> Motive Brake Bleeding Tool, which one do you have
rwilner
post Sep 16 2010, 06:25 PM
No Ghosts in the Machine
is it this one?
Van
post Sep 16 2010, 06:29 PM
You need the cheaper "European" one... http://www.racerpartswholesale.com/categor..._Brake_Bleeders (assuming you're using it for your 914)
rwilner
post Sep 16 2010, 06:32 PM
QUOTE(Van @ Sep 16 2010, 08:29 PM) *
I am, although i'm pretty sure my brakes are not the only thing that will be bleeding that day.
thanks!
Rotary'14
post Sep 16 2010, 06:37 PM
QUOTE(rwilner @ Sep 16 2010, 05:25 PM) *
is it this one?
I have that one,, it worked like a champ to put fluid into my dry system solo.
but,,,,
If I had to do it again I would buy these two things,,,,,
http://www.amazon.com/Mityvac-7400-Liter-F...f=pd_sim_auto_2
and
http://www.amazon.com/Mityvac-7205-Evacuat...y/dp/B000M6035O
with a little more $$ (no tax and free ship thru Amazon), you get a tool that can do more than the Motive bleeder. Just about the only drawback I can see is that this tool has a bigger foot print in the garage if space matters.
just my .02,, and I don't work at Amazon.
-Robert
Rotary'14
post Sep 16 2010, 06:44 PM
QUOTE(rwilner @ Sep 16 2010, 05:32 PM) *
thanks!
OK, that one is not quite the same as mine, mine does have a metal cap that screws on to the resevoir. I added a fitting to the hose so I can change the "bleeder" heads (Euro,USA,Jap) easier.
-Robert
budk
post Sep 16 2010, 06:51 PM
Yes! It's a Bumblebee!
You can make your own for $20... lots of instructions on line.
qa1142
Whiplash
I have one, works great (IMG:style_emoticons/default/wub.gif)
dr914@autoatlanta.com
post Sep 16 2010, 06:53 PM
we love those things! Get the one with the bmw porsche cap though, that is the one we order.
is it this one?
rwilner
post Sep 16 2010, 07:17 PM
QUOTE(dr914@autoatlanta.com @ Sep 16 2010, 08:53 PM) *
is it this one?
Dr...what's the model #?
jt914-6
post Sep 16 2010, 07:27 PM
QUOTE(budk @ Sep 16 2010, 07:51 PM) *
(IMG:style_emoticons/default/agree.gif) Made my own.....pressure sprayer, pressure gauge, 914 resevoir cap, valve stem, and hose from fix-a-flat.....
rwilner
post Sep 16 2010, 07:40 PM
QUOTE(jt914-6 @ Sep 16 2010, 09:27 PM) *
Yeah....this is tempting, but since this is my first time bleeding brakes, it's worth the extra $30 to take that variable out of the eqn.
mgphoto
post Sep 16 2010, 07:43 PM
"If there is a mistake it will find me"
I called Motive Products to make sure I would get the correct unit.
Last week I bought the unit #0100 it has the correct cap.
I believe the universal unit #1100 and the adapter #1109 will work but a bit more expensive.
SLITS
post Sep 16 2010, 08:47 PM
"This Utah shit is HARSH!"
I use a hospital aspirator vacuum unit.
zymurgist
post Sep 17 2010, 06:49 AM
"Ace" Mechanic
I use a Vacula, but then again, it was free... (IMG:style_emoticons/default/wink.gif)
Vacula
Mark Henry
post Sep 17 2010, 07:21 AM
that's what I do!
A chunk of plastic tubing, glass jar and the wife.
Cupomeat
post Sep 17 2010, 02:48 PM
missing my NY 914 in VA
QUOTE(zymurgist @ Sep 17 2010, 08:49 AM) *
Vacula
From what it says, it appears this is for (partial) vacuum only, right?
Or did I read it wrong?
Just checking as I've never been successful in suction bleeding the brakes without pulling air in around the bleeder valves. If you are successful at it, what is your secret?
swl
post Sep 17 2010, 07:50 PM
QUOTE(Mark Henry @ Sep 17 2010, 05:21 AM) *
Takes less time than mucking around with fancy stuff.
Gotta thank her after though (IMG:style_emoticons/default/grouphug.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 07:22 AM
