> Replacing exhaust seals, any tips or tricks
zeezee
post Apr 19 2009, 02:20 PM
I found two badly deformed exhaust seals when I pulled the pipes off the manifolds.
Any tips or tricks to making sure the seals and pipes seat correctly?
I'm considering a small drop of glue/sealent to stick the copper seal and pipes together properly - hoping this helps with proper alignment when I bolt the pipes into the manifold.
Al Meredith
post Apr 19 2009, 05:57 PM
Always file the part of the exhaust that contacts the copper gasket. You want a smooth flat surface to press against the copper. I usually put some muffler cement on the copper to help hold it up in the head.
solex
post Apr 19 2009, 06:12 PM
I anneal the gaskets prior to fitting/installation and also use copper gasket cement to hold them in place.
3d914
post Apr 19 2009, 07:20 PM
I second solex!
zeezee
post Apr 20 2009, 02:03 PM
Will do - Thanks.
Searching for "anneal" found some good threads for this that didn't turn up in my other "exhaust" oriented searches.
- http://www.914world.com/bbs2/index.php?showtopic=82732
- http://www.ratwell.com/technical/Exhaust.html
Sorry for the repetitive post.
Cap'n Krusty
post Apr 20 2009, 02:16 PM
Cap'n Krusty
If you're gonna file the pipes, you MUST file them together, not one port at a time. The Cap'n
- Lo-Fi Version Time is now: 2nd April 2026 - 09:36 AM
