GB- CV joint bolts drilled for safety wire, $2.25 each GB Closes Nov 15th |
Mikey914 |
Aug 12 2012, 07:17 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
These are new, and drilled for safety wire. The beauty is that you don't have to replace all the bolts, so if you want piece of mind that your CV joints will not come off, you can safety wire the bolts on. This will make it much easier.
Who needs em? Attached thumbnail(s) Attached image(s) |
FourBlades |
Aug 12 2012, 07:45 PM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I'd like a set, which is what, 8? Do you use them on the tranny side as well? John |
914werke |
Aug 12 2012, 08:06 PM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/stirthepot.gif) How much are new schor lock washers?
Mike Bellis |
Aug 12 2012, 08:43 PM
I'm in for 8 with washers if you can get them. (IMG:style_emoticons/default/smile.gif)
speed metal army |
Aug 12 2012, 08:56 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Id be down! Throw the wire in there with washers!
Dr Evil |
Aug 12 2012, 10:11 PM
Ya, I threw in wire, washers and bolts (IMG:style_emoticons/default/poke.gif)
Thanks for taking this on! (IMG:style_emoticons/default/thumb3d.gif) |
Mikey914 |
Aug 12 2012, 11:29 PM
I'll locate the washers. The wire is cheap. I know you don't have to use a drilled on on each, so for those of us that want to just alternate you can save a few bucks. I'll round up the wire and the washers. May take a few days.
Truth is if you have the safety wire the washer really makes no difference, except on the ones that don't have it. -Mark |
euro911 |
Aug 13 2012, 01:20 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I'd feel better knowing ALL of mine were wired, with schnorrs underneath them too (at both, the tranny flanges and the stub axles). Cheap insurance (IMG:style_emoticons/default/shades.gif)
Dr Evil |
Aug 13 2012, 06:45 AM
Wire them all! If you wire only a few, then that is what will be left if any of them come loose. Then, those may just likely break and take the CV with them. All or nothing (IMG:style_emoticons/default/smile.gif)
JStroud |
Aug 13 2012, 08:27 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
I'd feel better knowing ALL of mine were wired, with schnorrs underneath them too (at both, the tranny flanges and the stub axles). Cheap insurance (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/agree.gif) So that would be 16 per car, so I need 32. When will these be ready to ship. Jeff |
montoya 73 2.0 |
Aug 13 2012, 08:59 PM
Lack of consideration to others, and Selfish! Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California |
I need a full set (16). Are you drilling 2 holes or 4? I would prefer 4.
Dr Evil |
Aug 13 2012, 09:04 PM
4 is the preferred method (IMG:style_emoticons/default/smile.gif)
Valy |
Aug 13 2012, 09:06 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I need a full set (16). Are you drilling 2 holes or 4? I would prefer 4. (IMG:style_emoticons/default/agree.gif) |
montoya 73 2.0 |
Aug 13 2012, 09:09 PM
i lost the set I got from the Doc.
Mikey914 |
Aug 13 2012, 09:25 PM
Each bolt is drilled with 2 holes, I'll have the washers figured out in another day. The wire is inbound and I'll be able to ship by Friday.
-mark |
bigkensteele |
Aug 13 2012, 09:31 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Why? If wired correctly, the orientation of the holes should not matter, no? (IMG:style_emoticons/default/confused24.gif) Mark, I am in for a set of 16 as well. I can send you back new 16 cores, too. Is there any reason that used bolts can't be used as cores? |
montoya 73 2.0 |
Aug 13 2012, 09:40 PM
Why? If wired correctly, the orientation of the holes should not matter, no? (IMG:style_emoticons/default/confused24.gif) Some times the holes are in a wierd angle. |
michael7810 |
Aug 13 2012, 10:39 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
I'll take a set of 16.
Mikey914 |
Sep 8 2012, 10:37 PM
Installed photo -
Washers and wire will be in this week Attached image(s) |
Mikey914 |
Sep 8 2012, 10:40 PM
Why? If wired correctly, the orientation of the holes should not matter, no? (IMG:style_emoticons/default/confused24.gif) Mark, I am in for a set of 16 as well. I can send you back new 16 cores, too. Is there any reason that used bolts can't be used as cores? More hassle to clean up and the finish can be an issue. Easier to buy new ones at $1.60 each than mess with the old ones. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:16 PM |
