| blitZ |
Dec 17 2008, 01:45 PM
Beer please... ![]() ![]() ![]() ![]() Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
Just get some Euro front turn signals and put some bright LED lights in the white section. I use these as my daytime running lights so the car is more visible.
| johannes |
Dec 17 2008, 01:53 PM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
In the sixties the "flush" headlights were forbidden. The only light that was allowed in the USA was the 7' round lamp.
So if you wanted to design a low car, you had not a lot of alternatives. - Frog eyes like the 911 - Pop up like the 914 ... Popup headlights are now forbidden on new cars because of the pedestrian protection regulation. It's a shame ! Popup headlamps are soooo coool ... http://www.youtube.com/watch?v=1-dSISRUDq0 (IMG:style_emoticons/default/wink.gif) |
| ericread |
Dec 17 2008, 01:55 PM
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
QUOTE The worst thing about the 914 was the air coming off the roof. The 911 had much cleaner air flow on the rear end. Paul, I'm confused. I would have though "spoiling" the airflow over the rear end would be the best thing about a 914? (IMG:style_emoticons/default/confused24.gif) By putting a duck tail "spoiler" on the back of my 911 it reduced the cleanliness by -113lbs. (of lift) per corner. I know you're confused, but the drop off of the 914 roof line is a bad thing. I respectfully disagree.it breaks up the drag surface..A golf ball flys farther with dimples then with out..thats a fact..we need someone to find it in a book and post it You are correct. Dimples help a golf ball fly longer. But cut a chunk out of a golf ball and how does it fly then???? Not so good. The same with our cars. A slight dimpling or air disruption off the roof would be a good thing. The huge cavity behind the rear window is not so good. Eric Read |
| Todd Enlund |
Dec 17 2008, 02:21 PM
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,252 Joined: 24-August 07 From: Reed (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest |
I respectfully disagree.it breaks up the drag surface..A golf ball flys farther with dimples then with out..thats a fact..we need someone to find it in a book and post it This is true, but the principle is different. The dimples on the golf ball cause boundary layer turbulence, which increases the Reynolds number, which minimizes flow separation, which minimizes base drag. |
| roadster fan |
Dec 17 2008, 02:33 PM
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
This is true, but the principle is different. The dimples on the golf ball cause boundary layer turbulence, which increases the Reynolds number, which minimizes flow separation, which minimizes base drag. (IMG:style_emoticons/default/blink.gif) uh..............yeah, what he said! (IMG:style_emoticons/default/laugh.gif) |
| biggy72 |
Dec 17 2008, 02:46 PM
Member ![]() ![]() Group: Members Posts: 209 Joined: 14-January 06 From: Olympia, WA Member No.: 5,418 Region Association: Pacific Northwest |
I respectfully disagree.it breaks up the drag surface..A golf ball flys farther with dimples then with out..thats a fact..we need someone to find it in a book and post it This is true, but the principle is different. The dimples on the golf ball cause boundary layer turbulence, which increases the Reynolds number, which minimizes flow separation, which minimizes base drag. I was thinking about this last night, but why are bonneville cars as smooth as possible? I would really like to build one at some point and I have been considering things I could do to be different to go faster. I was thinking about dimpling some of the car to do this especially in areas where I wanted the boundary layer to be as small as possible. You never see it done, but it seems like it should work in theory. |
| Solo914 |
Dec 17 2008, 02:57 PM
Member ![]() ![]() Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None |
I respectfully disagree.it breaks up the drag surface..A golf ball flys farther with dimples then with out..thats a fact..we need someone to find it in a book and post it This is true, but the principle is different. The dimples on the golf ball cause boundary layer turbulence, which increases the Reynolds number, which minimizes flow separation, which minimizes base drag. I was thinking about this last night, but why are bonneville cars as smooth as possible? I would really like to build one at some point and I have been considering things I could do to be different to go faster. I was thinking about dimpling some of the car to do this especially in areas where I wanted the boundary layer to be as small as possible. You never see it done, but it seems like it should work in theory. Bonneville cars are not a round ball. Its the same reason they don't use dimple technology on F1 cars, they are able to make the drag coefficient lower by changing the shape with a golf ball you are kind of stuck (IMG:style_emoticons/default/wink.gif) Now, you could do some interesting things on existing cars where you can't change their design. Say, dimple the leading front of a volkswagen Beetle or Audi tt etc. Kyle |
| Todd Enlund |
Dec 17 2008, 03:03 PM
I was thinking about this last night, but why are bonneville cars as smooth as possible? I would really like to build one at some point and I have been considering things I could do to be different to go faster. I was thinking about dimpling some of the car to do this especially in areas where I wanted the boundary layer to be as small as possible. You never see it done, but it seems like it should work in theory. There are two ways to make an object faster... increase thrust or reduce drag. Thrust applied to a golf ball, for a given golfer, is fairly constant (if the golfer is any good). A golf ball MUST be round(ish). Round is not a very streamlined shape. Dimpling reduces the drag on a high drag object. Drag increases dramatically when the boundary layer separates, and the dimples delay the separation... a Bonneville car can be VERY streamlined, almost to the point of no boundary layer separation at all, so dimples would increase the drag. Laminar flow, baby. |
| Solo914 |
Dec 17 2008, 03:04 PM
| JeffBowlsby |
Dec 17 2008, 03:20 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,222 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Attached thumbnail(s) |
| biggy72 |
Dec 17 2008, 03:30 PM
I found another picture of a red 914 at bonneville too awhile back, but I don't know anything about either of the cars. Does anyone have any info about them?
