| Van |
Oct 13 2008, 09:07 PM
Member ![]() ![]() Group: Members Posts: 199 Joined: 15-January 08 From: Hyde Park, NY Member No.: 8,571 |
I'm slowly making progress! http://www.ephotomotion.com/914engine
My pushrods are cut and I'm happy with the results. I even lapped my cylinders to the heads. (IMG:style_emoticons/default/smile.gif) |
| Jake Raby |
Oct 13 2008, 09:24 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Awesome progress! I really appreciate your detail.
I wish someone with one of my kits would do this... |
| johannes |
Oct 14 2008, 02:31 PM
Club Porsche 914 France member since 2005 ![]() ![]() ![]() ![]() Group: Members Posts: 3,092 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
Awesome progress! I really appreciate your detail. I wish someone with one of my kits would do this... Isn't your kit delivered with a DVD ? (IMG:style_emoticons/default/idea.gif) |
| Van |
Nov 16 2009, 09:28 AM
So, it's been a while... But I've gotten back on this project.
I've got the short-block built! See here: http://www.ephotomotion.com/914engine/page32.html |
| Van |
Nov 25 2009, 07:28 AM
Even more completed:
2 new pages (each with video!) Putting on piston rings, etc. Assembly to a long-block Enjoy! |
| type47 |
Nov 25 2009, 08:00 AM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Quite excellent!! I did notice 2 things that I'd like to ask about. First, I noticed that you put the oil ring on the piston after inserting the wrist pin. Is that particular to the set of pistons you used? I remember putting all the rings on the piston before connecting to the connecting rod but that was with stock motors. Second, I noticed that you didn't bring each cylinder up to TDC for that cylinder when installing the rocker arms. I thought that you didn't want valve spring pressure against the rocker arms when torquing up the arms. Just casual thoughts from a novice.
| Van |
Nov 25 2009, 08:29 AM
Quite excellent!! I did notice 2 things that I'd like to ask about. First, I noticed that you put the oil ring on the piston after inserting the wrist pin. Is that particular to the set of pistons you used? I remember putting all the rings on the piston before connecting to the connecting rod but that was with stock motors. Second, I noticed that you didn't bring each cylinder up to TDC for that cylinder when installing the rocker arms. I thought that you didn't want valve spring pressure against the rocker arms when torquing up the arms. Just casual thoughts from a novice. On those particular pistons, the oil ring groove intersects with the wrist pin hole. I had no choice but to put the oil rings on after the wrist pins. As for the rockers, interesting point - I didn't think about that. Those heads have a M8 stud - not the usual M7 stud. So I torqued them to 14 ft/lbs. I still have to adjust the rockers, so when each one is at the compression stroke, I'll double check my torque. |
| Cevan |
Nov 25 2009, 07:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 |
Excellent!! (IMG:style_emoticons/default/beerchug.gif) I'll be doing that this winter. I love the videos.
Where did you get the rods? I'll do a video for cleaning the case. (IMG:style_emoticons/default/laugh.gif) |
| Van |
Dec 15 2009, 01:50 PM
Where did you get the rods? I believe I located them from the Samba website. Jake also stock them. For those interested, I've added 3 more pages to my website: http://www.ephotomotion.com/914engine The highlight of my updates: another video - putting on the engine tin http://www.youtube.com/watch?v=QeACshQJcHc |
| MDG |
Dec 15 2009, 02:39 PM
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
Great job! (IMG:style_emoticons/default/smilie_pokal.gif) Must be a satisfying feeling to be getting so close.
Also, for the first minute of that vid I was stupified that you had discovered how to clone yourself!?! Holy Crap, I thought, that is amazing! Then I read how your dad was visiting and you put him to work . . . ah well, it was pretty cool for awhile. Good luck with the home stretch. mike |
| enikolayev |
Jan 27 2010, 02:04 AM
Member ![]() ![]() Group: Members Posts: 50 Joined: 18-November 07 From: Gulfport, MS Member No.: 8,349 Region Association: South East States |
Most detailed "how to" i have ever seen, thanks.
I don't think you mentioned your bearing clearances though. I'm in the process of rebuilding a 1.8 and have no idea what the spec should be. |
| Van |
Jan 27 2010, 03:32 PM
Most detailed "how to" i have ever seen, thanks. I don't think you mentioned your bearing clearances though. I'm in the process of rebuilding a 1.8 and have no idea what the spec should be. I did not use plasti-gauge or anything. But I did measure the thickness of the old and new bearings with a dial caliper, and they were essentially identical. And, after assembling each component, the "feel" of the play and drag "felt" about right. Hope that helps! |
| tat2dphreak |
Jan 27 2010, 03:41 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
great info! thanks for taking the time to do this
| Brent |
Jan 28 2010, 03:14 PM
Every month is Oktober ![]() ![]() ![]() Group: Members Posts: 1,360 Joined: 16-December 04 From: North San Jose Member No.: 3,291 Region Association: Northern California |
This is fantastic!
| Van |
Mar 15 2010, 06:36 AM
I had a really great day yesterday... Started the engine for the first time! She fired right up!
More details and video here: http://www.ephotomotion.com/914engine/page44.html (And, for those too lazy to click...) https://www.youtube.com/watch?v=TQRiGPX2pi0 |
| Phoenix914 |
Mar 15 2010, 07:49 AM
Member ![]() ![]() Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States
Fantastic! Your test stand is great. Good job, Van, and thanks for documenting your project for us.
(IMG:style_emoticons/default/beerchug.gif) |
| MDG |
Mar 15 2010, 10:38 AM
That's got to be satisfying (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) Congratulations. I've been following your build on this for some time - great stuff.
mike |
| jeffdon |
Mar 15 2010, 11:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Congrats!
Fired mine on the stand for the first time on March 1. Now its time to get the engine bay prepped and painted, and the motor back in! Your website has been an inspiration and wealth of info. |
| tat2dphreak |
Mar 15 2010, 11:45 AM
grats! sounds great!! thanks again for the great documentation of the build
| Cevan |
Mar 15 2010, 11:51 AM
Great job!! (IMG:style_emoticons/default/beerchug.gif)
Question: Are you using a rotary style pump? If so, did you have any issues with it sucking gas out of the gas can? |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:34 AM |
