| HalfMoon |
Feb 7 2014, 04:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Hi all,
I'm doing my trailing arms bushings today (poly) and knowing they have to be reamed for the shaft so I grabbed a brake/cylinder honer I had handy and started boring the bushing (like what I'd seen in threads here at World.) Unfortunately I'll grow old a die before this method gets me anywhere. Simply put, it's not cutting it (or hardly). I saw in a thread that Eric with PMB now uses a small 3X1 barrel sander to get this work done (like this one http://www.mcmaster.com/#rubber-drums/=qlel82) and so I guess I'll go ahead and order one along with a bunch of sanding bands...but even then, I've heard the task can be a rather long one. Anyone have experience with this job and have a tool recommendation to cut this material using garage type tools (drill)? |
HalfMoon ISO Trailing arm bushing ream advice Feb 7 2014, 04:30 PM
ThePaintedMan Where did you order the bushings from? Eric is the... Feb 7 2014, 04:47 PM
HalfMoon
Where did you order the bushings from? Eric is th... Feb 7 2014, 04:52 PM
r_towle Small drum sanders work.... Feb 7 2014, 05:09 PM
motorvated
Hi all,
I'm doing my trailing arms bushings t... Feb 7 2014, 07:10 PM
HalfMoon
[quote name='HalfMoon' post='1994917' date='Feb 7... Feb 7 2014, 07:26 PM
jcd914 I have always used flapper wheels to sand/ream the... Feb 7 2014, 07:57 PM
HalfMoon
I have always used flapper wheels to sand/ream th... Feb 7 2014, 09:40 PM
MikeM I bought my bushings from Eric and used the brake ... Feb 8 2014, 11:10 AM
HalfMoon 80 grit, 1"X1", flapper wheel from NAPA ... Feb 12 2014, 10:03 PM
jimkelly check out #44
http://www.914world.com/bbs2/index.... Feb 13 2014, 05:59 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:51 PM |
