| Phoenix-MN |
May 10 2013, 08:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
What size engine are these going on? What are the throat sizes on them? What are you using to control them? I'm doing something similar with VFR800 ITBs. I really like how those come apart. The VFRs are 2 two-barrel castings. I'll be following this one. (IMG:style_emoticons/default/aktion035.gif) 1.7 with VFR800 tbs (work in progress) http://www.914world.com/bbs2/index.php?showtopic=192548 Mine are going on a 2.5L six and I'm using a Holley HP EFI ecu with crank fired ignition. The throat size on the GSX R600's is 38mm. My carbs are currently using 32mm venturies so 38's should be in the ball park. |
| Mark Henry |
May 10 2013, 08:18 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
What will be used to trigger the injectors? I already have the SDS-4F system, I ran it single TB modified D-jet plenum for several years in my 914. this time it's a much bigger engine and the upright conversion for the bug. I'm leaning towards milling it in and match porting as much as possible, I don't care for the adaptors much. |
| rick 918-S |
May 10 2013, 08:37 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
What will be used to trigger the injectors? I already have the SDS-4F system, I ran it single TB modified D-jet plenum for several years in my 914. this time it's a much bigger engine and the upright conversion for the bug. I'm leaning towards milling it in and match porting as much as possible, I don't care for the adaptors much. The rubber connector on my set have the depression to match the TB. Also the exiting side to the engine is a slight oval likely designed to help with reversion at the head. |
| McMark |
May 10 2013, 09:29 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
Just got a sextet of ITBs for my new 2.4 engine. I'm thinking about welding adapters so they bolt directly onto the heads.
| Mark Henry |
May 11 2013, 06:04 AM
Just got a sextet of ITBs for my new 2.4 engine. I'm thinking about welding adapters so they bolt directly onto the heads. Wouldn't the TB's warp? and would you real need to do this? One thing I notice is although there's meat at the flange the TB castings are very thin. |
| crash914 |
May 11 2013, 08:00 AM
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,830 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
Just get Evil to weld you up some manifolds like he did for his bus....
| rick 918-S |
May 11 2013, 08:04 AM
Cast aluminum sometimes is tricky to weld. I've had issues with it kind of bleeding contamination. I've had to stop and clean the parts as I go. Otherwise I think if the flange isn't too thick Mark could weld the TB's to a flange or shortened intake. I would try to make the welds tiny. If you were in doubt You could always weld the inside seam also.
| McMark |
May 11 2013, 10:24 AM
Came to my senses a little bit. Ordered one of the stock plastic/rubber boots to try. If these work, I'll just use them instead. Welded on flanges would be cool, but the cost to produce the pieces I need (custom) and then the effort to weld them on is more than is really worth it unless I have no other option.
Warping may be an issue, but for $25 for three throttle bodies, I'd be willing to try it. (IMG:style_emoticons/default/wink.gif) |
| r_towle |
May 11 2013, 07:28 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I love the title of the thread.....just cause its so true.
I would love to see one of these project done to completion. Rich |
| JamesM |
May 12 2013, 09:01 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,187 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Like I need another project... Beginning to be as bad as Dr Evil (IMG:style_emoticons/default/laugh.gif) ... (IMG:style_emoticons/default/huh.gif) ... (IMG:style_emoticons/default/unsure.gif) I need some TB's for my Jenvey, Extrudabody and TWM TB's are crazy frickin' expensive for what they are, so I'm going the Motorcycle TB route. This is what came in the mail today, stuff looks real good (IMG:style_emoticons/default/piratenanner.gif) How come no one ever brings up the CB Performance TBs, looks like they are making the 40s again. http://www.cbperformance.com/ProductDetail...roductCode=7097 Sure used bike TBs are still cheaper but the CB setup is still pretty cheap, and when you consder the time it takes to hack together the bike TBs just to wind up with what is still a hacked together solution it does not add up. For $500 bucks the CB parts bolt on, my time is worth more then that. Of course if you are doing it for the fun of the build, then it is a different story. |
| McMark |
May 12 2013, 10:02 AM
| stugray |
May 12 2013, 12:00 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE What did the TBs come off of? I have pondered this for my TR6. 98, 99 Suzuki GSXR 750. http://www.ebay.com/itm/98-99-suzuki-gsxr7...y-/110850134032 ~$180 Google IS your friend. And it looks like only one of the four has the TPS. Will you put one of the TPS on each side, or depend on the linkage to keep them synched? Stu |
| sixnotfour |
May 12 2013, 12:50 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Mcmark, I have the same ones, get to it x2=$$ |
| Mark Henry |
May 12 2013, 04:12 PM
It's OK (IMG:style_emoticons/default/smile.gif) I thought about do this on my 914/6 conversion as well, But I already have the Webers I would have used Triumph TB's , what ones are those? |
| McMark |
May 12 2013, 08:50 PM
Polaris 650 TBs. I'm reconsidering since they're 46mm, which is huge for a 2.4. But I might just strive ahead and if they're too big just sell the setup to a 3.2 owner.
| Mark Henry |
May 15 2013, 02:31 PM
I didn't like the funky shape on the bottom of the TB so I did some profiling today. (IMG:style_emoticons/default/smile.gif)
Original shape is top right TB. Attached image(s)
| Eric_Shea |
May 15 2013, 02:34 PM
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Beginning to be as bad as Dr Evil Send those to Evil... he can weld them up for ya! (IMG:style_emoticons/default/w00t.gif) |
| Dr Evil |
May 15 2013, 07:48 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
QUOTE Beginning to be as bad as Dr Evil Send those to Evil... he can weld them up for ya! (IMG:style_emoticons/default/w00t.gif) Nope, I am out of argon........prick. (IMG:style_emoticons/default/dry.gif) |
| MDG |
May 16 2013, 08:50 AM
Wolf in wolf's clothing. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,653 Joined: 3-February 09 From: Toronto Member No.: 10,018 Region Association: None |
QUOTE Beginning to be as bad as Dr Evil Send those to Evil... he can weld them up for ya! (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/mellow.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) |
| Mark Henry |
Nov 21 2013, 07:38 PM
I was making good progress, but work got in the way. Now I'm hoping to have both my bug and 914/6 project done for the spring. But I do have several jobs for others that have to be done as well.
This is my progress on my ITB project. this was originally for my 914 but now it's going in my 67 bug. Attached image(s)
Lo-Fi Version | Time is now: 2nd April 2026 - 07:27 AM |
