> Bay Area: Porsche 914 Mustang Shelby XR7 Cougar rod parts L@@K! (Ceres will ship) $50
914World
post Mar 9 2012, 02:45 AM
Member #1
LOT #3 Porsche 914 body and misc. 2.0 1.7 type IV
* O.E.M. headlight body cover (set)
* O.E.M. headlight motor cover (set)
* O.E.M. transmission mount (set) and misc. hardware
* O.E.M. 3 misc. trunk hinges
* O.E.M. front hood latch and mounting hardware
* O.E.M. engine latch and hardware
* O.E.M. excellent door strikers and all hard to find mounting screws
* O.E.M. trunk lock cylinder
* O.E.M. cig. lighter base and screw on mounting
* O.E.M. excellent trans to ground strap
* O.E.M. side marker light body-rough
* O.E.M. windshield trim corners
* O.E.M. bumper dog bone
* O.E.M. strut washer set
* O.E.M. interior vent 72 thru 76, visor
65 66 67 68 Mustang Shelby interior parts lot #6
* Apx. 30% speedometer change inline adapter to run around 4:11 etc... just fine tune with plastic cable to trans gear,
* Shelby Holley fuel line misc.
* O.E.M. Mustang piston type choke pull off assembly
* O.E.M. (2) interior door mirror mount bezels
* O.E.M. outer deluxe trunk cap trim piece
* O.E.M. (1) smog tube insert
* O.E.M. steering column lower brace
* O.E.M. door lock cylinder
* O.E.M. (3) 65-7 cig lighters
* O.E.M. (1) 68 up lighter
* O.E.M. (1) cig lighter mounting case
* O.E.M. (2) washer pump/intermittent wiper floor switches
* O.E.M. turn signal lever
* O.E.M. emergency switch knob
* NOS O.E.M. (1) Ford glove box latch box w/ nib parts including ford re-keying tumblers and chrome surround - minus the latch itself -
* O.E.M. 5 mixed 65 thru 68 glove box latches 4 of which are locking
LOT # 10
huge stash of diag. parts LOT #10 NOS fuel electrical ignition gm ford mopar l@@k, From
dealer mechanics test drawer of know good test parts with mixed NOS
* (2) blue (EEC III?) 90's electronic control modules
* NOS & O.E.M. relays
* misc fuel regulators
* fuel pump
*solenoids
* electrical pigtails NOS & used
* (6) Chrysler hall effect modules NOS
* O.E.M. (several) for pickup coils
* O.E.M. half dozen AIC motors
* misc. more...
LOT # 11
huge stash of diag. parts LOT #11 NOS carb ignition computer gm ford mopar l@@k From dealer mechanics test drawer of know good test parts with mixed NOS gaskets
* (1) box of misc. Holley and other carburetor NOS misc. gaskets
* (1) aluminum 4 BBL spacer
* (1) NOS Ford 2 BBL base gasket/spacer
* (1) NOS temp sending unit
* (2) new e.g.r. base gaskets
* (2) alt pulley nuts and washers
* NOS coil pack
* (6)+ various Ford Chevy TPS switches
* (1) MPS switch
* several good alternator voltage regulators
* a couple used G.M. on the column ignition switches,
* (2) A/C switches
* 90's S-10 v-6 computer chip
LOT # 12
Shelby Mustang Torino Parts LOT #12 NOS OEM FORD Mercury l@@k low $$$ NO reserve.