And thanks for that engtips article. Pretty good stuff to consider. |
| bandjoey |
Dec 17 2008, 03:33 PM
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,935 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
There was a show on Myth Busters a year ago about Pickup owners driving with their tail gates down, thinking it would reduce drag and increase gas mileage. Results of the tests showed the tail gate up was better because...my memory being almost gone...or so my wife says...airflow off the cab was dumping into the bed of the truck with the gate up, causing a swirling effect that enabled additional air to flow smoothly off the top of the air bubble, and over the tailgate. Actual results showed better gas mileage and lower drag. Could this same effect hapen on the 914? Go figure. Might find that old show on utube. Bill (IMG:style_emoticons/default/laugh.gif)
| Spoke |
Dec 17 2008, 03:54 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,370 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
No dimples on this vehicle & lots of thrust.
| RiqueMar |
Dec 17 2008, 04:09 PM
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,264 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California
Off topic from Aerodynamics, but what about theft or vandalism?
| orthobiz |
Dec 17 2008, 04:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,762 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest
I read somewere: AK, AL, AR, AZ, DC, DE, FL, GA, HI, ID, IN, KS, LA, MD, MI, ND, NH, NJ, NV, SC, TX, WA, WI - Height of headlamps must be at least 24 inches from the ground CA, CT, ME, MT, OK - Height of headlamps must be at least 22 inches from the ground NM - Height of headlamps must be at least 20 inches from the ground Taillights AL, AR, CO, DE, GA, IA, ID, IN, MD, NH, NJ, NM, RI, SC, WI - Taillights must be at least 20 inches off the ground AZ, CT, DC, KS, MT, NV, OK, SD, TX, WA - Taillights must be at least 15 inches off the ground CA - Taillights for post-'69 vehicles must be at a height of at least 15 inches Wow! For a guy who read it somewhere, you have the BEST information retention ever!!!! Paul |
| biggy72 |
Dec 17 2008, 04:23 PM
| Eric_Shea |
Dec 17 2008, 04:36 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE I know you're confused, but the drop off of the 914 roof line is a bad thing. Grumpy today aren't we? Seriously, wouldn't disrupting the airflow over that long, flat surface like our rear lid help reduce lift? I would think it would make it so we wouldn't need a big goofy wings on our cars! (IMG:style_emoticons/default/poke.gif) (serves ya right for being mean to me) (IMG:style_emoticons/default/tongue.gif) (IMG:style_emoticons/default/biggrin.gif) |
| URY914 |
Dec 17 2008, 04:50 PM
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 132,067 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
E, I wasn't being mean, just being a smart ass. Sorry.
Look at the shape of a rain drop. Now turn it on it's side. Does it look more like a 911 or a 914? |
| Eric_Shea |
Dec 17 2008, 05:02 PM
I know... I'm just (IMG:style_emoticons/default/poke.gif) ing at ya.
The problem I had with my 911 was, it got all squirelly on the back straight at Las Vegas as I was hauling ass coming into the infield 90 degree lefty. My duck tail has made some serious differences in the way that car handles. I did a bit of reading on it (hence the 113lb. reduced lift figure) and it all made sense to "spoil" that airflow, which we all know is why they call them spoilers. I get the teardrop thing, I also get the airfoil thing. My 911 looks more like an airplane wing than my 914 as well... I'd love to learn more because I honestly thought the 914 shape would perform better at speed with that feature. |
| 6freak |
Dec 17 2008, 05:11 PM
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:17 PM |
