| jmill |
Oct 2 2011, 08:45 AM
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest |
Search wasn't my friend here and I came up blank. I found an install thread but the location was eyeballed. I thought that there was a template out there that showed exact location. (IMG:style_emoticons/default/confused24.gif)
| BMXerror |
Oct 2 2011, 09:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Just a thought. You could get the reinforcement kit and that'll show you the exact placement. Probably not a bad idea to reinforce anyways if you're going to a big aftermarket swaybar.
http://engmanparts.com/swaybarref.php Mark D. |
| peteyd |
Oct 2 2011, 09:36 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 743 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
The pelican forum has a good write up. I used it with no problems.
http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm |
| jmill |
Oct 2 2011, 09:40 AM
Just a thought. You could get the reinforcement kit and that'll show you the exact placement. Probably not a bad idea to reinforce anyways if you're going to a big aftermarket swaybar. http://engmanparts.com/swaybarref.php Mark D. Thanks for the link. I'm going with a 23mm bar. Haven't heard of guys ripping out or bending up their mounts. Is this an issue? If it is, I'll install it. A pound or two added up front wouldn't hurt me either. |
| jmill |
Oct 2 2011, 09:46 AM
The pelican forum has a good write up. I used it with no problems. http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm Exactly what I was looking for! Thanks. |
| BMXerror |
Oct 2 2011, 11:37 AM
Thanks for the link. I'm going with a 23mm bar. Haven't heard of guys ripping out or bending up their mounts. Is this an issue? If it is, I'll install it. A pound or two added up front wouldn't hurt me either. I've got a 1" (25.4 mm) speedway engineering bar with stock torsion bars and no reinforcement. I haven't had a problem yet, but I think it becomes an issue when you combine a heavy bar with big T-bars. I will reinforce when I go to heavier torsion bars. I was more offering the link because, if I were in your situation I would probably just do both at the same time. Mark D. |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:30 AM |
