Carb Airbox, Input appreciated... |
stepuptotheMike |
May 16 2009, 07:04 AM
medium pimpin Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States |
So I have Weber 44s on my car. When the installation was done by a previous, previous owner, there were some aspects that were less than detail oriented. Items such as the following:
-Fuel Vapor lines from the front (car is a 73) just dump into the engine compartment. Assuming this contributes to fuel smell in car. -Crank vent is basically a hose with a tiny air filter on it, suspended over the engine case... this leads to oil film all over. - No head breather ports. Heads were never drilled/tapped for them, but I don't think my venting is adequate and it's causing oil leaks. - Carbs in general are just loud. I want to hear some throat when I get on it, but don't need it all the time. So in reading through various threads (especially the ones on the breather setups folks have posted recently) I started thinking about how I could solve all of these problems in 1. Creating a legal setup that would pull the fuel vapors and case/vents into the carb intakes..... and quieting things down a little bit. So I thought about creating a single airbox that would install over the combined carb setup. Ideally, I would think plastic would be the medium of choice, but I have no clue where I would start.... so then I started thinking about fiberglass. Granted, I've never really built anything with glass, but it's fairly cheap and if it doesn't work I figure I'm only out my time and a few bucks. Plus I learn something in the process. I figure I could use techniques similar to those that the custom speaker box guys use to form shapes and build the box. This would just be thinner. So I came up with the following crude drawing to illustrate kind of what I'm talking about. I would appreciate thoughts on this concept. Shoot holes in it as you see fit. Been down this road before? Know somebody that tried something similar? Thanks in advance.... Mike |
aircooledtechguy |
May 16 2009, 09:32 AM
The Aircooledtech Guy Group: Members Posts: 1,966 Joined: 8-November 08 From: Anacortes, WA Member No.: 9,730 Region Association: Pacific Northwest |
BAS in Germany make this exact thing. I've even seen them in carbon fiber with dual air snouts before (IMG:style_emoticons/default/drooley.gif) A set-up like this would quiet down the noise and keep rain out too. What about just using 912 filter assemblies from a set of Solex PII's??
Attached image(s) |
aircooledtechguy |
May 16 2009, 09:39 AM
Here's the stock 912 filter assemblies I was talking about. Probably cheaper and a true Porsche product w/ factory filters. . . Just an idea (IMG:style_emoticons/default/beerchug.gif)
Attached image(s) |
r_towle |
May 16 2009, 10:07 AM
Custom Member Group: Members Posts: 24,591 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I have thought about this also.
I have looked at the German ones...quite a few are really nice, but very expensive. The one that got me thinking is attached. Here are the basic parts that I would use. CB performance blow through turbo covers for the webers. Get two. Super beetle airbox...that is what is pictured (could just be any beetle) Then get silocone hoses from a boat supply place.. Rich Attached image(s) |
azbill |
May 16 2009, 10:49 AM
Member Group: Members Posts: 455 Joined: 26-July 04 From: Glendale, Az Member No.: 2,403 Region Association: Southwest Region |
I got sick of hearing air going into the throttle bodies - to much noise for nothing. I came up with "Quite Air Induction" I will be selling the system in teh near future. Here is a picture of the proto-type.
Bill Shaffer Attached image(s) |
type2man |
May 16 2009, 12:49 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Wow, that looks awesome. I am guessing part of the kit would also be a bellcrank linkage. What's the estimated price on it?
E-Man |
May 16 2009, 12:51 PM
Member Group: Members Posts: 158 Joined: 4-March 03 From: S. Windsor, CT Member No.: 390 |
That looks good Bill. Any way to route it to get colder air?
I was thinking of boxing in the vents on either side of the engine lid, making rain hats for the filters, and put drain lines on the boxes. -Mike |
tomeric914 |
May 16 2009, 01:17 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
CB performance blow through turbo covers for the webers. Those are 2" diameter connections IIRC which are ok if you are pressurizing with a turbo, but are flat out restrictive for airflow. I had some made with 3" connections for my T4 setup on my Baja using a centrifugal air filter. It was quieter for certain but clearly restrictive probably because of the Donaldson air cleaner I was using. I'm tempted to use them on the 914 now. (IMG:http://farm3.static.flickr.com/2225/3536056115_feca4a26f2.jpg) (IMG:http://farm3.static.flickr.com/2441/3536056013_f6042d8b0a.jpg) |
azbill |
May 16 2009, 01:32 PM
I am using 3" tubing and have found that the Quite Air is somewhat restricted. When I get the production model done I will dyno the car again and state what the difference. The price has not been determined.
