| tscrihfield |
Jan 6 2013, 05:24 PM
Drive Fast and Take Chances ![]() ![]() ![]() Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None
Okay, so I have made more progress on the car in the past few months than I have in the past two years and I want to keep the momentum. to give everyone an idea of where I am going with my car, it is going to be a driver for good weather and a trackday toy. But heavily used at the track... ( wife won't let me go all out track cuz she wants to ride around in it...(IMG:style_emoticons/default/sad2.gif) ... But that is her only wish without any complaint til now, I won't pry...
I need some advice/guidance based on folks experience... First I have heard good and bad about aluminum fuel lines. I know that I want hard lines that will be mounted along the longs. I am wanting to run them with AN fittings on each end with braided lines running to the tank and engine. What's you're opinion? Second Can someone provide non factory seat mounting. I am running bride low max seats and I do not like their seat rails or the height of them so I am looking into other options if I don't modify the factory setup. Last... I am torn in the Gauge area.... I love the look of stock 914 gauges but I really like the AIM dash. Does anyone have one of these and driven on the street? I am looking for the good and bad to this... Thanks, Thomas |
| Cap'n Krusty |
Jan 6 2013, 05:42 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Aluminum fuel lines? Not a chance. They don't like ANY vibration. Use stainless steel. IME, SS braided fuel/oil lines tend to develop leaks. Not worth the extra bux, IMO.
The Cap'n |
| tscrihfield |
Jan 6 2013, 06:09 PM
Aluminum fuel lines? Not a chance. They don't like ANY vibration. Use stainless steel. IME, SS braided fuel/oil lines tend to develop leaks. Not worth the extra bux, IMO. The Cap'n Have heard that about the aluminum, just wanted continuity. On the SS braided lines. What would you prefer? Regular lines with AN? I know that hose clamps are frowned upon with PCA. Thomas |
| Jeffs9146 |
Jan 6 2013, 08:04 PM
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
| tscrihfield |
Jan 6 2013, 08:18 PM
I'm not running them in the factory location. I can purchase lengths and run them where im planning. What would you recommend for flexible portions of the line sets? |
| Mike Bellis |
Jan 6 2013, 08:40 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I have run aluminum soft drawn (specific for fuel) on many cars without any problems. I have a mandrel bender and they make very nice lines. The are designed for A/N fittings and is available from Summit Racing.
Using hard aluminum or copper is bad. It will crack. |
| tscrihfield |
Jan 7 2013, 09:50 PM
I have run aluminum soft drawn (specific for fuel) on many cars without any problems. I have a mandrel bender and they make very nice lines. The are designed for A/N fittings and is available from Summit Racing. Using hard aluminum or copper is bad. It will crack. How do you tell the difference? I went to their site and searched soft drawn and didn't find it. It's the coiled up tubing right? But I could find a different designation for soft to hard tubing... Thomas |
| Mike Bellis |
Jan 7 2013, 10:15 PM
I have run aluminum soft drawn (specific for fuel) on many cars without any problems. I have a mandrel bender and they make very nice lines. The are designed for A/N fittings and is available from Summit Racing. Using hard aluminum or copper is bad. It will crack. How do you tell the difference? I went to their site and searched soft drawn and didn't find it. It's the coiled up tubing right? But I could find a different designation for soft to hard tubing... Thomas Summit and Jegs only sell the soft drawn. A piping wholesaler will sell hard tube. If it is in a coil, it usually is soft drawn. Here is some on the fuel rail of my Big Block Mopar. ![]() |
| tscrihfield |
Jan 8 2013, 04:36 PM
I have run aluminum soft drawn (specific for fuel) on many cars without any problems. I have a mandrel bender and they make very nice lines. The are designed for A/N fittings and is available from Summit Racing. Using hard aluminum or copper is bad. It will crack. How do you tell the difference? I went to their site and searched soft drawn and didn't find it. It's the coiled up tubing right? But I could find a different designation for soft to hard tubing... Thomas Summit and Jegs only sell the soft drawn. A piping wholesaler will sell hard tube. If it is in a coil, it usually is soft drawn. Here is some on the fuel rail of my Big Block Mopar. ![]() Sounds good, that's what I've been looking at. Thanks! |
| ArtechnikA |
Jan 8 2013, 04:44 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
On the SS braided lines. What would you prefer? Regular lines with AN? The problem is not with the SS braid, but the nitrile/Buna-N liner which will oxidize in time, after exposure to heat, ozone, and oxygenated fuels. Seen it happen, yes, it's real. Race cars just replace all the hose every so often. The alternative to all hard line is braided-sheath Teflon hose. Yes the hose and fittings are expensive. But the Teflon will stand up to methanol, as will the fittings which are typically also stainless. Or at least plated steel - the key point is they are _not_ aluminum. |
| stugray |
Jan 8 2013, 05:05 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I used rigid steel (not stainless) brake lines for my fuel lines.