* NEW 351W double roller timing chain,
* NEW h/d tie rod ends
* solid state alternator regulators (2)
* bag of 67-8 misc. hard to find O.E.M. gauge cluster dividers and screws
* (2 sets) of rear end/leaf spring U-bolts/nuts
* COMPLETE poly urethane rear leaf spring bushing kit
LOT # 15
LOT# 15 Mustang Cougar 67 68 headlight and misc. interior parts
* O.E.M. headlight surround trim set
* O.E.M. stainless steel headlight surround hold down set
* O.E.M. head light bucket
* O.E.M. front turn signal brace backing
* O.E.M. back up light brace backing
* O.E.M. rebuild able (power disc.) w/ unobtainium ring
* O.E.M. door handle/release (possible GT handle)
* O.E.M. deluxe door speaker (for parts) C7ZA-18808-B
* O.E.M. 67 parts antenna
LOT # 16
LOT # 16 Shelby Mustang Cougar trim, drive train, interior
* O.E.M. 67 68 coupe rear window L&R stainless trim
* O.E.M. 67 68 L half dash to windshield trim piece
* O.E.M. 67 68 misc. windshield trim piece (2)
* O.E.M. 67 Mustang pass. Side dash trim w/ pony insert
* O.E.M. 67 68 R grill trim
* O.E.M. 67 thru (?) 4 speed & C-4 transmission mount
* O.E.M. C-6 automatic transmission dip stick
* O.E.M. glove box door
ITEM #17
ITEM #17 This large Pepsi sign and very unusual dry erase board menu is not only extremely rare 6 foot in length, but is a blackboard/dry erase type. It holds significant nostalgic memories to many central valley, Modesto residents that grew up or took their kids to Modesto's one and only Roller King. It closed after many years of fond memories. It was the main menu board that hung over the snack bar. The menu has been carefully preserved just as it was when you were growing up.
This unique Pepsi sign/menu is like no other I've seen. When was the last NON letter menu Pepsi sign you've seen? Chances are you've not seen a blackboard style before and may not again. Other than one small repairable spot (on lower right of frame) this sign is extremely mint. Now is your chance to bid on a significant piece of history and a really cool item for the rec room or shop. contact me for the link to the Facebook page dedicated to Roller King and the fond memories it gave. I believe I saw a quick shot of it hanging above the snack bar on a you tube video search. .Don't confuse this with the common sign/menu board with the plastic letters! This is a near mint must have!!! It will be carefully protected and packaged very securely. Please contact me on any additional questions I'll be happy to answer them ASAP. Happy bidding.
http://www.facebook.com/group.php?gid=120526225036#!/group.php?gid=120526225036&v=wall
ITEM #18
ITEM #18 NEW CHROME locking wheel lug set of 16 with key
This is a brand new set that has been installed once then removed as I wanted a shorter look instead. They are conical seats and are for 12mm x 1.5 threads. Will work to lock 4 sets of 4 wheels (1 lock on each wheel) or 4 wheels (4 per wheel).
ITEM #19
ITEM #19 GTI steering wheel MINT condition Mk1
O.E.M. Black mint condition. GTI center piece. No splits or cracks, you won't be disappointed!
ITEM #20
Crown Vic front shoulder strap seat belt sets (all 3 front sets) great resto mod hot rod upgrade. nice.
ITEM #23
ITEM #23 type IV EURO 1.7 piston, rods and pins, O.E.M. set, high compression ,raised dome.
Please look over my other auctions there are some incredibly good deals on vintage Ford, Mustang, Shelby, Porsche, 914 and G.M. parts coming from an estate sale of many years of car and parts collection.
ITEM #25
TRANS AM CAMERO ram air under hood diverter and electric solenoid. Use on your restomod, hot rod or rat rod. attaches to your hood underside then seals to you air inlet. Electric butterfly controlled air flow. complete unit as pictured. Factory designed quality!
.... NO reserve! Happy bidding
I will be listing new weekly. add 10% IF additional shipping insurance is desired.
ITEM #26
NOS NIB 70's thru early 80's Ca. emission control KIT sticker booklet parts, Remember these? 1965 thru 1973 American steel had to get em' They capped the vacuum advance, stuck an ungodly sticker on the speedometer... ahhhh... my beautiful 442! The where known as a NOX kit also. I've personally owned this since about 81'ish. A way cool man cave or garage wall hanger.
It's smog check time!!!
ITEM #28
1965 1966 Shelby Mustang interior door panel vapor seal set NORS NIB
NO REASERVE... NO SHIPPING!!!!!!!!!!!!
ITEM #29
like new edelbrock air cleaner 10" universal. Sat on display motor. New breater and hardware included
buy it now $24.99...
