| rhd914 |
Jul 9 2013, 11:06 PM
Newbie ![]() Group: Members Posts: 44 Joined: 11-November 03 From: Australia Member No.: 1,332 |
Hi, well at long last my project car is almost complete. It came off the road in 2006 for a lot of reason. The car is now complete again and has a nice 3.2 in it along with a host of other upgrades.
I have just fitted Michelin pilot sport 3 front and rear. I want to send it for an alignment, but the spec for the rear toe in settings are in degree. Can anyone tell me what the setting is in millimeters? Thanks Geoff |
| messix |
Jul 9 2013, 11:15 PM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
use this to convert, http://www.onlineconversion.com/forum/forum_1061942119.htm
degrees is a constant regardless of distance or length. [tire diameter] that's is why the "degree" is the universal alignment standard. |
| r_towle |
Jul 10 2013, 08:25 AM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Tire diameter is required when using inches or MM measurements.
The machine should be using degrees, not MM measurements, regardless of what part of the world you reside. Look at the factory manual, the numbers are in degrees. At the end of the day, you want almost just a hair of toe in at the rear. Rich |
| stugray |
Jul 10 2013, 08:49 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE At the end of the day, you want almost just a hair of toe in at the rear. I assume you mean Toe IN ;-) As for the measurement it is: Wheel Diameter (mm)= WD Angle of Toe (degrees) = AT Distance of Toe = DT (mm) DT = WD * SIN(AT) So for a 15 inch rim (15 inches = 381mm) And One degree of Toe: DT = 381(mm) * SIN(1.0) = 381 * 0.01745 = 6.65 mm So for every degree of Toe-IN (near zero) you would space the forward rim of the wheel IN by ~6.6mm (or ~ 1/4 inch) Stu |
| sixnotfour |
Jul 10 2013, 09:37 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,184 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Factory setting is below, thanks to Bowlsby
15 minutes is .25 of a degree 20 minutes is .333 of a degree 30 minutes is .50 of a degree Attached image(s)
| SirAndy |
Jul 10 2013, 11:10 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can anyone tell me what the setting is in millimeters? Millimeters will be different depending on your wheel size, so no, there is no easy answer. If you are using strings to align the car and measuring mm from the lip of the wheel to the string, you need to do the math (distance from the axle center to your wheel lip) and calculate the the mm that give you a certain degree of toe (in or out). However, if this is for a street car, i'd just set it to 0 degrees ... (IMG:style_emoticons/default/shades.gif) |
| r_towle |
Jul 10 2013, 11:35 AM
| r_towle |
Jul 10 2013, 11:39 AM
Can anyone tell me what the setting is in millimeters? Millimeters will be different depending on your wheel size, so no, there is no easy answer. If you are using strings to align the car and measuring mm from the lip of the wheel to the string, you need to do the math (distance from the axle center to your wheel lip) and calculate the the mm that give you a certain degree of toe (in or out). However, if this is for a street car, i'd just set it to 0 degrees ... (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/agree.gif) Rear can be zero...works better for a street car. To much toe IN at the rear makes the car really darty, and you get sucked around in ruts the trucks leave on the highways. More toe IN helps on an autox car...helps turn the car in quickly. |
| stugray |
Jul 10 2013, 11:45 AM
QUOTE You can read, right? Sorry, when I read that my brain registered: QUOTE At the end of the day, you want almost just a hair of toe in the rear. AND since I have been measuring the TOE "in the rear" on my car the last few days AND IT is toed OUT, I am also interested in the subject. Stu |
| TravisNeff |
Jul 10 2013, 12:12 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region
toe in makes the car more stable in a straight line, toe out makes the car want to turn!
| Downunderman |
Jul 10 2013, 01:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
Geoff, I run about 1 - 1.5 mm per side toe in on the rear. Seems to work pretty well. |
| jimkelly |
Jul 10 2013, 01:19 PM
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
I assume you guys do this with car on ground with wheels/tires on.
loosen the bolts some, and tap the bracket toward the wanted position? or does this have to be done with car off the ground? jim |
| Bartlett 914 |
Jul 10 2013, 04:19 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
If you are using strings to align the car and measuring mm from the lip of the wheel to the string, you need to do the math (distance from the axle center to your wheel lip) and calculate the the mm that give you a certain degree of toe (in or out). If you are using Stu's numbers then the measurement would be the difference between the rear of the rim to the front of the rim measured at the center line of the wheel. If you are measuring from the axle to the rim, Stu's numbers are double the number you need. |
| Dave_Darling |
Jul 10 2013, 06:01 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
To much toe IN at the rear makes the car really darty, and you get sucked around in ruts the trucks leave on the highways. More toe IN helps on an autox car...helps turn the car in quickly. Wrong way around. It's toe OUT at the front that can help initial turn-in. And makes the car darty. Toe OUT at the rear of the car is pretty diabolical. It means the tail of the car will like to step out, and will try to keep going once it starts sliding. Not so good... --DD |
| sixnotfour |
Jul 10 2013, 06:39 PM
QUOTE Geoff, I run about 1 - 1.5 mm per side toe in on the rear. Seems to work pretty well measured where ?? |
| r_towle |
Jul 10 2013, 07:27 PM
To much toe IN at the rear makes the car really darty, and you get sucked around in ruts the trucks leave on the highways. More toe IN helps on an autox car...helps turn the car in quickly. Wrong way around. It's toe OUT at the front that can help initial turn-in. And makes the car darty. Toe OUT at the rear of the car is pretty diabolical. It means the tail of the car will like to step out, and will try to keep going once it starts sliding. Not so good... --DD No, you have it wrong. Fr auto cross. Toe out in front, toe in in the rear, both more than a street car. Car turns in fast.....sucks to drive on the road, you need to hold on tight to the wheel. Rich |
| Dave_Darling |
Jul 10 2013, 10:42 PM
Read it again, Rich.
Toe OUT in front, better turn in but the car is darty. OK for autoX, bad for the street and a bit of a handful on the big track. If you toe OUT in the back, the car goes sideways all the time. You don't want that. Street: Toe in at the front, toe in at the rear. AutoX: Toe out at the front, toe in at the rear. Big track: Toe in at the front, toe in at the rear. --DD |
| rhd914 |
Jul 11 2013, 01:57 AM
Hi and thanks for the reply's. I was looking for a reading in mm as the printout from the tyre shop gave the reading in mm. So I guess I will make a calculation and work out what I need them to set it at.
I am thinking this one is a little beyond them. I am going to look for someone else to do this. Love the info I have learnt a lot from this. My area is wires so I am loving the chance to learn some more. Geoff |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:30 AM |
