2 Pages V < 1 2
> Rusty Fuel Tanks, cleaning rusty fuel tanks
dlestep
post Oct 30 2011, 09:12 PM
Post #21
I am smilin'...
...DO NOT USE CRES (stainless) in this process....
partwerks
post Oct 30 2011, 09:42 PM
Post #22
Is the electrolysis the same concept used in a HHO dry cell?
http://www.youtube.com/watch?v=Ffc0r1hHqWk...feature=related
914Mike
post Oct 31 2011, 01:03 AM
Post #23
Somebody missed this part from post #1:
"Don't use stainless steel for the electrodes. The results are toxic and illegal to dump out."
rick 918-S
post Dec 2 2011, 09:13 AM
Post #24
Hey nice rack! -Celette
I just did this to Sandy's tank. He's a few things that seemed to work for me. I used a piece of 18 ga. sheet metal. I rolled it into a tube shape and bolted a tab to one end. This gave me more surface area than a strip of metal or a piece of rebar which seems to be the generally used sacrificial piece of steel.
I used the reccomended mix of 1 table spoon to 1 gal of water and filled the tank.
Here is my electrode.
I used shrink wrap over the ends to avoid contact inside the tank or at the opening.
I did this for two days. After the first day I poured out the nasty rust water. I could see it was working but not to my satifaction. Here's what it looks like when it's cooking.
The next day I started fresh. I used a grinder to clean my metal elctrode. What I found was, as the metal started to gather too much rust the gauge on my charger would start to drop. I pulled the electrode and cleaned off again with a grinder and started again.
I cleaned off the electrode about every 2-2.5 hours. about the third time I pulled the electrode it was going from orange rust to black. Another thing I did was to take a gallon of the solution and flooded the openings washing out the top of the orange sludge. This seems to work well.
Here's what I ended up with, I am rinsing the tank with a 50/50 solution of metal ready and plan on using some WD-40 or marvel or something to clean the flash rust in preperation of new gas.
jaxdream
post Dec 2 2011, 10:04 AM
Post #25
Rick , that looks great (IMG:style_emoticons/default/piratenanner.gif) . I wonder if temp would play a role in the length of time you mentioned, seeing the snow on the ground. There was no mention of outside temp , still it might effect the process some . As your pics do show , you had great success with this method , inspite of the outside temps . This is something on my future " to do " list ,as I have a few tanks to chose from for my car's fuel tank.
Jack
rjames
post Dec 2 2011, 10:23 AM
Post #26
I'm made of metal
The science is cool, but it seems like a lot of hassle to go through for a gas tank when you could just drop it off at a radiator shop and have them dip it in muriatic acid for ~$50.
rick 918-S
post Dec 2 2011, 10:59 AM
Post #27
I've done the radiator shop thing. Around here the shops suck. The tank would come back worse than it went in. It took like 45 minutes to fill the tank a gallon at a time. It's cold here so I had to keep going from the kitchen to the garage like 17 times. Otherwise it's like watching paint dry. I think If I would have cleaned off the electrode several times the first day I may have had faster results. It was a learning curve. I have a second tank to do. I did it outside because The process creates hydrogen gas. My boy and a couple friends were screwing around with their cars trying to make a hydrogen generator to add a free source of fuel to their cars. They were in my garage with the door down and lit off the gas they were collecting. BOOOM!!! (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/unsure.gif) I heard it in my office 70 feet away. Outside is best. (IMG:style_emoticons/default/wacko.gif)
Drums66
post Dec 2 2011, 06:17 PM
Post #28
914 Rudiments
QUOTE(rjames @ Dec 2 2011, 08:23 AM) *
I repeat ...RADIATOR SHOP! (IMG:style_emoticons/default/poke.gif)
(IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/shades.gif)
Jeffs9146
post Dec 2 2011, 06:25 PM
Post #29
Ski Bum
You could run a hose from the bottom of the hot water heater! (IMG:style_emoticons/default/blink.gif)
rick 918-S
post Dec 3 2011, 11:40 AM
Post #30
QUOTE(Jeffs9146 @ Dec 2 2011, 06:25 PM) *
Ya, but you still need to add the washing soda in the right mix per gallon. So, patiences is a virtue grasshopper... (IMG:style_emoticons/default/biggrin.gif)
charliew
post Dec 3 2011, 12:16 PM
Post #31
So why not ss?
windforfun
post Dec 3 2011, 05:08 PM
Post #32
QUOTE(charliew @ Dec 3 2011, 10:16 AM) *
So why not ss?
Katmanken
post Dec 4 2011, 01:18 PM
Post #33
You haven't seen me if anybody asks...
Because it makes hexavalent chromium should the stainless corrode. Hexavalent chromium is toxic. See the "Erin Brockovich" movie.
http://www.osha.gov/OshDoc/data_General_Fa...nt_chromium.pdf
But, you can can neutralize the toxic Hex-Chrom to the non-toxic Tri-Chrom with.....
SUGAR..
http://www.technologyreview.com/blog/duncan/17578/
Or:
You can also use ferrous sulfate and calcium hydroxide to neutralize the Hex-Chrom to Tri-Chrom
Cr6+ + 3Fe2+ → Cr3+ + 3Fe3+
Cr3+ + 3 OH → Cr(OH)3
Fe3+ + 3 OH → Fe(OH)3
Tri-Chrom is sold in health food stores as a vitamin supplement.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 2nd April 2026 - 03:50 PM
