| wilchek |
Jun 27 2004, 09:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 506 Joined: 8-June 04 From: Eastern Pennsylvania Member No.: 2,177 |
does anyone know what these or a normal 914 with temp gage costs normally and what sending unit would I use to power the temp gage Thanks for any info. Dan
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...&category=46100 |
| markb |
Jun 27 2004, 09:20 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
I added a temp gauge to my standard tank gauge & Hollywood Speedo charged about $80.00 with the sender.
| Aaron Cox |
Jun 27 2004, 09:46 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
i bought a whole 3 gauge cluster for one of those gauges for around 60 bucks.
the ebay gauge is a /6 gauge, wont work correctly with the 4 cyl sender.... |
| propricer |
Jun 28 2004, 09:08 AM
Member ![]() ![]() Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
| markb |
Jun 28 2004, 09:44 AM
Thanks for the link, propricer. I didn't know anybody still made them. It's now at the top of my wish list. (IMG:style_emoticons/default/biggrin.gif)
| seanery |
Jun 28 2004, 10:10 AM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
how much?
| markb |
Jun 28 2004, 10:12 AM
I just emailed for a price. I'll post it when I get an answer.
| lapuwali |
Jun 28 2004, 11:05 AM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
It'll be at least $400. Way expensive for what it is, IMHO. Once upon a time, someone made a kit to assemble one of these yourself (front bezel all powercoated and silkscreened, and a back plate; you cut the OEM gauge back yourself and aquired gauges used). For some reason, I thought this person was Mueller, but my memory is vague and this was 5-6 years ago. I had one of these kits, but never assembled it and sold it with the car I bought it for.
A much cheaper alternative is to use a 911 oil temp/pressure combo gauge ($40-50 on ebay), and put the 914 fuel light in the slot where the oil pressure light goes in the 911 gauge. You lose the fuel gauge, but at least you still know when you're low on gas, and if your trip odo still works, it's a great indication of how much fuel you still have once you know how far you can usually go on a tank. You also lose the brake warning light, but frankly, if you don't know the handbrake is on, you need help. Having a light tell me my brakes have failed seems superfluous, as well. |
| jfort |
Jun 28 2004, 12:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,188 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest
i have the kit, but have not started to install it. i, too, sent an email to the company and asked some questions.
| Qarl |
Jun 28 2004, 02:40 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Here it is in a 914 cluster (with silver bezels and yellow indicator needles).
(IMG:http://www.my914-6.com/images/DSCN1745.JPG) |
| wilchek |
QUOTE(seanery @ Jun 28 2004, 12:10 PM) how much? I called for a price, 450.00 with everything, bulbs sending units. Fuel gage plugs into the original wiring. They said it would take a couple of weeks to put one together. |
| jfort |
Jun 29 2004, 07:16 AM
here is the response i received via email:
The cost for the complete 914-6 3 cluster is $450.00 + shipping. The kit includes a new temp sender, new oil pressure sender, mounting hardware, and all lights. The fuel gauge is calibrated to your current fuel sender. The new oil pressure sender replaces your current oil pressure switch, it actually screws into the same hole. The new temp sender replaces your current temp sender. Installation instructions I could give you over the phone, we do not have any instructions printed up that we could send you. Delivery time of the gauge is about 2 weeks. |
| rhodyguy |
Jun 29 2004, 08:17 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
another option. the plan was to install a 911 gage, but without a center console i would've had to drill the dash to put in a fuel gage, plus the added cost of the correct tank sending unit. the new plan at this point is to replace the temp gage from the 914 with the one from the 911 and change out the sending unit. my understanding is the 4 #'s on the gauge, 0033, is what you need for the correct sender. i'll have to live with the idiot light for preasure, if i go this route.
kevin Attached image(s)
| seanery |
Jun 29 2004, 08:23 AM
no fuel?
| rhodyguy |
Jun 29 2004, 08:34 AM
the numbered unit from the 911 will replace the one from the stock 914 oil temp without the numbers.
kevin |
| don9146 |
Jun 29 2004, 02:05 PM
Member ![]() ![]() Group: Members Posts: 199 Joined: 3-January 04 From: Nashville, TN Member No.: 1,500 Region Association: None |
North Hollywood Speedometer also makes a different style combo gauge that will work with a 6-conversion. They take an old 911 turbo tach and replace the boost gauge with a fuel gauge. The stock 911 oil temperature and pressure combo gauge is retained on the left of the tach in the dash. I think it looks "clean" while the triple cluster gauge looks "busy." I have one in my 914-6 conversion car, but I don't have a digital camera for pics (IMG:style_emoticons/default/sad.gif) .
I believe the cost of the Palo Alto triple tluster gauge and the North Hollywood Speedometer tach and fuel combo gauge are about the same. I thought there were pics of the gauge on North Hollywood's web site, but it seems to be down at the moment (IMG:style_emoticons/default/confused24.gif) ? |
| don9146 |
Jun 29 2004, 02:11 PM
Of course as soon as I post, the web site works again. Here is a pic installed in the dash from their web site.
Lo-Fi Version | Time is now: 2nd April 2026 - 08:32 AM |
