| moneysmarts |
Apr 6 2011, 03:50 PM
Member ![]() ![]() Group: Members Posts: 169 Joined: 2-March 04 From: Central Massachusetts Member No.: 1,745 Region Association: None
Long-time- no-post!
Hi all. Just took the car out of storage from winter, looking forward to driving. My new battery keeps draining overnight. So I tapped in-line my multimeter and started pulling fuses and relays to locate the source. When I pulled the alternator wiring harness plug from the relay board, the volts/amps dropped to zero. Bingo! But now what do I do? (IMG:style_emoticons/default/confused24.gif) Do I have a bad alternator or can I diagnose further? Thanks for the help. I'd hate to have to struggle to replace that bad boy for nothing. Steve |
| r_towle |
Apr 6 2011, 03:53 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
how far are you from Tyngsboro?
| messix |
Apr 6 2011, 03:54 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
diode in the alt is blown and is energizing the field from the battery. get a new alt.
| Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,929 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Plug the alt harnes back in and the take the volt reg out. Might just be a bad volt reg?
Those are cheap. |
| moneysmarts |
| r_towle |
Apr 6 2011, 03:55 PM
unplug just the alternator at the alternator.
It may be the reverse light switch....same part of the harness and it may be the same plug. Rich |
| moneysmarts |
Apr 6 2011, 03:59 PM
| r_towle |
Apr 6 2011, 04:01 PM
not easily...but yes you can.
Chelmsford Auto Electric is where to bring it if it needs rebuilding. Up near the tyngsboro bridge... Rich |
| moneysmarts |
Apr 6 2011, 04:07 PM
I just pulled out the voltage regulator from the relay board and my meter still shows a power drain. (IMG:style_emoticons/default/mad.gif)
So now I'll try disconnecting the alternator directly. |
| moneysmarts |
Apr 6 2011, 04:09 PM
[quote name='r_towle' date='Apr 6 2011, 02:01 PM' post='1454691']
not easily...but yes you can. How else can I do it? Snip the wires in the engine compartment, then splice them back together when I finish checking? Steve |
| r_towle |
Apr 6 2011, 04:11 PM
well, that might seem easier, but it wont be in the long run.
Jack her up and climb underneath.... Rich |
| 76-914 |
Apr 6 2011, 05:22 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
well, that might seem easier, but it wont be in the long run. Jack her up and climb underneath.... Rich (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/agree.gif) Spoken like an old pro. We can sit here and talk all day or we can climb under and do it in a few. The voice of experience is the wise teacher. |
| SLITS |
Apr 6 2011, 05:24 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
The alt harness unplugs from the relay board ............ the hot wire to the alt is on the same terminal on the starter solenoid as the feed to the starter from the battery.
| moneysmarts |
Apr 6 2011, 05:35 PM
The alt harness unplugs from the relay board ............ the hot wire to the alt is on the same terminal on the starter solenoid as the feed to the starter from the battery. Hi Ron; Are you saying I can just loosten the nut on the starter solonioid and take that hot wire off? |
| moneysmarts |
Apr 6 2011, 06:48 PM
Rather than pulling apart the sheet metal to get at the alternator, I disconnected the red hot wire that was attached to the starter solonoid (and positive battery lead).
My multimeter dropped to zero. Is this now telling me that the alt. was the parasite? And if so, should I have mine rebuilt or just source a new one? |
| messix |
Apr 6 2011, 06:51 PM
Rather than pulling apart the sheet metal to get at the alternator, I disconnected the red hot wire that was attached to the starter solonoid (and positive battery lead). My multimeter dropped to zero. Is this now telling me that the alt. was the parasite? And if so, should I have mine rebuilt or just source a new one? yes the diodes are blown and it needs to be rebuilt. [diodes are like a one way valve to electricity] |
| moneysmarts |
Apr 6 2011, 07:05 PM
[/quote] Alrighty. When I jump the car and have it running, my multimeter shows that the alternator is charging the battery, though. Would it still work that way if the diodes were shot? |
| messix |
Apr 6 2011, 07:15 PM
[quote name='moneysmarts' date='Apr 6 2011, 06:05 PM' post='1454764']
yes the diodes are blown and it needs to be rebuilt. [diodes are like a one way valve to electricity] [/quote] Alrighty. When I jump the car and have it running, my multimeter shows that the alternator is charging the battery, though. Would it still work that way if the diodes were shot? [/quote] yah, for a while, it's going to over load the ones that are still working and blow all of them. it won't be making the full rated output in current. the diodes convert the a/c that the "alternator" makes into d/c, by taking voltage at 180 phases ...... well it gets complicated to explain in text and is easier to do on a chalk board. look it up here http://en.wikipedia.org/wiki/Rectifier |
| moneysmarts |
Apr 6 2011, 07:20 PM
OK
Thanks much. I'll have to pull it out tomorrow. |
| Root_Werks |
Apr 6 2011, 08:59 PM
Troy is my hero. (IMG:style_emoticons/default/pray.gif)
Lo-Fi Version | Time is now: 2nd April 2026 - 06:27 AM |
