> bolt help
mein_tag
post Mar 9 2009, 01:14 PM
does anyone know the specs on the bolts for the mounting bar at the front of the engine. I need it for the ones that go to the bar to the mounts.
thanks Levi
Wilhelm
post Mar 9 2009, 03:25 PM
Is this what your looking for?
http://dcauto.gotdns.com/illustration/inde...lass=illo_title
mein_tag
post Mar 9 2009, 04:16 PM
yes i need part number 16, 18 and 19. they don't give any specs on them so i'm might have to buy one side then go down to Ace or something and match up the other side. " i would like to get it done without dropping a 10 dollar bill on bolts tho -.-"
highways
post Mar 9 2009, 04:20 PM
I can take some measurements tonight, I just pulled those out.
MrKona
post Mar 9 2009, 04:44 PM
Per the Porsche parts catalog...
#16, part # N 014 736 1 (Hex Bolt, M10 x 90)
#18, part # 900 025 008 02 (Washer, 10,5)
#19, part # N 021 195 1 (Nut, M10, self locking)
McMark
post Mar 9 2009, 04:49 PM
914 Freak!
Which means you need an M10 bolt which is 90mm long. Plus a washer and a nylock nut. Also, be sure to mounts them with the threads up (i.e. insert them from the bottom, going up). If you mount them the other way, the threads hang down too far and can hang up on speed bumps, etc.
mein_tag
post Mar 9 2009, 06:10 PM
is that standard thread?
MrKona
post Mar 9 2009, 06:34 PM
QUOTE(mein_tag @ Mar 9 2009, 05:10 PM) *
It's a metric thread. If your local Ace Hardware is anything like mine, they should have a nice selection of metric hardware...
azbill
post Mar 9 2009, 06:54 PM
Go to Copperstate Bolt. They are cheaper then Ace Hardware. Ace may or may not have the metric sizes.
Azbill
- Lo-Fi Version Time is now: 2nd April 2026 - 01:53 PM
