| eyesright |
Nov 9 2012, 04:52 PM
Member ![]() ![]() Group: Members Posts: 430 Joined: 8-January 12 From: OK Member No.: 13,979 Region Association: Southwest Region |
I just got my 2.0 heads back from Len (Hoffmann automotive) and they are beautiful. It'll be weeks before I am ready for them but photos will be forthcoming.
In the meantime, I muse about valves...since fuel injectors can be precisely controlled in timing and range of movement, with stronger electronics of course, could not intake and exhaust valves be moved electrically thereby allowing variable timing and maybe even reach. Yes modern cars have variable cams but wouldn't electrical valves be infinitely varible? Surely engineers have considered this. Enlighten me if any of you know. Thanks. |
| brant |
Nov 9 2012, 04:56 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
bmw built this in test engines over 10 years ago
I think formula one engines used pneumatic valves for years and years (don't know if they still do?) because the valve springs couldn't keep up with 18k revolutions per a minute |
| Mike Bellis |
Nov 9 2012, 04:57 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Theoretically possible if you can get a solenoid powerful enough to open under combustion. The harder part is controlling the speed at which it opens. Then the solenoid needs to operate like a stepper motor.
You should invent it!, But I bet Cadillac already has something in the works... |
| tommy914 |
Nov 9 2012, 04:58 PM
Life is a journey, enjoy every turn. ![]() ![]() ![]() Group: Members Posts: 1,103 Joined: 15-September 03 From: Ridgeland, MS Member No.: 1,165 Region Association: None |
| nathansnathan |
Nov 9 2012, 05:34 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None |
There is a wiki page on camless engines.
http://en.wikipedia.org/wiki/Camless |
| Al Meredith |
Nov 9 2012, 05:43 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 984 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
can't do it with 12 volts. There was a movement worldwise to move to a 36 volt prootcol to allow for an acceptical solanoid , but I haven't heard of it latley.
| ghuff |
Nov 9 2012, 05:45 PM
This is certainly not what I expected down here. ![]() ![]() ![]() Group: Members Posts: 849 Joined: 21-May 09 From: Bodymore Murderland Member No.: 10,389 Region Association: MidAtlantic Region |
New dodge dart.... Iirc it's solenoid lifters or something called air something... I'm awesomely helpful but google it
| brp986s |
Nov 9 2012, 09:09 PM
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 |
can't do it with 12 volts. There was a movement worldwise to move to a 36 volt prootcol to allow for an acceptical solanoid , but I haven't heard of it latley. Dang, I hope you're not driving soon (IMG:style_emoticons/default/drunk.gif) |
| charliew |
Nov 9 2012, 09:14 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 |
or typing
| Porcharu |
Nov 10 2012, 12:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 27-January 05 From: Campbell, CA Member No.: 3,518 Region Association: Northern California |
They have been trying this for ~ 25+ years. I remember seeing a SB chevy with this setup in HotRod a LONG time ago. Worked perfectly up to about 1500 RPM. It's a great idea as you can get rid of the throttle and get near diesel efficiency with gas. F1 cars are still using pneumatic valve springs, I saw Mark Webber get a gas refill on a recent race.
| falconfp2001 |
Nov 10 2012, 03:30 AM
Pancho Pantera ![]() ![]() Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
create a solenoid with a plunger stop at one end where the distance is controlled by hydraulic oil. The plunger stop can control your lift height. You have near instantaneous reaction and the variable height control. YOu can further speed up activation by only controlling your ground supply.
It would be a very complicated setup as there would need to be hydraulic valves controlling each solenoid lift height. Wear would be the main concern on the plunger stop. |
| Ductech |
Nov 10 2012, 03:32 AM
Member ![]() ![]() Group: Members Posts: 356 Joined: 16-July 10 From: AridZona Member No.: 11,949 Region Association: Southwest Region |
Oh make it desmodromic whilst your at it !
| falconfp2001 |
Nov 10 2012, 04:26 AM
| bulitt |
Nov 10 2012, 05:35 AM
Achtzylinder ![]() ![]() ![]() ![]() Group: Members Posts: 4,189 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Overhead Cams. Wankel. Or maybe a turbine like the Batmobile.
| SLITS |
Nov 10 2012, 07:00 AM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Two stoke ...........................
| ClayPerrine |
Nov 10 2012, 02:23 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Rotary valves. No valve springs... no valve in the way of the airflow. Just a nice open hole. No chance of the piston hitting the valve in high compression engines. No valve float. Simplified valvetrain, just a shaft with slots cut in it.
First invented in 1886. Never perfected. No one was able to overcome the radial sealing issues with the shaft. Rotary Valve Engines |
| Porcharu |
Nov 11 2012, 12:35 AM
It will happen in the next 20 years or so. My Powerstroke has these unreal fuel injectors (120+VAC) that could/should be adopted to valve actuation. 40,000 PSI of injector pressure.
Lo-Fi Version | Time is now: 2nd April 2026 - 06:26 AM |