Yes it is designed to complement the Sidewinder throttle control. But, I am selling them as separate units. Bill Shaffer |
r_towle |
Jun 12 2009, 11:43 AM
I am using 3" tubing and have found that the Quite Air is somewhat restricted. When I get the production model done I will dyno the car again and state what the difference. The price has not been determined. Yes it is designed to complement the Sidewinder throttle control. But, I am selling them as separate units. Bill Shaffer Back of the napkin math makes me think about the tubing size. A single 40mm barrel on a dual weber is close to the 2 inch tubing size of 50mm So it makes me think that for a system to work properly and have no restriction, you would need at least a 3 inch intak tube from each carb (80mm is 3.14 inches) and then at your merge portion you would need 6 inches. None of my math factors in the timing of each intake pulse, but I think if you step up to 3 inch tubing, you will probably be alot better off. Rich |
gothspeed |
Mar 16 2011, 11:25 AM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
BAS in Germany make this exact thing. I've even seen them in carbon fiber with dual air snouts before (IMG:style_emoticons/default/drooley.gif) A set-up like this would quiet down the noise and keep rain out too. What about just using 912 filter assemblies from a set of Solex PII's?? Does anyone know if this BAS Airbox is available here in the states? ........... or ............ does anyone make something similar? |
JmuRiz |
Mar 16 2011, 11:52 AM
914 Guru Group: Members Posts: 5,434 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Not sure, but it's damn cool!
Cap'n Krusty |
Mar 16 2011, 12:03 PM
You need only one port on the air cleaner housing for the EVAP. The other hose goes to the fan shroud. There has to be a flow through the system in order for it to work.
The Cap'n |
gothspeed |
Mar 16 2011, 12:16 PM
Not sure, but it's damn cool! Indeed!! I will try to find the BAS version ........ if I cannot find anything ....... I will probably have to make something similar to the 6 cylinder weber airbox .......... I am not a big fan of noisy intakes or exhausts ......... (IMG:style_emoticons/default/smile.gif) |
Root_Werks |
Mar 16 2011, 03:15 PM
Village Idiot Group: Members Posts: 8,338 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
The 912 units don't work. Well, they work 50%.
I purchased a set of 912 air cleaners that fit with the 914 rain tray still on. From 1967 912 I think? The pass side fit fine using an adapter plate. The drivers side ran into the firewall by about 3/4 of in inch. So I pulled them off. My solution was going back to FI. |
URY914 |
Mar 16 2011, 06:35 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,106 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I'm in the process of making a fiberglass shroud (for lack of a better term) that would connect both of my carbs and have a center section that my air scoop would sit on. It's a slow process with having to make the buck then the mold then the actual piece. The mold is in two pieces that I'll have to join together. I have to do this on each side. The center section is next and finally the scoop which will go up over the targa bar. I should wrap it up in 2012 if I hurry. (IMG:style_emoticons/default/sad.gif)
VaccaRabite |
Mar 16 2011, 07:45 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have a box of parts - namely 912 air cleaners, which I have been trying to find the time to work on to my car. I am very slow....
One of these days I'll get it done. the induction is REALLY loud. Zach |
bam914 |
Mar 16 2011, 08:26 PM
Member Group: Members Posts: 334 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
Here is my idea. Just need to lay fiber glass over it. I have already talked with someone about making a mold. But I did not think there would be much interest. If there is I can look into the cost.
URY914 |
Mar 17 2011, 06:57 AM
^^^ That looks good and is sorta like what I'm doing but mine is using seperate pieces for each carb running into a center section.
VaccaRabite |
Mar 17 2011, 07:29 AM
I'd be interested. The 912 cleaners are heavy.
BAM, where does the filter go? K&Ns on each side, or a panel filter somewhere? Zach |
Lo-Fi Version | Time is now: 15th June 2024 - 11:33 PM |
