> Bay Area: 1974 Porsche 914 2.0l (campbell) $6800
914World
post Sep 24 2011, 02:18 PM
Member #1
Car has been set up as a street legal track and auto-x racer. The car was completely stripped to bare metal and repainted. Race 2.0L just installed, but final engine install has not been complete, so it is currently not running. Everything is included to finish the install, just not the time to complete it. The following is a list of items that have been done to the car.
Paint
Strip exterior and interior to bare metal
Acid etching primer all bare metal
Base primer
Two coats of silver paint exterior and interior
Front Suspension
New race bushing in lower control arm front and back
Bilstein struts
22 mm torsion bars
22 mm sway bar
New passenger side lower ball joint
New wheel bearing
Turbo tie rods
bump steer kit
Flex dam front air dam
15 by 7 steel rims
Falken Azenis Sport 205 50 15
Rear Suspension
New wheel bearings
New race bushing in swing arm inside and out
Bilstein shocks
16 mm rear sway bar
200lb. springs
Adjustable spring purchases
15 by 7 steel rims
Race alignment and corner weighted
Brakes
19mm master cylinder
Replace Proportioning valve with T-fitting
Stainless steel break lines
Parking brake cables
Remove dust shields
Porterfield front brake pads
Ferodo Rear brake pads
Rebuilt front calipers
Inspect and reinstalled all hard brake lines
Engine
Ceramic coated racing heaters
Optical Pertronix points
High pressure booster piston kit
New dual oil sender unit
Remote oil sender kit
Remote oil cooler adapter plate
Stainless steel oil lines
AN fitting for remote oil cooler
Front mounted oil cooler
Custom fabricated oil line support
Powder coated engine tin
Solid motor mounts
Solid transmission mounts
New rear main seal
Replace all fuel line on engine
New injector seals
New fuel filter
New fuel lines at tank
Replace tank sending unit
Replace fuel pump
New fuel pump mounts
K&N air filter
New battery tray
Optima Batter
Hard mount batter strap
Reinforce clutch tube at fire wall and tunnel
New clutch cable
Heat shielding for cabling
New shift rod bushing at firewall
New Teflon shift rod bushing at transmission
Race cam
Stock fuel injection
Stock pistons and cylinders
Lighten flywheel
Interior
Bronze pedal bushings
Replace brake light switch
New tachometer
Low oil warning light
Removal of floor pan sound deeding material
Removal of fire wall sound deeding material
Welded in reinforcing plates for roll cage
Roll cage
Roll cage padding
Carbon fiber dash skin
Custom fiber dash with built in gages
VDO oil pressure gauge
VDO oil temp gauge
Windshield to dash seal
Replaced windshield
Windshield seal
Momo race seat
Stock seat belts
Replace head light switch
Momo steering wheel
Quick release steering wheel adapter
Replace rear window
New rear window seal
Replace rear window to engine lid seal
Gas shock rear trunk lid kit
New rear trunk hinge mounts
  • it's NOT ok to contact this poster with services or other commercial interests
View the full article
- Lo-Fi Version Time is now: 2nd April 2026 - 07:04 AM
