4 Pages V < 1 2 3 4 >
> What oil temp Temperature gauge do I trust, Just installed the new Pressure & CHT guages
marks914
post Nov 15 2008, 03:52 PM
Post #21
You should replace the original with a new module/sender, you can get them here:
http://www.newvintageusa.com/bigmarkdesign
(IMG:http://inlinethumb27.webshots.com/44378/2117910870057582025S425x425Q85.jpg)
Mark
jc914
post Nov 15 2008, 07:35 PM
Post #22
thanks marks914 I love the website first time I have seen it. Great products.
marks914
post Nov 15 2008, 07:48 PM
Post #23
Oops, I had a typo in the web address:
I fixed it
Gint
post Nov 15 2008, 07:50 PM
Post #24
Mike Ginter
QUOTE(Ferg @ Nov 14 2008, 08:02 PM) *
QUOTE(Gint @ Nov 14 2008, 07:56 PM) *
QUOTE(Ferg @ Nov 14 2008, 07:46 PM) *
I'm not trying to be a downer, but I speak from some experiance, as I've had a few 914's...
220 as a high point in your climate and highway driving is very optomistic without a second cooler, and impossible in the summer.
I'm hoping you find blockage (check your warm up flaps too) but the temps you are seeing are exactly what I have seen with all my 2.0's before a aux cooler.
Ferg
Bah! Hot-schmot!
My /4 has no temp gauge of any kind. I borrowed Ferg's Mainley dipstick thermo once. Saw 230-240. "That's a little high." Pulled that sucker out and gave it back to Ferg. Twisted the key and dumped the clutch and throttle and never looked back. (IMG:style_emoticons/default/driving.gif)
That was a year or so ago (maybe more?). When if it breaks I'll fix it.
Drive it like you stole it!
(IMG:style_emoticons/default/poke.gif) spend a week and drive up I70 and get back to me (IMG:style_emoticons/default/laugh.gif)
Your results may vary. (IMG:style_emoticons/default/popcorn[1].gif)
Ferg
BTDT Went down to AR last year and back. No sweat.
jc914
post Nov 15 2008, 07:55 PM
Post #25
I found great information on this post and it has picture of all the temp gauges with numbers so you can correlate with your gauge that has no numbers ( on my post above my observations are the same as what is on the diagram) (IMG:style_emoticons/default/biggrin.gif)
http://www.914world.com/bbs2/index.php?sho...20oil&st=20
This was my personal observation with the dip stick.
For those of you that have a temp gauge with the big red zone this is what I used on the stock gauge to correlate to the dip stick gauge. When the top of the needle passed the top Tip left of the T (on the temp word) i had 220 from the dip stick. When the needle got to almost the tip of the end of the T i had 250 on the dip stick.
According to this diagram my temp gauge is working correctly, (IMG:style_emoticons/default/smilie_pokal.gif) STILL 250 Is to HOT
(IMG:http://i176.photobucket.com/albums/w177/JCD404/oilgaugepic.jpg)
Jaybird
post Nov 15 2008, 09:04 PM
Post #26
Ferg: I presume the oil temp gauge you refer to is what is on my (your old) 914? What temp is "ok"; ie; do I check it running? Or as soon as I shut it off? (IMG:style_emoticons/default/blink.gif) The interior gauge is not working at all. Thanks, Jay
Ferg
post Nov 15 2008, 09:30 PM
Post #27
QUOTE(Jaybird @ Nov 15 2008, 08:04 PM) *
Jay, no worries, I installed the cooler on that car right off the bat when I bought it. Never had a problem after.
That guage was working before it left me? What is it doing, if it's pegging when turned on, you have a ground issue.
Ferg
Gint
post Nov 15 2008, 09:37 PM
Post #28
Mike Ginter
Sorry about the thread hijack BTW! (IMG:style_emoticons/default/hijacked.gif) You're getting/posting some good info here.
jc914
post Nov 15 2008, 10:43 PM
Post #29
Gint thread hijack NO way more info the better. Look what they are selling on ebay. A 914 BILLET OIL SUMP PLATE
they claim that it " The extra surface area that is gained with our unique fin design, works like a heat sink. That helps to keep your engine oil cooler"
http://cgi.ebay.com/ebaymotors/PORSCHE-912...sQ5fAccessories
any one thinks this might work. (IMG:style_emoticons/default/huh.gif) (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/screwy.gif) (IMG:style_emoticons/default/icon14.gif) (IMG:style_emoticons/default/idea.gif)
jc914
post Nov 16 2008, 12:34 PM
Post #30
I just did my oil change and cleaned the oil sump screen, just look at the old oil and the new oil the picture says it all . I also cleaned the oil cooler with brake cleaner and the surounding areas that had old oil residue. I did notice that one of my heat exchanger the driver side had a gap on the connection and was releasing hot air in an upward direction i fixed that. The PO disconnected the thermostat wire. So if i am correct when it fail it is in the open setting. today in MIAMI is a cool 70 degrees later i will run the car again and see if the temp has dropped.
