| Shindog1961 |
Oct 20 2013, 11:08 AM
Member ![]() ![]() Group: Members Posts: 196 Joined: 10-November 12 From: Santa Fe New Mexico Member No.: 15,133 Region Association: Southwest Region |
Just want to make sure this is possible. I have a 1.7 case that I want to make into a 2.0 ish engine. I'm hoping with 2.0 heads, cam, cranks etc... it will be plug and run into a stock 1974 2.0 FI. Any potential problems with a 1.7 case?
| TheCabinetmaker |
Oct 20 2013, 11:33 AM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
You will have to open up the case registers for the two litre cylinders.
| 914_teener |
Oct 20 2013, 12:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,270 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
(IMG:style_emoticons/default/WTF.gif)
The head registers need to be opened up....if you are going to use 1.7 heads. Good luck finding good 2.0 heads. . |
| reharvey |
Oct 20 2013, 12:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
1.7--1.8---2.0 cases--they're all the same and interchangable. No need to cut anything. I've built 2.0 engines out of 1.7 cases more then once. I'm surprised that so many people think the 2.0 case is something special. Only the serial # stamp makes it different.
(IMG:style_emoticons/default/dry.gif) |
| TheCabinetmaker |
Oct 20 2013, 12:47 PM
I guess I stand corrected. That's what I get for repeating info I have gotten here from what I thought were very knowledgeable and reliable sources. Now I cant believe anything that anyone says. Damn!
| HAM Inc |
Oct 20 2013, 12:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
QUOTE I guess I stand corrected. That's what I get for repeating info I have gotten here from what I thought were very knowledgeable and reliable sources. Now I cant believe anything that anyone says. Damn! Welcome to the internet. |
| Java2570 |
Oct 20 2013, 02:21 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
http://www.hamincgroup.com/main.php
Talk to Len Hoffman about getting the best heads..... you can find used 2.0L heads but for the money I've seen good used, rebuilt ones going for lately, why gamble. For a little more $$ you can get new ones that are better and will last a lot longer! |
| r_towle |
Oct 20 2013, 03:50 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I guess I stand corrected. That's what I get for repeating info I have gotten here from what I thought were very knowledgeable and reliable sources. Now I cant believe anything that anyone says. Damn! Jake has added to many threads, and all cases have the same registers for the cylinders. The 1.7 cylinders have the thickest walls. |
| Dave_Darling |
Oct 20 2013, 04:06 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
If you were to use the 1.7 heads with the 2.0's cylinders, the registers in the heads would have to be opened up. If you're going with 2.0 heads, the 2.0 cylinders will fit just fine.
--DD |
| Jake Raby |
Oct 20 2013, 05:49 PM
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
I'll give you 100 bucks if you can find a T4 case that doesn't have the same register size as a 1.8 or 2.0.
You won't find it, not even a magnesium version. |
| TheCabinetmaker |
Oct 20 2013, 06:37 PM
Looks like I have been thoroughly chastised for my stupidity. Now I will never forget again that all cases are the same. Hey, didn't all you guys know that? I will go write it 100 times on the blackboard.
| oldschool |
Oct 20 2013, 07:18 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,374 Joined: 29-October 08 From: P-town Member No.: 9,705 Region Association: Southern California |
QUOTE I guess I stand corrected. That's what I get for repeating info I have gotten here from what I thought were very knowledgeable and reliable sources. Now I cant believe anything that anyone says. Damn! Welcome to the internet. Funny |
| r_towle |
Oct 20 2013, 07:19 PM
| malcolm2 |
Oct 20 2013, 07:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,749 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States
Looks like I have been thoroughly chastised for my stupidity. Now I will never forget again that all cases are the same. Hey, didn't all you guys know that? I will go write it 100 times on the blackboard. But wait.... (IMG:style_emoticons/default/type.gif) the internet also said that using 2.0 rods in a 1.7 case requires some clearance.... Didn't I read that ? (IMG:style_emoticons/default/shades.gif) |
| Cap'n Krusty |
Oct 20 2013, 08:40 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:59 PM |
