| Bob L. |
May 26 2013, 04:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 851 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
It was not a dizzy rebuilt thread, it was the thread I opened when I was having the issue. Here is the Link Thanks for all the input Paul. This is frustrating, but fun, Can't wait to solve this puzzle. I still can't get the piece off the bottom of the shaft. I don't want to damage it. Should I just give it a good whack with a pin punch? |
| Bob L. |
May 27 2013, 03:27 PM
Progress update...
I have another dizzy from a 1.7. It's a different model # but I swapped out the advance plate for the freshly cleaned and lubed one and dropped it in. After setting the dwell and timing again, there is definitely an improvement. It's not all the way there but better. There is still a little stumble coming off idle, not too bad. once it catches, it wants to jump to about 3000. For slower acceleration, it still wants to hang up around 2000. Just not as bad! I'm pretty sure I have to stick with this type of diz, but which is the optimal version regarding advance curve, transition off idle and flat spot(lack of)? Some ?s. Does the 1.7 diz have a different curve/max advance than the 2.0? Can the weights/springs be changed to improve "things"? Are there any Dizzy rebuild threads? I have searched. Thanks, Bob. |
| Dave_Darling |
May 27 2013, 04:27 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Advance specs scraped from the factory manuals:
http://web.archive.org/web/20001119214600/...ch/distrib.html --DD |
| SLITS |
May 27 2013, 04:32 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Progress update... I have another dizzy from a 1.7. It's a different model # but I swapped out the advance plate for the freshly cleaned and lubed one and dropped it in. After setting the dwell and timing again, there is definitely an improvement. It's not all the way there but better. There is still a little stumble coming off idle, not too bad. once it catches, it wants to jump to about 3000. For slower acceleration, it still wants to hang up around 2000. Just not as bad! I'm pretty sure I have to stick with this type of diz, but which is the optimal version regarding advance curve, transition off idle and flat spot(lack of)? Some ?s. Does the 1.7 diz have a different curve/max advance than the 2.0? Can the weights/springs be changed to improve "things"? Are there any Dizzy rebuild threads? I have searched. Thanks, Bob. the advance curves are different, but similar enough to work. Rebuilding a dizzy is more a matter of cleaning and checking function than anything. Centrifugal advance springs can be checked for tension but finding the specification may be hard. Don't know if new parts are available. Centrifugal advance can be checked by merely hooking a timing light to #1 and starting the engine. From idle, watch the mark move into the window as you slowly accelerate the engine. The movement should be reasonably smooth. The only other thing in rebuilding a dizzy is replacement of the shaft busing in the housing. It is pressed in an honed to size. A worn shaft allows the point cam to wobble back and forth, changing dwell / timing as it does. One cure without rebuilding is the Petronix, Ignitor, or whatever pointless systems available on the market. |
| Bob L. |
May 27 2013, 06:36 PM
Thanks Dave. Checking the stampings, it looks like they are the same distributor!? I assumed they would not be. Same #s and all. so I guess I have the correct curve in play. I'm still not convinced the new one is up to snuff. The shaft feels stable but it makes more noise and isn't as smooth as the old one. Still hoping I can get the cam off the bottom of the shaft and replace the thrust bushing. Anyone know about that? Is the thrust washer part of the distributor rebuild kit? Available by itself? (Cap'n?) Still could be a TPS issue...? Hmmmmmm... Damn it! |
| 914itis |
May 27 2013, 08:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States |
I have a good working 2.0 dizzy, PM me if you are interested.
| Bob L. |
Jun 8 2013, 06:41 PM
Update:
Finally got the dizzy reconditioned. All clean and lubed nice. It helped a bit. not dramatically. It seems more like the old hesitation coming off idle now. I know that as a problem with the 009's. Mine is a "011". Do they have the same issue? I tried clamping off the fuel line to the 5th injector just to see if it made a difference. Nope. I took off and cleaned up the TPS. It has remarkably little wear. I put it back. It also seems better after the engine warms up. Still not very good. Once it gets going it seems pretty good. If I shift and the rev's drop below 3000. It'll buck a bit. Do I need to keep the rev's up higher? Makes it hard to go slow through the neighborhood. NEXT! |
| Bob L. |
Jun 15 2013, 04:53 PM
Update:
(IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/driving.gif) I decided to start from the beginning again and I'm glad I did. Two injectors were loose. Huge vacuum leak (IMG:style_emoticons/default/headbang.gif) At least one spark plug wire was faulty. I swapped out for a spare (old) set of wires and tightened the injectors up. Started right up as easily as I have ever seen AAAAnd the hesitation/bogging is gone I seem to remember a few of you telling me to check things like that. I wish I did it sooner Thank you all for your input. (IMG:style_emoticons/default/beer.gif) Oh, By the way, where does the oil temp sending lead go to? I know it seems simple but...do I just extend the lead to the gauge? |
| Cairo94507 |
Jun 16 2013, 07:16 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,609 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Very cool. What a satisfying feel to have resolved that issue. Now enjoy driving that baby.
| 76-914 |
Jun 16 2013, 08:37 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,876 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
There is a plastic incased female spade fitting just beneath the battery coming off the harness on the shelf. It's easy to miss as it is only a few inch's long.
| Bob L. |
Jun 16 2013, 10:52 AM
Lo-Fi Version | Time is now: 2nd April 2026 - 07:21 AM |
