2 Pages V < 1 2
> Falken Azenis, Rate 'em
Trekkor
post May 31 2004, 07:28 PM
Post #21
I do things...
Set the tires to 29 psi cold.
Ran hard.
The car understeers a bit and feels a little drifty.
A little tail happy, if you will.
Added fuel ( front end weight ) and set the Koni's 1 whole turn each from full soft toward firm front and rear.
A little better.
Came home fast. ( vineyard lap )
Checked tires hot. 32 psi front, 34 psi rear.
Your comments, if you please.
grantsfo
post Jun 1 2004, 02:06 PM
Post #22
Arrrrhhhh!
I missed your original post. I just installed 205/50/15 Falken Azenis sports on my car as well. I originally started at cold 33 psi. One thing I'm still getting used to is the delay in inital turn in and the floaty feeling compared to my 195/60/15s. I cranked up the presure to 38 psi and floatly feeling went away, but not sure thats going to be the best pressure. I'm having a love hate thing with these tires - grip is awesom, but road feel is strange for me.
Ride height of the 205/50/15 falkens seems about the same as my 195/60/15s. Car doesnt accelerate quite as well with bigger tires, but grip outweighs the slight reduction in acceleration.
seanery
post Jun 1 2004, 02:18 PM
Post #23
waiting to rebuild whitey!
how do these compare to Yoko A032Rs? Anyone here use both?
MattR
post Jun 1 2004, 02:24 PM
Post #24
Shouldnt smaller diameter = quicker acceleration? I think so, thats why I make fun of those rollers with 22s.
Has anyone had a significant problem with switching between bycicle tyres (165/1x-15) to 205s in over reving at freeway speeds? I cant remember what the stock size is, but I seem to remember punching it into a tyre calculator and figuring 10.1mph would read 10mph on the gauge. And is there that big of a difference between 205/55 and 205/50 in terms of acceleration vs top speed vs over reving?
Here is the link for that tyre compensator calculator thing:
http://www.web-cars.com/math/tiresize.html
GaroldShaffer
post Jun 1 2004, 02:26 PM
Post #25
You bought another 914?
I ran my first ever AX back on June 23rd. I had mine set to 30 psi cold with Konis set to full hard on front and full soft rear on my first 2 runs. My lack of driving skils and this combo caused the rear end to break loose on hard turns.
My next 2 runs no tire pressure change but set the koni's to 3 turns past soft on front and full soft on rear. My time got better by 3 seconds.
My last 2 runs again no tire pressure change and all koin's set to full soft, dropped another 2 sec of my time (I guess my driving skills improved (IMG:style_emoticons/default/wink.gif) )
Did two fun runs at 34 psi, front koni's 2 turns past soft and the rear 1 turn past soft and had my best time's of the day. So what does this mean?????
Nothing , I don't know what the F I'm doing but it was fun. (IMG:style_emoticons/default/biggrin.gif)
I think for my next AX I will set the tire pressure to 32 cold, and leave the front koni's set at 2 turns past soft and leave the rear at full soft and learn to drive the car that way.
- Garold
PS I run 205/50/15 on my car
Part Pricer
post Jun 1 2004, 02:52 PM
Post #26
Believe everything I post
Garold, that's 34 psi hot right?
GaroldShaffer
post Jun 1 2004, 09:23 PM
Post #27
Well, yes and no. The funs runs were done about 25 min after I completed my final offical timed runs. So I guess you could say they were hot.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 2nd April 2026 - 06:42 AM
