................................... The Cap'n
| 736conver |
Apr 23 2008, 05:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None |
lol
Not here to argue it. I seen it first hand. Those who claim BS just dont know. |
| zymurgist |
Apr 23 2008, 05:34 PM
"Ace" Mechanic ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
If you believe that crap works, I have a 12 lane bridge over some swamp land in Arizona you'd like to buy ........................................................... The Cap'n Will you deliver it to the Potomac River about 5 miles upstream of the American Legion Bridge? (IMG:style_emoticons/default/biggrin.gif) |
| Dr. Roger |
Apr 23 2008, 06:32 PM
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
lol Not here to argue it. I seen it first hand. Those who claim BS just dont know. quoted from wiki: <The energy required to generate the oxyhydrogen always exceeds the energy released by combusting it; see Electrolysis of water:Efficiency.> and on the subject of acetone... I worked at the test fuel lab for Chevron in Richmond, CA. as a test fuel additive rater. Of course I played around with my own cocktails for the fuel tank. Acteone, as stated, reduces surface tension making for a more gaseous/vaporized charge. The problem is that when a fuel charge is more vaporized and less atomized the charge is more explosive and less "a controlled burn". A higher octane is a longer controlled burn. Lower octane is a quicker burn. (IMG:style_emoticons/default/chair.gif) Most things that seems too good to be true... usually are. Now if you add a high end solvent that prolongs the burning of the fuel, such as Tolulene or Zylene, you will realize an instant boost in octane rating. But that only works on a curve being the more you add, the less it increases octane. Also tough on rubber parts. But worth it IMHO for weekend racing. (IMG:style_emoticons/default/happy11.gif) |
| Cap'n Krusty |
Apr 23 2008, 08:28 PM
Don't go confusing them with facts, it's not fair ............... The Cap'n
| 736conver |
Apr 23 2008, 08:39 PM
Doctor Roger, Did you read the whole wiki article? If you didn't, please read the whole article again.
| Richard Casto |
Apr 23 2008, 09:07 PM
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States |
HHO is the way to go. My next door neighbor installed one on his Saturn sl2. Hes seeing about 20% increase on mileage so far. Im about to make my own and install it on my gas hog Durango. You are just yanking our chain right? (IMG:style_emoticons/default/confused24.gif) |
| Dr. Roger |
Apr 23 2008, 09:52 PM
Doctor Roger, Did you read the whole wiki article? If you didn't, please read the whole article again. whats your point? (IMG:style_emoticons/default/beer3.gif) |
| Dr. Roger |
Apr 23 2008, 09:54 PM
quoted from wiki:
<As a fuel supplement Oxyhydrogen improves emissions and economy of internal combustion engines when combined with air/fuel ratio and timing modification; these effects will be achieved given a performance tradeoff. The Hydrogen content of Oxyhydrogen will effect the burn rate of fuels and lean combustion capabilities of internal combustion engines.> all they're saying is mods have to be made. what they're not saying is that you've got to richen the A/F ratio and back off the timing..... cleaner running, yes. But at what price???? Bueller? (IMG:style_emoticons/default/popcorn[1].gif) |
| Dr. Roger |
Apr 23 2008, 10:04 PM
and taken from one of the technical reference foot notes from that particular wiki article which I have now read....
<In all cases considered, a considerable loss in maximum power capacity of the engine occurs as a result of the use of gaseous fuels and by operating under lean conditions. Effective utilization of onboard hydrogen generation calls for lightweight high displacement engines to overcome this disadvantage.> |
| ericread |
Apr 23 2008, 11:40 PM
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
All this talk of secret fuel additives reminds me of a drug that doesn't need FDA approval, and has been proven to cure almost any disease in up to 20% of the patients that take it.
I believe that everyone should have a supply of this drug in their cabinet, as test after test shows incredible healing results. The drug is called "Placebo", and is available upon request to your local pharmacy. Really, it works!!! (IMG:style_emoticons/default/aktion035.gif) |
| Borderline |
Apr 24 2008, 12:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
When I was in college (yes, many years ago) I took a class in Internal Combustion Engine Design. We spent a bunch of time studying engine efficiency. There is only so much energy in a gallon of gas. It takes so much energy to propel a vehicle. The engine's efficiency is limited by design (largest contributing factor being compression ratio). The instructor said that all those tales about super carbs were just tales. Of course, if someone can give us the patent numbers, we can check them out. I'm impressed that they have made the gains that they have.
| DNHunt |
Apr 24 2008, 11:41 AM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
It's kind of interesting that this topic came up. For any of you PBS fans NOVA just had a program on the car of the future. They touched on lots of stuff from fuels to alternative energies, increased efficiency, and reduced weight. It just so happens this is all available for download. I love this kind of stuff. Check this URL out . http://www.pbs.org/wgbh/nova/car/program.html
Dave |
| Cap'n Krusty |
Apr 24 2008, 12:14 PM
Without going past the opening page, my knee-jerk reaction is having Tom and Ray Magliacci host a serious study of cars of the future is like having Bozo the Clown teach an upper division philosophy class.
The Cap'n |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:32 AM |
