> 911 engine number question
914ltd
post Apr 7 2014, 11:57 AM
I purchased a 911 magnesium engine case that has an odd serial number seeming authentically stamped in the correct place. 3180259. The case is a 1R series casting number. Any way to check this number out? Thanks! Brad
ejm
post Apr 7 2014, 05:04 PM
I can see the light at the end of the tunnel
According to the engine s/n listings in "The Porsche Family Tree" book the only year that had a seven digit number beginning with 3 was 1968 but the lowest number was 3280001. Any chance you are miss reading the number?
Jeffs9146
post Apr 7 2014, 06:00 PM
Ski Bum
It is a 68 Targa!
911 Targa 901/06 130/6100 176/4200 11880001-11880268 3180001-3180347
Porsche 911 Identification
914ltd
post Apr 7 2014, 08:40 PM
Thanks Jeff and Ed, It doesn't fall in the numbers but that isn't unusual. I owned a couple 68's years ago but they were aluminum case engines?? I certainly didn't remember the mag case before 1969. Furthering your education includes relearning things forgotten. Brad
Jeffs9146
post Apr 8 2014, 11:02 AM
Ski Bum
QUOTE(914ltd @ Apr 7 2014, 07:40 PM) *
It falls well withing the range of numbers for a 68 targa!
3180001-3180347
It is number 259 in the range of 347 built!
ClayPerrine
post Apr 8 2014, 11:32 AM
Probably a replacement engine that had a blank number plate. There were no mag cases in 68. The dealer installing it probably just put the original engine number on there.
Jeffs9146
post Apr 8 2014, 11:53 AM
Ski Bum
QUOTE(ClayPerrine @ Apr 8 2014, 10:32 AM) *
Maybe but I think there were 20 mag cased 911R motors built between 1967 and 1968 for "race only" cars!
The R designation meant a lightened car with thinner sheet metal and a racing engine with 210 bhp at 8000 rpm. This particular example is one of only 20 made and has an extensive period racing history.
The 110 PS (81 kW; 108 hp) 911T was also launched in 1967 and effectively replaced the 912. The staple 130 PS (96 kW; 128 hp) model was renamed the 911L. The 911R had a very limited production (20 in all), as this was a lightweight racing version with thin aluminium doors, a magnesium crankcase, twin-spark cylinder heads, and a power output of 210 PS (154 kW).
Porsche used the Type 901/22 engine from the Carrera 906 to power the 911R. Some of the cars were given mechanical Bosch fuel injection systems while others received Weber carburetors.
914ltd
post Apr 8 2014, 02:30 PM
QUOTE(Jeffs9146 @ Apr 8 2014, 09:02 AM) *
3180001-3180347
Forgot how to count as well. Brad
brant
post Apr 8 2014, 03:03 PM
QUOTE(ClayPerrine @ Apr 8 2014, 11:32 AM) *
I've seen a few aluminum cases in 1968, and a few magnesium cases in 1968
it was a transition year... probably the mag motors were later in the year
my race car has a 1972 7R case that was MFI
the 7R cases were all supposed to be 1973.5 CIS cars
but I think when the motor cases switched production they went into the assembly line no matter the model year... same thing as the aluminum to magnesium motors.
- Lo-Fi Version Time is now: 2nd April 2026 - 08:55 AM
