| dlestep |
Oct 30 2011, 09:12 PM
I am smilin'... ![]() ![]() ![]() Group: Members Posts: 890 Joined: 15-January 08 From: Sunrise Florida Member No.: 8,573 Region Association: South East States |
...DO NOT USE CRES (stainless) in this process....
| partwerks |
Oct 30 2011, 09:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,619 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Is the electrolysis the same concept used in a HHO dry cell?
http://www.youtube.com/watch?v=Ffc0r1hHqWk...feature=related |
| 914Mike |
Oct 31 2011, 01:03 AM
Member ![]() ![]() Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
Somebody missed this part from post #1:
"Don't use stainless steel for the electrodes. The results are toxic and illegal to dump out." |
| rick 918-S |
Dec 2 2011, 09:13 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I just did this to Sandy's tank. He's a few things that seemed to work for me. I used a piece of 18 ga. sheet metal. I rolled it into a tube shape and bolted a tab to one end. This gave me more surface area than a strip of metal or a piece of rebar which seems to be the generally used sacrificial piece of steel.
I used the reccomended mix of 1 table spoon to 1 gal of water and filled the tank. Here is my electrode. ![]() I used shrink wrap over the ends to avoid contact inside the tank or at the opening. I did this for two days. After the first day I poured out the nasty rust water. I could see it was working but not to my satifaction. Here's what it looks like when it's cooking. ![]() The next day I started fresh. I used a grinder to clean my metal elctrode. What I found was, as the metal started to gather too much rust the gauge on my charger would start to drop. I pulled the electrode and cleaned off again with a grinder and started again. I cleaned off the electrode about every 2-2.5 hours. about the third time I pulled the electrode it was going from orange rust to black. Another thing I did was to take a gallon of the solution and flooded the openings washing out the top of the orange sludge. This seems to work well. Here's what I ended up with, I am rinsing the tank with a 50/50 solution of metal ready and plan on using some WD-40 or marvel or something to clean the flash rust in preperation of new gas. ![]() |
| jaxdream |
Dec 2 2011, 10:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
Rick , that looks great (IMG:style_emoticons/default/piratenanner.gif) . I wonder if temp would play a role in the length of time you mentioned, seeing the snow on the ground. There was no mention of outside temp , still it might effect the process some . As your pics do show , you had great success with this method , inspite of the outside temps . This is something on my future " to do " list ,as I have a few tanks to chose from for my car's fuel tank.
Jack |
| rjames |
Dec 2 2011, 10:23 AM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,447 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
The science is cool, but it seems like a lot of hassle to go through for a gas tank when you could just drop it off at a radiator shop and have them dip it in muriatic acid for ~$50.
| rick 918-S |
Dec 2 2011, 10:59 AM
I've done the radiator shop thing. Around here the shops suck. The tank would come back worse than it went in. It took like 45 minutes to fill the tank a gallon at a time. It's cold here so I had to keep going from the kitchen to the garage like 17 times. Otherwise it's like watching paint dry. I think If I would have cleaned off the electrode several times the first day I may have had faster results. It was a learning curve. I have a second tank to do. I did it outside because The process creates hydrogen gas. My boy and a couple friends were screwing around with their cars trying to make a hydrogen generator to add a free source of fuel to their cars. They were in my garage with the door down and lit off the gas they were collecting. BOOOM!!! (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/unsure.gif) I heard it in my office 70 feet away. Outside is best. (IMG:style_emoticons/default/wacko.gif)
| Drums66 |
Dec 2 2011, 06:17 PM
914 Rudiments ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
The science is cool, but it seems like a lot of hassle to go through for a gas tank when you could just drop it off at a radiator shop and have them dip it in muriatic acid for ~$50. I repeat ...RADIATOR SHOP! (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/shades.gif) |
| Jeffs9146 |
Dec 2 2011, 06:25 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE It took like 45 minutes to fill the tank a gallon at a time. You could run a hose from the bottom of the hot water heater! (IMG:style_emoticons/default/blink.gif) |
| rick 918-S |
Dec 3 2011, 11:40 AM
QUOTE It took like 45 minutes to fill the tank a gallon at a time. You could run a hose from the bottom of the hot water heater! (IMG:style_emoticons/default/blink.gif) Ya, but you still need to add the washing soda in the right mix per gallon. So, patiences is a virtue grasshopper... (IMG:style_emoticons/default/biggrin.gif) |
| charliew |
Dec 3 2011, 12:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
So why not ss?
| windforfun |
Dec 3 2011, 05:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,097 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
| Katmanken |
Dec 4 2011, 01:18 PM
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest |
Because it makes hexavalent chromium should the stainless corrode. Hexavalent chromium is toxic. See the "Erin Brockovich" movie.
http://www.osha.gov/OshDoc/data_General_Fa...nt_chromium.pdf But, you can can neutralize the toxic Hex-Chrom to the non-toxic Tri-Chrom with..... SUGAR.. http://www.technologyreview.com/blog/duncan/17578/ Or: You can also use ferrous sulfate and calcium hydroxide to neutralize the Hex-Chrom to Tri-Chrom Cr6+ + 3Fe2+ → Cr3+ + 3Fe3+ Cr3+ + 3 OH → Cr(OH)3 Fe3+ + 3 OH → Fe(OH)3 Tri-Chrom is sold in health food stores as a vitamin supplement. |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:10 AM |
