| Luke M |
Jan 8 2013, 09:52 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,497 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States
| ThePaintedMan |
Jan 8 2013, 10:57 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
This is an amazing stash. Started off with a lot of parts for a /6 conversion! I wish I had the money. Good stuff Luke.
| infraredcalvin |
Jan 13 2013, 09:09 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,737 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
Hi,
Interested in: 914-6 engine short block ser # * 6405500 * No history but turns over by hand : $900.00 Is it still avalable? Would you please send pics to: infraredcalvin@yahoo.com Thank you, Pat |
| hydroliftin |
Jan 13 2013, 09:32 PM
Member ![]() ![]() Group: Members Posts: 378 Joined: 8-November 06 From: Vallejo, CA Member No.: 7,180 Region Association: Northern California |
I want a pair of 914 2.0 liter intake gaskets (new) if still available, or even used if okay condition.
| Luke M |
Jan 18 2013, 12:08 PM
I want a pair of 914 2.0 liter intake gaskets (new) if still available, or even used if okay condition. I have them still... email me for pics , shipping and payment info. Luke |
| Phil Plummer |
Jan 20 2013, 03:48 PM
Member ![]() ![]() Group: Members Posts: 120 Joined: 7-January 12 From: Edmonton Ab Canada Member No.: 13,973 Region Association: Canada |
I purchased a lot of 911/914/914-6 parts that I'll be listing for sale here and the bird board. I just started to look at the parts and will take several days if not weeks to id some. I'll post pics of items if you see something that you may want, make me a reasonable offer if there's no price attached to a listing. I will add to the list as I find/id items. If I list an item that doesn't match the proper description please correct me. I have no history on these parts but will do my best to check and confirm things for buyer. Please take note that it may take a little time to do this. I can use Paypal but add their fees to total or I can take a check/money order. I'll wait for the payment to clear/post then ship items out. I've been selling parts on here like this w/o any problems. If you need to confirm this, ask other members on here that have purchased things from me in the past. They may even post on this add if they like to confirm our past transaction. The shipping cost of items is not included with price. In order to not have any conflict, I would like people to first ask for item on this add then e-mail me ( as I check that often ). I will sell item to first come and will confirm with the time/date of post. If the first person passes I'll go down the list. I have some 911 engine and misc parts listed on the pelican site: http://forums.pelicanparts.com/porsche-911...check-list.html Thanks, Luke E-mail : lmartini@rochester.rr.com The list starts : 911/914-6 mag manifolds New stickers still on them : part #'s 901 108 321 1R on manifolds . Sticker #'s 905/108/031 & 905/108/031/04 :40mm carb side/32mm head side ports: $300.00 911/914-6 mag manifolds slightly used if not new ( same as above #'s ) : $200.00 911/914-6 carb cross bar only (unable to locate other mounting hardware) : $40.00 911/914-6 carb cross bar with brackets : $80.00 911 engine cams. This is what is left. T, T MFI, E MFI, & S cams. I can send you pics as needed. Some lobe/bearing rust no other history. 914-6 Quick 6 engine mount : $60.00 911 Misc. engine sheet metal : $60.00 (see pic) 911 New performance friction pads carbon metallic fits A calipers (3 sets) : $50.00 pr. set part # on box is 045 69 911 108 mm 4 bolt cv, coarse spline trans flanges : $80.00 911 108 mm 4 bolt cv axle spindles : $80.00 911 73.5 to 83 CIS pop off valve New : $20.00 New Tan leather Nardi/Personal steering wheel with new hub/horn button. Hub fits 356 B, C /911 > 73, 912 65-69, 914-6 part # on hub box 1583600 and wheel is 1584841741 : $250.00 911/914-6 muffler made by Hersteller Abarth & Co. 911 S /2.2 10585 : $250.00 Steering wheel hub (made in Italy #0178) believe it fits 911 unk year : $40.00 Steering wheel