| ericread |
Feb 18 2010, 08:41 AM
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Eric, the switch is designed with hysteresis (backlash) so that contact C is shorted either to post A OR to post B, but never to both simultaneously. In this way, the ECU can detect an opening throttle vs. a closing throttle. But here is the problem with your TPS -- you've got a 2.0 liter board mounted in a 1.7 liter sensor plate. The 1.7 liter throttle rotates the opposite direction, so your mismatched sensor will never detect idle. That would make sense. Thanks! Eric |
| hushpuppy |
Sep 21 2018, 06:57 PM
Newbie ![]() Group: Members Posts: 21 Joined: 2-September 05 From: Embudo, NM Member No.: 4,730 |
dave,
do you still have any of the boards left 75 2.0 thanks, |
| jagalyn |
Sep 26 2018, 08:17 PM
True Patina ![]() ![]() Group: Members Posts: 414 Joined: 31-January 06 From: Scandia, MN Member No.: 5,503 Region Association: None
dave, do you still have any of the boards left 75 2.0 thanks, https://900designs.zoeysite.com/index.php/c...n-sensor-board/ |
| worn |
Sep 27 2018, 01:28 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
Isnt that gold? Could gold leafbe applied tofix the groove? Even silver solder might work? Rich Good idea, but gold leaf is generally applied with some varnish as glue. Conduction might be a problem. True silver solder melts at a temp that would vaporize the board. Plating is certainly an option as long as you hav3 a thin film of metal to go on. I have used cars well products a lot and they offer gold and silver kits. Hmmm. Whoops. Thought they we’re gone because I didn’t check the dates of the posts. |
| Tbrown4x4 |
Sep 27 2018, 02:44 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 708 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None
914Rubber has the boards in stock.
Oops. I didn't see jagalyn's link. |
| ChrisFoley |
Sep 27 2018, 06:37 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
dave, do you still have any of the boards left 75 2.0 thanks, https://900designs.zoeysite.com/index.php/c...n-sensor-board/ So why does the part listing for a 2.0L TPS board have a description for a 1.7L car? |
| jagalyn |
Sep 27 2018, 07:14 AM
| Mikey914 |
Sep 29 2018, 10:31 PM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,772 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
dave, do you still have any of the boards left 75 2.0 thanks, https://900designs.zoeysite.com/index.php/c...n-sensor-board/ So why does the part listing for a 2.0L TPS board have a description for a 1.7L car? Because we screwed the pooch. Sorry about that. It is indeed for the 2.0. We will get that fixed. Thx Mark |
| davesprinkle |
Sep 30 2018, 01:11 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None
Lo-Fi Version | Time is now: 2nd April 2026 - 09:30 AM |