LOT #30
FORD FULL SIZE TRUCKS
1997 F-350 & F-450
1995 & 2002 F-150 sales brochure
1995
ITEM #31 NOS Power antenna + good spare free
ITEM #31 BRAND NEW power antenna + good 2nd used power antenna
* BRAND NEW power antenna w/ relay and extra length co-axial wire.
* good used power antenna included
Lot # 32 Mk1 steering wheel mint condition
Lot # 32 1983 VW rabbit caddy gulf steering wheel mint condition black
No cracks or splits, very nice steering wheel, you won't be disappointed
Lot # 35 vintage stereo bundle
Lot # 35 1] VINTAGE AM/FM 8 Track + 1] Pioneer cassette player + misc.
* excellent AM/FM 8 track
* excellent vintage Pioneer cassette unit W/ cassette & bracket
* like new 8 track and jacket
* VERY rare see thru EARLY 8 track
Lot # 36 vintage group of AM/FM 8 Track players
Lot # 36 Couple vintage stereos + misc.
* 70's ford AM/FM 8 Track stereo unit
* aftermarket AM/FM 8 Track unit
* (3) C.B. microphone hanger clips w/ mounting hardware
Lot # 38
Lot # 38 Fog light set like new
Lot # 39
Lot # 39 O.E.M. Falcon fender emblem original chrome minor pitting, lens crazing and fogged, very usable driver status.
Lot # 40
Lot # 40
* (2) Ford NOS grounding straps
* (2) NOS 90's Ford alternator recall repair pigtail
* trunk release solenoid
* trunk light & wiring
Lot # 41
Lot # 41 VDO 2" gauge & Combination sending unit matched set
5 BAR (75 lb.) backlit style gauge with the matched (important) combination sending unit. With this unit you can have a dummy light come on at 5lb's along with actual oil pressure reading. Great addition to any vehicle.
Lot # 42 VW rabbit pickup mk1 2 passenger seat very nice VW Scirocco
Tan in far nicer than average condition. Local pickup only
Lot # 43 Porsche 914 O.E.M. rear window, never installed after professional tint
Lot # 44 Porsche 914 O.E.M. rear window
Lot # 44 Porsche 914 O.E.M. rear window, non tint
Lot # 45 Porsche 914 O.E.M. factory tint passenger window
Lot # 46 Porsche 914 O.E.M. factory tint driver wing window
Lot # 47 S/W 2" oil or water temperature gauge 325 degree
Lot # 47 S/W 2" oil or water temperature gauge 325 degree. Backlit style gauge. Great addition to any vehicle.
Lot # 48 S/W 30 amp gauge
Lot # 48 S/W 30 amp gauge backlit style gauge. Great addition to any vehicle.
Lot # 49 VW Scirocco S1 mk1 3 spoke sport steering wheel center
Lot # 49 Very hard to find Tan rubber center section only. This is the center rubber only piece that's always missing. In excellent condition.
Lot # 50 OEM Dash bezel 64 65 Falcon Ranchero Mustang
Lot # 50 NO broken mounts or cracks, use as is or restore O.E.M. original part
Lot # 51 3-on-the-tree column to floor shift conversion pieces. . . RARE!. . . Unobtainium!!!. . .
Lot # 51 This is what you need to remove the ugly 3-on-the-tree shift column parts when you convert your 60's ford or Mercury over to a floor shift. O.E.M. Ford parts. These are extremely hard to locate parts that have been lost packed away for years in a box in my shop! YOU WILL NOT find these again! Comes with new NOS bearing to boot!
Lot # 52 Ford Mercury OEM premium sound cassette, C/D controller head unit
Lot # 52 This unit came from a 2000 Taurus Sable and is an excellent premium high powered with great sound. It has cassette with the factory c/d controls built in. It looks to be interchangeable with other Ford Mercury vehicles in early 2000's (same as my 2001 Escort Tracer etc. . .).
Lot # 53 Ford Mercury OEM premium sound C/D controller head unit
Lot # 53 This unit came from a 2001 Escort Tracer and is an excellent factory premium high with great sound. It looks to be interchangeable with other Ford Mercury vehicles in early 2000's (same as my 2000 Taurus Sable etc. . .).