hub spacer 3 bolt # ATI-403 (930S per Pelican parts): $30.00 911 engine oil line (2 with hoses attached & 1 w/o hose & larger id/od) : $40.00 w/o hose & $60.00 w/hose attached 911 Oil tank filler necks (would need to be re plated) 2 with caps/dip stick : $50.00 each & 2 w/o cap/dip stick : $25.00 each 911 Oil tank unk year and can't make out part # on sticker w/oil filter console. would need to be cleaned as it's been sitting on a shelf collecting dust : $400.00 911 rear bushings new (4 weltmeister # 004 black in color & 4 white unk brand) $20.00 pr set of 4 914 dellarto drla40s carbs (made in Italy)w/manifolds & linkage No history sold as is : $150.00 ***Sold*** 914 weber 40idf carbs (made in Spain)w/manifolds & linkage No history sold as is : $150.00 Shocks appear to be new or slightly used. 914 Koni Special D red rear shocks # 82K-1722 : $125.00 ***Sold*** 914 Koni Special D red front shocks (used) # 82R-1730 : $80.00 911 Koni Special D red front shocks (75-89 w koni struts) # 86R-1942 : $100.00 Koni Special D red shocks # 82R-1942 (looked up # but nothing found) : $100.00 914 New fiberglass flare set : $200.00 914 73-76 New rubber engine mounts part # 039 199 231 (have 3) : $15.00 each 914 1.7/1.8 New Empi muffler two single exhaust tips one pr side : $100.00 914 1.7/1.8 new muffler gaskets ( I have 35 sets ) : $4.00 per pr. 914 2.0 new muffler gaskets ( I have 2 sets ) : $5.00 per pr. 914 1.7/1.8 & 2.0 intake manifold heat insulators/gaskets, some new & used. 3 pr. 2.0 new 5mm thick : $5.00 per pr. 3 pr. 2.0 used 5mm thick : $2.00 per pr. 1 pr. 1.7/1.8 new 8mm thick : $4.00 pr. 4 pr. 1.7/1.8 used 8mm thick : $1.00 pr. 2 pr. 1.7/1.8 used 4mm thick : $1.00 pr. Stainless steel brake lines made by Precise Lines, New/Not DOT approved. part # RP6911 Fits 911 69-89 and 914 70-71 : $45.00 914 wheel lug bolt covers (have 23 on hand) : $5.00 for all 914 wheel studs 40 mm long (have 4 on hand) : $5.00 for all New Goetze piston rings stock # 08-399100-10 part # 025 198 151 STD 94x1, 75 + 2 + 4 mm , 914/4 1.8/1.9/2.0L : $40.00 Hi looking for a 94/6muffler for a 3.0 set up would prefer dual exhaust tips-Phil More to come ...... |
| Luke M |
Jan 20 2013, 04:38 PM
Do you have a muffler for a 914/6?? needed to go with my 911sc set up!
Also are the hellas for a 914 or a 911? if for a 914 let me know -Phil The only 914-6/911 muffler that I currently have is listed in my ad. I'm not sure what you are referring to on the hellas ?? Luke |
| dfelz |
Jan 21 2013, 01:36 AM
beach bum ![]() ![]() Group: Members Posts: 419 Joined: 7-June 12 From: San Diego Member No.: 14,538 Region Association: Southern California
Very interested in "914 1.7/1.8 New Empi muffler two single exhaust tips one pr side : $100.00"
Will follow with email, let me know if its still available and shipping cost to 91789. |
| Luke M |
Jan 30 2013, 09:12 AM
| Luke M |
Feb 23 2013, 11:25 AM
| Luke M |
Feb 28 2013, 09:43 AM
Added a few more parts.. (IMG:style_emoticons/default/beerchug.gif) |
| OU8AVW |
Feb 28 2013, 04:22 PM
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,804 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
PM sent (IMG:style_emoticons/default/biggrin.gif)
| pete000 |
Feb 28 2013, 09:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Is the plastic air box sold? if not I will take it. PM Sent.
Thanks ! |
| Luke M |
Mar 26 2013, 09:33 AM
| Luke M |
Apr 11 2013, 06:55 AM
| Luke M |
Apr 16 2013, 02:25 PM
| Luke M |
May 4 2013, 07:54 AM
| rgalla9146 |
May 4 2013, 08:14 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,950 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Hi Luke Do you still have the six bolt steering wheel adapter ? Rory |
| Luke M |
May 4 2013, 12:26 PM
Hi Luke Do you still have the six bolt steering wheel adapter ? Rory Hi Rory, Yes, I still have the hub. Luke |
| Hawk |
May 6 2013, 03:00 PM
Member ![]() ![]() Group: Members Posts: 351 Joined: 31-December 02 From: Ann Arbor, Michigan Member No.: 57 |
Luke,
Would you have early door panels? Any color. |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:54 AM |
