Shall I say... 3.6?, my conversion thread ... |
PRS914-6 |
Jun 18 2010, 12:25 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
An FYI....The conversion flywheel is smaller than a 993 making the sensor gap too big unless you machine the bracket for the sensor to drop deeper...see pictures Mine worked just fine ... (IMG:style_emoticons/default/confused24.gif) I set the gap to the factory specs and the adjustment on the stock bracket was more than enough. No machining needed. (IMG:style_emoticons/default/popcorn[1].gif) Andy My recollection is that I removed about .060 off the bracket. The holes in the bracket are large enough to move some but not nearly enough for mine to get close enough to the smaller flywheel. Bottom line, it's a setting that needs to be accurate for sure. Some people drill the holes larger in the bracket to gain a little movement. If you don't have to cut anything, better yet.... |
-JR- |
Jun 19 2010, 01:18 AM
Life goes faster at 150MPH Group: Members Posts: 276 Joined: 12-May 04 From: Victoria BC Canada Member No.: 2,055 |
I assume you're talking about the sensor on the flywheel. In which case the bracket is stock 993. All i did was to notch the 901 bellhousing in the right place for the sensor. As for the 944 axle conversion, there's a thread with all the details in the classics forum ... (IMG:style_emoticons/default/shades.gif) Andy Thanks Andy, I think I figured it out. My engine had no such bracket and I think this bracket only is installed on manual transmission cars. My engine came from a tiptronic car. Found the axel article. Had no idea that the "classic" forum had all the stuff in there. |
SirAndy |
Mar 22 2013, 12:15 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
... here's the current "todo" list ... - Fabricate oil cooler exit ducting Wow, it's only been 6 years since the post above. (IMG:style_emoticons/default/screwy.gif) Well, i finally decided to have McMark put in some time to make me an original custom oil cooler duct. (IMG:style_emoticons/default/beerchug.gif) The shroud is removable which allows for storing stuff like my toolbox behind it. |
Cairo94507 |
Mar 22 2013, 12:39 PM
Michael Group: Members Posts: 9,818 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
that looks very nice Andy.
SirAndy |
Mar 22 2013, 04:53 PM
that looks very nice Andy. (IMG:style_emoticons/default/agree.gif) Haven't seen it yet in person and i'm also waiting to see what the louvers in the hood look like. I'm excited about having proper air-flow now which should cut down on some of the heat issues i had. (IMG:style_emoticons/default/driving.gif) |
r_towle |
Mar 22 2013, 04:55 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Curious if that will blow alot of hot air on your head with the top off.
rich |
SirAndy |
Mar 22 2013, 04:56 PM
Curious if that will blow alot of hot air on your head with the top off. Poor mans heater for those bitter cold CA mornings ... (IMG:style_emoticons/default/laugh.gif) |
76-914 |
Mar 22 2013, 05:01 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,507 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Nothing some well placed vortex generators couldn't correct.
Madswede |
Mar 22 2013, 05:03 PM
Flat Out Driver Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains |
Sweeeeeet! (IMG:style_emoticons/default/sunglasses.gif)
Krieger |
Mar 22 2013, 05:20 PM
Advanced Member Group: Members Posts: 4,724 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Looks great. Can't wait to see the hood.
Krieger |
Mar 22 2013, 05:40 PM
Spoke |
Mar 22 2013, 07:44 PM
Jerry Group: Members Posts: 6,990 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Nice ducting.
2 questions: 1) is the ducting removable for access to the battery box? 2) What did/are you doing for exit onto the hood? |
SirAndy |
Mar 22 2013, 07:54 PM
2 questions: 1) is the ducting removable for access to the battery box? 2) What did/are you doing for exit onto the hood? 1 - Yes, no. Yes, it's removable, no, it's not a battery box, it's my toolbox. 2 - Je ne sais pas. That'll be a original customs surprise. The whole piece is build to be easily removed. It just drops in from the top and anchors to the cooler in the front and the firewall in the back. Once the hood is closed, it's held in place by the frame of the hood. (IMG:style_emoticons/default/popcorn[1].gif) |
bulitt |
Jul 21 2013, 04:58 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
(IMG:style_emoticons/default/icon_bump.gif) ing this thread to see if Andy has pics of his hood cut for the oil cooler
ducting? |
r_towle |
Jul 21 2013, 06:41 PM
2 questions: 1) is the ducting removable for access to the battery box? 2) What did/are you doing for exit onto the hood? 1 - Yes, no. Yes, it's removable, no, it's not a battery box, it's my toolbox. 2 - Je ne sais pas. That'll be a original customs surprise. The whole piece is build to be easily removed. It just drops in from the top and anchors to the cooler in the front and the firewall in the back. Once the hood is closed, it's held in place by the frame of the hood. (IMG:style_emoticons/default/popcorn[1].gif) Hinged so it flips forward.....then you don't need to find a place to put it on the ground... Just saying |
SirAndy |
Jul 21 2013, 08:00 PM
(IMG:style_emoticons/default/icon_bump.gif) ing this thread to see if Andy has pics of his hood cut for the oil cooler ducting? I'm going to take the car to work tomorrow, i'll post some pics then. It's a bit "rough" but works very well ... (IMG:style_emoticons/default/shades.gif) |
rick 918-S |
Jul 22 2013, 08:41 AM
Hey nice rack! -Celette Group: Members Posts: 20,480 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
SirAndy |
Jul 22 2013, 11:50 PM
It's a bit "rough" but works very well ... Alright, as promised, here are the pix ... View from the front View from the top The shroud in place The hood from the underside The shroud removed The shroud Since this hood is all bend up anyways, we just went ahead and cut the louvers directly into the hood. The final design will have a nice stamped (or FG) louvered section. As mentioned before, the shroud is slid into position from the top and is only held in place by the closed hood. It's very simply to take out (just lift it up). The improvement in cooling is almost too much (see my other thread about the car not getting up to operating temp). I also noticed a significant improvement in high speed stability, i'm guessing due to less air under the car and added downforce from the out the hood design. (IMG:style_emoticons/default/driving.gif) |
bulitt |
Jul 23 2013, 03:02 AM
Nice. Mini-ferrari type set up. The 308's and 512's didnt have a shroud, the front trunk bulkhead just acted as a wall to direct air up through the louvers, and as you did- Ferrari just used a strip of foam to seal the area. I would think the shroud will keep water out of the trunk to some extent, if you ever drive in the rain. I may go this route to vent my radiator and keep the wheel structure intact. Have a spare hood to mess with.
Thanks for posting. |
pcar916 |
Jul 23 2013, 06:58 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
This was fun to read! I should've taken a lot more pictures while building through all of the various stages. I have lots from specific mods but an entire timeline would've been a lot more interesting.
Note to self... next time stop long enough to take more pix along the way. It's just such a PITA to repeatedly stop working, clean up enough not to turn your camera into a greaseball, and get back to it. Second note to self: Invite friends to build with me, looks a lot more interesting. And there would have been more beer after each day's work. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 5th June 2024 - 12:07 PM |