They were available from the local auto parts store. I flared the ends to take the AN fittings. I am converting to carbs, so didnt need both lines but I ran both anyway. That way I can use the second line for a fuel pump wire conduit from the stock location to the front where the new pump is. Stu |
| Dave_Darling |
Jan 8 2013, 05:36 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The problem is not with the SS braid, but the nitrile/Buna-N liner ... Is nitrile or Buna-N still the most common liner? I believe that there are at least some of the SS braided lines that have Teflon liners. No, I'm not sure which ones. No, I'm not sure how you can tell which is what. --DD |
| ArtechnikA |
Jan 8 2013, 07:11 PM
Is nitrile or Buna-N still the most common liner? I believe that there are at least some of the SS braided lines that have Teflon liners. Yes, there's Teflon-lined braided stainless hose. I think I said that... in AN-3 it's popular for brake line and in AN-4, clutches and other hydraulic actuators. and -6 is good for fuel lines for even high flow rates - i think the smooth(er) walls help. I've seen it in -8 and larger but you better have a F1 budget for that stuff... even -6 is pricey. Here's the blurb from the Perform-O-Flex (IMO - Earls' good stuff - Aeroquip and Goodridge have good stuff too...) on the hose: QUOTE Top racing teams depend on Earl's Perform-O-Flex hose. The hose features an inner liner of Temprel synthetic rubber, a partial-coverage protective sheath of stainless steel braid embedded in the liner during manufacturing, and a full-coverage outer protective sheath of high tensile stainless steel wire braid. So what's Temprel? I donno - this isn't my research project ;-) 'Speed-Flex' (6000-series...) is the PTFE-lined stuff, and in -6 it's $6 a foot. The fittings and olives are the pricey bits, tho, and the PTFE has a fairly large bend radius. But in today's oxygenated fuels environment, it's what you gotta do... |
| tscrihfield |
Jan 8 2013, 07:53 PM
ArtechnikA, Dave & Stu
Thanks for all of the info. I am going to go with earls stuff anyway, but I didn't know that they had a PTFE lined version of their braided lines. I have found that in using the braided lines earls is the only way to for the quality that you can actually tighten and not have leaks... I'm pretty familiar with PTFE because I use a ton of PTFE products for work. When dealing with things that have to hold up to skydrol you need a good barrier... I don't mind to spend the dough upfront as long as it lasts and performs well. Saving money to spend more later never was a "perk" in my eyes. I am also looking into the crimped lines through Goodyear. I can buy them through work as premade "hydraulic" lines (hehe) with nice fittings. Still up in the air and trying to narrow options down. Anyone have anything on the AIM dash for street use? Again, thanks Thomas |
| ArtechnikA |
Jan 8 2013, 08:22 PM
out of curiousity, i went looking for Temprel, and discovered that it is a 'canceled' (as of 1990!) Federal Trademark once owned by B.F. Goodrich for tubular rubber products.
So what is it chemically? It _was_ whatever B. F. Goodrich said it was. Now? Who knows... I donno why Earls would continue to use a trademark not in current status, and one that isn't chemically deterministic. Sounds good, I suppose, but I wouldn't want to base a long-term installation on a zippy trademark. Perform-O-Flex is still my go-to brand for everything but fuel, although I knew guys who swore by Goodridge (N.B. - not Goodrich...). For fuels, my money's on something 'PTFE' (the generic for Teflon, another trademarked term...) based. E10 is here and there's no sign it's going away any time soon, whether it makes any kind of thermodynamic or economic sense or not. E15 is looming. I have a FlexFuel (E85...) vehicle and I'd want to make sure the plumbing for anything I built now was built to at least that standard. But that's just me... |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:33 AM |
