2 Pages V < 1 2
> Manual Fuel pump switch, and tips
ONTHEGRIND
post Nov 23 2008, 09:36 AM
Post #21
THank you for the replies I am up at 7:30 gonna have some tea and read threw this, I have DMM but it is kind of a cheapo I am gonna buysomething a little better..
My Cobra is in the Garage taking up most of myspace so I have the NINEFOURTEEN. In front of the garage and I is super foggy out in Californina once it clears I will start my testing
THanks again for the info..
DAVE
Dave_Darling
post Nov 23 2008, 06:44 PM
Post #22
914 Idiot
Which fuel injection system does your car have? The 1.8's L-jetronic FI actually has a "dual relay" hanging off of the battery tray that takes over the function of those two relays from the relay board.
If your car is D-jet (1.7, 2.0 original EFI) then Brad Anders has just about everything known about the FI on his website: http://members.rennlist.com/pbanders . He even has flowcharts for troubleshooting the fuel pump control system...
--DD
ONTHEGRIND
post Nov 23 2008, 06:52 PM
Post #23
I went on pbanders page started to work from the last page and worked from there.. Now I got the pump on but before I put fuel and take it off the stands can you tell me if I have the pump hoses on correct ? give me a sec I will post some pics..
ONTHEGRIND
post Nov 23 2008, 07:00 PM
Post #24
As you can see I moved the pump and added some new lines to old linevs where shorter and one cracked like a stale piece of bread so I put on some longer lines I had orginized and hung neatly but pulled them down for a better pic.
(IMG:http://img.photobucket.com/albums/v236/xr8ted/100_2024.jpg)
(IMG:http://img.photobucket.com/albums/v236/xr8ted/100_2025.jpg)
(IMG:http://img.photobucket.com/albums/v236/xr8ted/100_2026.jpg)
ONTHEGRIND
post Nov 23 2008, 07:29 PM
Post #25
In the book it shows it going the other way ? top hose going to the y connector and the bottom goes to the fuel filter middle goes to the clear fuel tubing ?
ONTHEGRIND
post Nov 23 2008, 07:43 PM
Post #26
Swaped the lines droped the car put 2 gallons of fuel and it fired I am gonna clean up and go fuel it up..
markb
post Nov 23 2008, 10:38 PM
Post #27
914less :(
If the fuel lines were as bad as you say, you need to pull the tank & replace the lines there.
Dave_Darling
post Nov 24 2008, 12:40 AM
Post #28
914 Idiot
The filter you have on there is a cheap low-pressure one. Chances are decent that it will break up and get into the pump...
If you look carefully, there are tabs with letters next to each port on the pump. "S" stands for (the German word for) Suction, and is hooked up to the fuel filter and then the tank. "D" stands for Druck, German for "Pressure". That gets hooked to the driver's side fuel rail. "R" stands for (the German word for) "Return", and the hose goes to the "Y" fitting that goes to both the return port on the tank, and the fuel pressure regulator in the engine bay.
--DD
ONTHEGRIND
post Nov 24 2008, 12:55 AM
Post #29
QUOTE(Dave_Darling @ Nov 23 2008, 10:40 PM) *
--DD
Thanks for all the reply's ..
CAR is now moving under its own power.
ONTHEGRIND
post Dec 1 2008, 07:38 PM
Post #30
Car Runs but seems to have still have a problem..
Car runs and drives but the car dies out and the fuel pump shuts off I go to turn the key no sound from the fuel pump.. Pop the engine lid pull out the white fuse check it snap it back in pump goes back on.... get to my destination on the way back it does it again creep to the side of 101 and pull the fuse pop it back in and pump goes back on.. Any Ideas
Cap'n Krusty
post Dec 1 2008, 07:42 PM
Post #31
Cap'n Krusty
QUOTE(ONTHEGRIND @ Dec 1 2008, 05:38 PM) *
Clean the contacts for the fuse. BTW, the fuse should be red, not white. White is 8 amps, not enough for the pump circuit. The Cap'n
ONTHEGRIND
post Dec 1 2008, 07:59 PM
Post #32
QUOTE(Cap'n Krusty @ Dec 1 2008, 05:42 PM) *
Good to know.. I just bought all new fuses and some extras I will toss a red in there... As this is a new car to me I have been going over all the electrical grounds hitting everything with wd'40
I am going to snap in a new fuse and take it for a spin
ONTHEGRIND
post Dec 1 2008, 08:10 PM
Post #33
Swapped the fuse to red firred it up made it ten feet and it did it again.. shut off pulled the fuse opped back in and it fired i pulled the board and cleaned it when I put in the new pump so those connections are fine..
ONTHEGRIND
post Dec 2 2008, 10:19 AM
Post #34
Any guess ?
Spoke
post Dec 2 2008, 11:03 AM
Post #35
Jerry
You mentioned wd40 everything. For electrical items with some oxidation, tarnish, and dirt, you need to very gently clean contacts off with fine sandpaper like 400 grit, then spray off with contact cleaner. You can get contact cleaner at Radio Shack/Fry's or at your FLAPS. Just make sure it's contact cleaner with no residue. Some have lubricants in them; you don't want lubricants.
When you're done with the contacts, they should be nice and shiny.
ONTHEGRIND
post Dec 2 2008, 11:19 AM
Post #36
Spoke I also have heen doing that the reason for the wd-40 is to keep the moisture off..
I am gonna post a video of the car give me a sec..
ONTHEGRIND
post Dec 2 2008, 11:31 AM
Post #37
http://smg.photobucket.com/albums/v236/xr8...nt=100_2035.flv
http://smg.photobucket.com/albums/v236/xr8...nt=100_2036.flv
2 Pages V < 1 2
- Lo-Fi Version Time is now: 2nd April 2026 - 01:53 PM