(IMG:http://i176.photobucket.com/albums/w177/JCD404/IMG_2936.jpg)
jc914
post Nov 16 2008, 03:12 PM
Post #31
OK I just got back from an 1 1/2 run in the car in traffic and highway drove her hard in and out durning my drive the temp out side was 68-70. At the end the car still marked a very steady 250 degrees. I guess my car just runs at that temp. On my original post I ran the car with 80 degrees outside temp and the oil temp was also steady at 250. In all at least I know that at 80 or 68-70 degrees outside temp my car runs at a steady 250 degrees. So If i am correct my car is cooling b/c at 80outside temp the oil is the same as 68 degrees outside temp (IMG:style_emoticons/default/biggrin.gif). The only thing else that i want to do before i consider extra oil cooler is giving a tune up (wires, spark plugs, rotor distributer cap, and valve adjustments)
Ferg
post Nov 16 2008, 08:05 PM
Post #32
Flaps are supposed to fail in the "safe" mode, but it's always best to verify... grab the tab where the wire connects and move them by hand and make sure they are not binding or stuck.
Do you have emissions in FL? If so did you pass easy and what were your readouts.
Ferg
southernmost914
post Nov 16 2008, 08:36 PM
Post #33
KEY WEST/HAVANA Tunnel Authority
No emissions in FL. (IMG:style_emoticons/default/biggrin.gif) Timeing and valve adjustment has allot to do with temperatures. In this climate 220-250f oil temp seems to be normal to high. Get it tuned and see what you get. (IMG:style_emoticons/default/bye1.gif)
Steve
jc914
post Nov 16 2008, 09:28 PM
Post #34
thanks Steve i plan to have her tuned hopefully next month. I just got back from a long drive to south beach i keep checking the temp it got it at 240 but the outside temp went down to 60.
Freg I tried looking for the tab but i did not see it I will try again this week. I did see the wheel the cable is to go through will the tab be hidden above that
Ferg
post Nov 17 2008, 10:25 AM
Post #35
Here you go...
http://www.ratwell.com/technical/Thermostats.html
Ferg
jc914
post Nov 17 2008, 11:48 AM
Post #36
Thank ferg I checked they are fully open. I guess Steve is right for this climate that I am in. Steve what temps to you get on your oil and or CHT Gauge i would like the information.
Ferg. If i was to get an oil cooler can I use any aftermarket brand or does some one have a kit for sale. Thanks
Ferg
post Nov 17 2008, 12:20 PM
Post #37
Nobody really has a kit...
Depends on where you want to put it as well. Best spot is up front no doubt, but I've had "OK" success under the rear trunk above the pass side drive shaft. (was done to keep front end and overall of car "stock") it had about a 20 or so degree reduction, at max.
ut now that I have a proper front cooler on my 911 it works so well, I will go up front on the next 914 I own.
I pieced mine together with AN fittings and a mocal cooler from here http://www.batinc.net/mocal.htm They have everything, including the sandwich plate type thermostat.
southernmost914
post Nov 17 2008, 12:36 PM
Post #38
QUOTE(jc914 @ Nov 17 2008, 12:48 PM) *
I would say 180-220F oil temp since I went to a mallory dizzy and a correct tune. CHT I have seen 375F in fifth 65mph with a 30knot headwind and A/C on. That was my ultimate test. Normaly in the summer 320-350 CHT. (IMG:style_emoticons/default/bye1.gif)
Steve
jc914
post Nov 17 2008, 01:39 PM
Post #39
thanks for the replies Ferg and Steve. I hope by Dec/Jan i will have my heat issue taken care off. Once again thanks for all the help. Got to save some money for the Dakota digital, and the full tune up.
I know this might be stupid but whats a mallory dizzy. I am new to all this ( the mechanical side )
southernmost914
post Nov 17 2008, 07:27 PM
Post #40
QUOTE(jc914 @ Nov 17 2008, 02:39 PM) *
Mallory unilite distributor for carbed cars. FYI today at ambient temps of 71F= oil temp was 180F,CHT 248F. Good Luck (IMG:style_emoticons/default/bye1.gif)
Steve
- Lo-Fi Version Time is now: 2nd April 2026 - 08:33 AM