Lot # 54
Lot # 54 NORS Door seal set
Lot # 55 NEW Mahle filter 2 25mm oil pumps TYPE IV Porsche VW 914
Lot # 55 Brand new Mahle OC28 oil filter, fits 1.7, 1.8, 2.0 TYPE IV and 914-6 engines. This is the good German Mahle. (2) 25mm oil pumps TYPE IV, used but very tight with no wear on drive tangs, excellent O.E.M. units.
Lot # 56 valves springs rockers extras 289 302 351 small block Ford L@@K
Lot # 56 valves springs, excellent condition rockers, bunch of misc. other. All parts came from stripped down set of small block Ford heads. See pictures, extras for that must have missing part you need but just can't find when your going thru those heads!
Lot # 57 O.E.M. rear window regulator 1967 1968 Mustang Cougar
Lot # 58 VINTAGE wrenches Model A T antique Ford Chevrolet Oldsmobile
Lot # 58 17 VINTAGE wrenches Model A T antique Ford Chevrolet Oldsmobile they've seen them all. These go way back. Cool Man Cave wall hangers.
Lot # 59 CATCH-A-CALL phone solicitor eliminator
Lot # 59 This plugs inline with your phone and filters out those annoying soliciting sales phone calls, WARNING: won't filter out the mother-in-law but everything else ;)
Lot # 60 INTERIOR screw kit misc. 60'S Shelby XR7 Eliminator Ranchero Falcon
Lot # 60 many many hard to find interior screws with special counter sunk heads, new, for ford cars trucks interior
Lot # 61 FORD posi-traction parts limited slip 9" drag race Shelby Boss fe
Lot # 61 Stash of posi and H/D rear end parts group
* O.E.M. posi traction 4 pinion block w/ all springs & plate & pins (50 miles on these parts)
* O.E.M. open style 4 pinion block
* O.E.M. set of excellent 28 spline spider gears
* (2) O.E.M. sets of pinion gears (for 4 pinion block)
* (1) NOS pinion gear crush sleeve (2) used pinion gear crush sleeve
* (8) O.E.M. ring gear bolts and washers
Lot # 62 7.5" rear end master shim set with bearing install driver press tools
Lot # 62 HUGE LIFETIME assortment of misc sized carrier adjustment shims. Ford Mercury 7.5 rear end rebuild adjust set up shim packs, includes inner and outer bearing races that make excellent precision press tools to install new carrier bearings.
Lot # 63 O.E.M. FOMOCO 9" ring gear and pinion set excellent low mile
Lot # 63 EXCELLENT original low mile. MINOR surface rust (shelved for years). 3.00:1. Came from low mile 1967 ford. PERFECT wear pattern. C2AW 4210 D
Lot # 64 1967 9 inch 3rd member carrier GTA Shelby Fairlane Comet Thunderbolt
Lot # 64 This is the original 9" pumpkin out of my original 1967 GTA S-code Mustang. C7AW E, production date 9B22. Complete with carrier caps & OEM bolts, pinion housing & shim pack, flange & lock nut. AWSOME pumpkin builder base or correct numbers restoration piece.
(IMG:http://i293.photobucket.com/albums/mm62/redgtastang/GTIwheeitem192.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebayitems057.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebayitems069.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebayitems077.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebayitems061-1.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebbayparts009.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebbayparts074.jpg) <img (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/lot12.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/DSC00619-1.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebbayparts035.jpg)(IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebbayparts020.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/item173.jpg)(IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebbayparts044.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/lot6.jpg) (IMG:http://i293.photobucket.com/albums/mm62/redgtastang/item183.jpg)(IMG:http://i293.photobucket.com/albums/mm62/redgtastang/ebbayparts035.jpg)
  • it's NOT ok to contact this poster with services or other commercial interests
View the full article
THIS IS NOT A 914WORLD AD!
Do not reply to this thread! No one is listening!
Click on the "View the full article" link above to go to the actual Ad!
- Lo-Fi Version Time is now: 2nd April 2026 - 11:56 AM
