5 Pages V < 1 2 3 4 5 >
> HOW TO: Convert to real 5-lug in the rear using 944 CVs
matthepcat
post Jun 8 2011, 05:23 PM
Post #41
Meat Popsicle
QUOTE(PeeGreen 914 @ Jun 8 2011, 03:13 PM) *
You can use spacers on the caliper to line them up (IMG:style_emoticons/default/confused24.gif)
Maybe. I guess I feel that this is sort of "janky". Have you seen this method used for a similar application?
post Jun 8 2011, 05:29 PM
Post #42
Resident German
QUOTE(matthepcat @ Jun 8 2011, 03:06 PM) *
Update on 944 hubs.
They don't work becuase they push the brake rotor out too far. This makes the brake caliper to rotor alignment incorrect.
I knew there was a reason i didn't use the 944 hubs ... (IMG:style_emoticons/default/smile.gif)
Eric_Shea
post Jun 8 2011, 05:47 PM
Post #43
PMB Performance
Have you tried the 944 rear rotor? Its quite a bit shallower.
matthepcat
post Jun 8 2011, 05:50 PM
Post #44
Meat Popsicle
No I haven't but I assume this would require me to run a different rear brake caliper?
Matt
QUOTE(Eric_Shea @ Jun 8 2011, 04:47 PM) *
Eric_Shea
post Jun 8 2011, 05:57 PM
Post #45
PMB Performance
Why? I believe they're within 1mm in diameter.
matthepcat
post Jun 8 2011, 07:29 PM
Post #46
Meat Popsicle
QUOTE(Eric_Shea @ Jun 8 2011, 04:57 PM) *
Hmm, Thanks for the tip.
I never really payed any attention to them when I pulled the hubs off at the junk yard. I thought the rear rotors on the 944 were vented, and therefore much thicker.
I will give it a try.
Matt
Eric_Shea
post Jun 8 2011, 09:37 PM
Post #47
PMB Performance
Ahhhhh.. That, yes, they are vented. For some reason I though you were using vented with this setup.
Go with the caliper spacers... Good enough for Ferrari good enough for you (IMG:style_emoticons/default/wink.gif)
McMark
post Jun 9 2011, 12:06 AM
Post #48
914 Freak!
If caliper spacers are too janky, then pull your trailing arms, weld more material onto the caliper mounts, mill it, drill it, and tap it. Ahhhh, perfection. (IMG:style_emoticons/default/biggrin.gif)
Or maybe some red anodized billet aluminum spacers. (IMG:style_emoticons/default/laugh.gif)
Just giving you a hard time... (IMG:style_emoticons/default/poke.gif)
PRS914-6
post Jun 9 2011, 06:56 AM
Post #49
Excellence Magazine Project 914 3.6
Group: Retired Members
QUOTE(McMark @ Jun 8 2011, 11:06 PM) *
Get out the cutting torch.....there's joy in that! Then you can have any thing you want......
matthepcat
post Jun 9 2011, 08:27 AM
Post #50
Meat Popsicle
Haha! Well I think swapping hubs would be a tad easier than metal fabrication (IMG:style_emoticons/default/smile.gif)
Spacers it is.
jaxdream
post Jun 9 2011, 08:46 AM
Post #51
QUOTE(matthepcat @ Jun 9 2011, 06:27 AM) *
Spacers it is.
Matt did you measure the amount of offset the 944 hubs create ?? Just curious as to the dimensions and wondering if using 944 hubs and rotors would give similar setup specs to the other methods of modification. I went with thw SC hubcentric hub/ stub combo for the 944 cv mod and using the 911 24mm vented rotor with M rear calipers, got 5mm spacer washers from Eric Shea to get the caliper / rotor offset alingment .
Jack
matthepcat
post Jun 9 2011, 12:17 PM
Post #52
Meat Popsicle
Hey Jack,
I have not measured yet (hopefully get some time in this weekend).
If you are looking to push out your wheels for inner clearance, this would help for sure. I will take some measurements this weekend and post back.
So you are running m rear calipers in the rear? Did you lose the e-brake?
Matt
QUOTE(jaxdream @ Jun 9 2011, 07:46 AM) *
Spacers it is.
Jack
jaxdream
post Jun 9 2011, 04:12 PM
Post #53
Yes M rear calipers and converted to alternative e-brake. I modified the arms to use 944/928 e brake shoes with 944 shoe expanders. The welds and mod looks fffuuuugggly , but it will work using the 914 passenger side cable modified with the 944 ends to the shoe expander. I check and check mocking the operation of it , inside the 911 rear rotor / drum it doesn't need to expand very far. Haven't installed the cables and such yet , all bench testing . Used part of a 928 and 911 backing plated grafted together to hold shoes and spreader . Welded a 1/4 thick piece of angle for the anchor plate for the shoes . Plans ( yeah right ) are to use a 964 e-brake lever center mounted over the rear of the tunnel , on the list to do in the future and have read just about every thread / post on e-brake mods that I can find.
Jack
jimkelly
post Nov 18 2011, 07:56 AM
Post #54
Delaware USA
some cv dim info
http://blindchickenracing.com/How_to/CVJoi..._joints_101.htm
for clarification - this set up requires four 33 spline 944 cvs which are from years 1986/87. pelican has them for $78.25 each.
http://www.pelicanparts.com/catalog/shopca...l_pg1.htm#item0
cause my next car will be suby engine and suby trans and porcharu's magic flanges, i will only be needing from tsi set up for my set up. 2 911 stub axles and 2 911 hubs - along with complete bus axle assys with 100mm cvs.
Aaron Cox
post Mar 11 2012, 03:59 PM
Post #55
Professional Tinkerer
Andy,
Many thanks for putting this write up together. I'm in the middle of this same project.
Question - Do the 944 CV's require CV gaskets between the stub/cv and trans/cv?
Another way to accomplish this task is with 944/951 stub axles instead of SC stubs. A 5mm spacer is required on the bearing flange (944's/later 911's used a 5mm wider bearing).
And it appears the 951 stubs do not require a cv gasket (they are flanged to fit over the corners of the cv joint).
See 951 stub below - no cv gasket required.
matthepcat
post Mar 12 2012, 01:10 AM
Post #56
Meat Popsicle
I had to use a cv gasket between the inner cv and trans output flange.
ClayPerrine
post Mar 12 2012, 11:23 AM
Post #57
Yes, they do require a CV gasket. If you don't put them in, it slings grease everywhere... BTDT!
Aaron Cox
post Mar 12 2012, 11:36 AM
Post #58
QUOTE(ClayPerrine @ Mar 12 2012, 10:23 AM) *
even the stub axle side??
Wow. Grease slinga!
matthepcat
post Mar 12 2012, 03:25 PM
Post #59
Meat Popsicle
No.
Only on the inner CV.
QUOTE(Aaron Cox @ Mar 12 2012, 09:36 AM) *
Wow. Grease slinga!
Aaron Cox
post Mar 12 2012, 03:45 PM
Post #60
roger matt. Thanks.
BTW - anyone need any 951 stub axle spacers made? Having my machinist bang out a set for me, and figured - while he's making some......
- Lo-Fi Version Time is now: 2nd April 2026 - 11:56 AM
